    Routing between DMZ and LAN
    3 Posts 2 Posters 929 Views
      tuanquan
      Hi there,
      I have a pfsense setup as below:
      WAN: 192.168.1.1
      DMZ:  172.16.200.1
      LAN:  172.16.100.1
      For testing purpose, I have two rules, one in LAN and one in DMZ to allow ICMP
      I can only ping within LAN and LAN to pfsense 172.16.100.1
      I can not ping from DMZ to DMZ's pfsense interface 172.16.200.1
      Eventually, I like to allow certain traffic between DMZ and LAN.
      How I can do so?
      Thanks,
      LAN.JPG_thumb
      DMZ.JPG_thumb
      • V Offline
        viragomann
        Check the DMZ interface settings for
        • the correct network mask
        • if "block private networks" is checked
        Also check the network settings on the DMZ computer.
          tuanquan
          Resolved.
          One of the rule was set incorrectly.
          Thanks.
