WAN interfaces fail to return after power outage
Hmm, well the DHCP logs should still show if the bad address is coming from somewhere upstream. If it's coming from a different DHCP server you can block it as a source and the client will continue to look for other servers. That works well with cable modems that do this.
Anyway check the logs for 0.0.0.0 messages.Steve
I can't see anything in the DHCP logs for 0.0.0.0 I even lengthened the log to 1,000 entries, which took me back to about 11am today, should I go back further?
Here's what's in there, I can't make much sense of it, can you?
what's the "fail" all about?Nov 16 13:20:13 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 16 13:20:14 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 16 13:20:16 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 3 Nov 16 13:20:19 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 16 13:20:24 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 16 13:20:37 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 14 Nov 16 13:20:51 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 12 Nov 16 13:21:03 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 8 Nov 16 13:21:11 dhclient 99656 No DHCPOFFERS received. Nov 16 13:21:11 dhclient 99656 No working leases in persistent database - sleeping. Nov 16 13:21:11 dhclient FAIL Nov 16 13:21:26 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 16 13:21:27 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 16 13:21:28 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 16 13:21:30 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 16 13:21:32 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 16 13:21:38 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 14 Nov 16 13:21:52 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 11 Nov 16 13:22:03 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 16 Nov 16 13:22:11 dhcpd DHCPREQUEST for 10.20.63.134 from 80:5e:c0:07:7f:9c (W60B) via igb3 Nov 16 13:22:11 dhcpd DHCPACK on 10.20.63.134 to 80:5e:c0:07:7f:9c (W60B) via igb3 Nov 16 13:22:19 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 8 Nov 16 13:22:27 dhclient 99656 No DHCPOFFERS received. Nov 16 13:22:27 dhclient 99656 No working leases in persistent database - sleeping. Nov 16 13:22:27 dhclient FAIL Nov 16 13:22:42 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 16 13:22:43 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 16 13:22:45 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 16 13:22:49 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 9 Nov 16 13:22:58 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 21 Nov 16 13:23:19 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 16 Nov 16 13:23:36 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 7 Nov 16 13:23:43 dhclient 99656 No DHCPOFFERS received. Nov 16 13:23:43 dhclient 99656 No working leases in persistent database - sleeping. Nov 16 13:23:43 dhclient FAIL Nov 16 13:23:58 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 16 13:24:00 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 16 13:24:05 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 8 Nov 16 13:24:13 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 16 Nov 16 13:24:29 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 19 Nov 16 13:24:48 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 11 Nov 16 13:24:59 dhclient 99656 No DHCPOFFERS received. Nov 16 13:24:59 dhclient 99656 No working leases in persistent database - sleeping. Nov 16 13:24:59 dhclient FAIL Nov 16 13:25:14 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 16 13:25:16 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 16 13:25:21 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 9 Nov 16 13:25:30 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 9 Nov 16 13:25:40 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 12 Nov 16 13:25:52 dhclient 99656 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 15
Hmm, disappointing. The fail simply indicates the dhcp client failed to get get a lease from a server after completing its sequence and starts again after a pause.
Does the Nigthhawk log anything for this connection or is it entirely bridging?
I will have a look but I'm not holding my breath for any decent logging in a Netgear piece of equipment. I don't think this is a Netgear problem though, it doesn't happen with any other device such as a laptop. You can restart the laptop and it gets an IP address just fine. It's only when pfSense is restarted that this happens. And it's not just isolated to the Netgear device, it also happens with the WAN connection - so both connections fail to come back when the router is restarted. If the power goes off or I need to reboot the router for any reason, I have to go into the router, disable the interfaces and then re-enable the interfaces for them to work again.
Had to re-read the thread as I'd assumed it was a powerfailure on the upstream devices the prevented it connecting. Not connecting to either WAN after rebooting pfSense is even more weird.
Can you restore the connection by pulling the cable and reconnecting it? Or does it need logically disabled while remaining connected?
Unplugging and replugging also works the same as disabling and re enabling the interface. It comes back online and gets correct ip address.
please help :-)
I think a packet capture showing the client failing to get a lease is the next step here.
Do you see anything coming back from the DHCP server at all?Steve
Thanks Steve. Sorry, as I'm not a total expert (yet), can you please break it down for me a bit?
Packet capture - from within pfSense? (as in Diagnostics -> Packet Capture?) If so, what settings do I use?
ps - I just found a display bug - I'm using Chrome on a Mac - there are more options in Diagnostics that I can't access because I'd have to scroll, but even if I scroll to the bottom of the page, I can't scroll the dropdown menu from Diagnostics (see attached image). Also, it's worse if the "downloads" bar is visible at the bottom of the Chrome window, it covers up the last one or two options in the Diagnostics menu.
I just checked the DHCP log, here's what it shows: (see below) Is it the Netgear that's not giving out an address via DHCP? Because it will if I connect my laptop to it via WiFi. There is definitely a link light on the ethernet port of the router that is connected to the Netgear, and occasionally the activity light will blink.
Nov 23 14:54:12 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 14:54:13 dhclient 84923 No DHCPOFFERS received. Nov 23 14:54:13 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 14:54:13 dhclient FAIL Nov 23 14:54:28 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 14:54:29 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 14:54:31 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 14:54:36 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 6 Nov 23 14:54:42 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 9 Nov 23 14:54:51 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 19 Nov 23 14:55:10 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 14:55:23 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 6 Nov 23 14:55:29 dhclient 84923 No DHCPOFFERS received. Nov 23 14:55:29 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 14:55:29 dhclient FAIL Nov 23 14:55:44 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 14:55:45 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 14:55:46 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 14:55:47 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 14:55:49 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 14:55:54 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 14:56:07 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 16 Nov 23 14:56:23 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 9 Nov 23 14:56:32 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 11 Nov 23 14:56:43 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 14:56:45 dhclient 84923 No DHCPOFFERS received. Nov 23 14:56:45 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 14:56:45 dhclient FAIL Nov 23 14:57:00 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 14:57:01 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 14:57:03 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 14:57:07 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 14:57:12 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 14:57:17 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 14:57:30 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 14:57:43 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 14 Nov 23 14:57:57 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 14:58:01 dhclient 84923 No DHCPOFFERS received. Nov 23 14:58:01 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 14:58:01 dhclient FAIL Nov 23 14:58:16 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 14:58:18 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 14:58:22 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 11 Nov 23 14:58:33 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 10 Nov 23 14:58:43 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 20 Nov 23 14:59:03 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 8 Nov 23 14:59:11 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 6 Nov 23 14:59:17 dhclient 84923 No DHCPOFFERS received. Nov 23 14:59:17 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 14:59:17 dhclient FAIL Nov 23 14:59:32 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 14:59:34 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 3 Nov 23 14:59:37 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 6 Nov 23 14:59:43 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 9 Nov 23 14:59:46 dhcpd DHCPREQUEST for 10.20.63.33 from ac:37:43:e8:50:4a (android-5482cd93fd6e378c) via igb3 Nov 23 14:59:46 dhcpd DHCPACK on 10.20.63.33 to ac:37:43:e8:50:4a (android-5482cd93fd6e378c) via igb3 Nov 23 14:59:52 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 15:00:05 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 14 Nov 23 15:00:19 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 10 Nov 23 15:00:29 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 15:00:33 dhclient 84923 No DHCPOFFERS received. Nov 23 15:00:33 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:00:33 dhclient FAIL Nov 23 15:00:48 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:00:49 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:00:51 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 3 Nov 23 15:00:54 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 15:00:58 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 6 Nov 23 15:01:04 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 12 Nov 23 15:01:16 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 15:01:29 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 12 Nov 23 15:01:41 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 8 Nov 23 15:01:49 dhclient 84923 No DHCPOFFERS received. Nov 23 15:01:49 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:01:49 dhclient FAIL Nov 23 15:02:04 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:02:05 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:02:07 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:02:09 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 15:02:14 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 15:02:19 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 9 Nov 23 15:02:28 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 19 Nov 23 15:02:47 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 16 Nov 23 15:03:03 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:03:05 dhclient 84923 No DHCPOFFERS received. Nov 23 15:03:05 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:03:05 dhclient FAIL Nov 23 15:03:20 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:03:22 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 15:03:26 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 9 Nov 23 15:03:35 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 21 Nov 23 15:03:56 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 14 Nov 23 15:04:10 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 11 Nov 23 15:04:21 dhclient 84923 No DHCPOFFERS received. Nov 23 15:04:21 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:04:21 dhclient FAIL Nov 23 15:04:36 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:04:37 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:04:38 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:04:39 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:04:41 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 15:04:45 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 6 Nov 23 15:04:51 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 15 Nov 23 15:05:07 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 12 Nov 23 15:05:19 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 14 Nov 23 15:05:33 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 15:05:38 dhclient 84923 No DHCPOFFERS received. Nov 23 15:05:38 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:05:38 dhclient FAIL Nov 23 15:05:53 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:05:54 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:05:55 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:05:56 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:05:58 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:06:00 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 15:06:05 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 15:06:10 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 14 Nov 23 15:06:24 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 17 Nov 23 15:06:41 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 15:06:54 dhclient 84923 No DHCPOFFERS received. Nov 23 15:06:54 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:06:54 dhclient FAIL Nov 23 15:07:09 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:07:10 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:07:12 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 15:07:16 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 8 Nov 23 15:07:24 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 12 Nov 23 15:07:36 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 17 Nov 23 15:07:53 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 17 Nov 23 15:08:10 dhclient 84923 No DHCPOFFERS received. Nov 23 15:08:10 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:08:10 dhclient FAIL Nov 23 15:08:25 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:08:27 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 15:08:31 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 15:08:36 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 6 Nov 23 15:08:42 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 15:08:55 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 8 Nov 23 15:09:03 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 10 Nov 23 15:09:13 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 7 Nov 23 15:09:20 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 6 Nov 23 15:09:26 dhclient 84923 No DHCPOFFERS received. Nov 23 15:09:26 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:09:26 dhclient FAIL Nov 23 15:09:30 dhcpd DHCPREQUEST for 10.20.63.35 from e8:99:c4:7e:78:7b (android-aaa02c5bc3d65de) via igb3 Nov 23 15:09:30 dhcpd DHCPACK on 10.20.63.35 to e8:99:c4:7e:78:7b (android-aaa02c5bc3d65de) via igb3 Nov 23 15:09:41 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:09:42 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:09:44 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 15:09:49 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 15:10:02 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 19 Nov 23 15:10:21 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 13 Nov 23 15:10:34 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 8 Nov 23 15:10:42 dhclient 84923 No DHCPOFFERS received. Nov 23 15:10:42 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:10:42 dhclient FAIL Nov 23 15:10:57 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 1 Nov 23 15:10:58 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:11:00 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 15:11:04 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 7 Nov 23 15:11:11 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 16 Nov 23 15:11:27 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 12 Nov 23 15:11:39 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 8 Nov 23 15:11:47 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 11 Nov 23 15:11:58 dhclient 84923 No DHCPOFFERS received. Nov 23 15:11:58 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:11:58 dhclient FAIL Nov 23 15:12:13 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:12:15 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 4 Nov 23 15:12:19 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 10 Nov 23 15:12:29 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 17 Nov 23 15:12:46 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 17 Nov 23 15:13:03 dhclient 84923 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 11 Nov 23 15:13:14 dhclient 84923 No DHCPOFFERS received. Nov 23 15:13:14 dhclient 84923 No working leases in persistent database - sleeping. Nov 23 15:13:14 dhclient FAIL
I just noticed that new firmware was available for it so I updated it and after a couple of reboots, it's back online. Here's the log from DHCP in pfSense:
Nov 23 15:45:13 dhclient 81089 No DHCPOFFERS received. Nov 23 15:45:13 dhclient 81089 No working leases in persistent database - sleeping. Nov 23 15:45:13 dhclient FAIL Nov 23 15:45:25 dhclient 81089 igb1 link state up -> down Nov 23 15:45:26 dhclient 57640 connection closed Nov 23 15:45:26 dhclient 57640 exiting. Nov 23 15:45:42 dhcpd reuse_lease: lease age 854 (secs) under 25% threshold, reply with unaltered, existing lease for 10.20.63.133 Nov 23 15:45:42 dhcpd DHCPREQUEST for 10.20.63.133 from a0:99:9b:14:37:55 (Petes-MBP) via igb3 Nov 23 15:45:42 dhcpd DHCPACK on 10.20.63.133 to a0:99:9b:14:37:55 (Petes-MBP) via igb3 Nov 23 15:46:02 dhclient PREINIT Nov 23 15:46:02 dhclient EXPIRE Nov 23 15:46:02 dhclient Deleting old routes Nov 23 15:46:02 dhclient PREINIT Nov 23 15:46:02 dhclient 71272 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 2 Nov 23 15:46:04 dhclient 71272 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 3 Nov 23 15:46:07 dhclient 71272 DHCPDISCOVER on igb1 to 255.255.255.255 port 67 interval 5 Nov 23 15:46:10 dhclient 71272 DHCPOFFER from 192.168.1.1 Nov 23 15:46:10 dhclient 71272 unknown dhcp option value 0x78 Nov 23 15:46:10 dhclient ARPSEND Nov 23 15:46:13 dhclient ARPCHECK Nov 23 15:46:13 dhclient 71272 DHCPREQUEST on igb1 to 255.255.255.255 port 67 Nov 23 15:46:13 dhclient 71272 DHCPACK from 192.168.1.1 Nov 23 15:46:13 dhclient 71272 unknown dhcp option value 0x78 Nov 23 15:46:13 dhclient BOUND Nov 23 15:46:13 dhclient Starting add_new_address() Nov 23 15:46:13 dhclient ifconfig igb1 inet 192.168.1.46 netmask 255.255.255.0 broadcast 192.168.1.255 Nov 23 15:46:13 dhclient New IP Address (igb1): 192.168.1.46 Nov 23 15:46:13 dhclient New Subnet Mask (igb1): 255.255.255.0 Nov 23 15:46:13 dhclient New Broadcast Address (igb1): 192.168.1.255 Nov 23 15:46:13 dhclient New Routers (igb1): 192.168.1.1 Nov 23 15:46:13 dhclient Adding new routes to interface: igb1 Nov 23 15:46:13 dhclient Creating resolv.conf Nov 23 15:46:13 dhclient 71272 bound to 192.168.1.46 -- renewal in 21600 seconds. Nov 23 15:46:16 dhcpd Internet Systems Consortium DHCP Server 4.3.6-P1 Nov 23 15:46:16 dhcpd Copyright 2004-2018 Internet Systems Consortium. Nov 23 15:46:16 dhcpd All rights reserved. Nov 23 15:46:16 dhcpd For info, please visit https://www.isc.org/software/dhcp/ Nov 23 15:46:16 dhcpd Config file: /etc/dhcpd.conf Nov 23 15:46:16 dhcpd Database file: /var/db/dhcpd.leases Nov 23 15:46:16 dhcpd PID file: /var/run/dhcpd.pid Nov 23 15:46:16 dhcpd Internet Systems Consortium DHCP Server 4.3.6-P1 Nov 23 15:46:16 dhcpd Copyright 2004-2018 Internet Systems Consortium. Nov 23 15:46:16 dhcpd All rights reserved. Nov 23 15:46:16 dhcpd For info, please visit https://www.isc.org/software/dhcp/ Nov 23 15:46:16 dhcpd Wrote 0 deleted host decls to leases file. Nov 23 15:46:16 dhcpd Wrote 0 new dynamic host decls to leases file. Nov 23 15:46:16 dhcpd Wrote 73 leases to leases file. Nov 23 15:46:16 dhcpd Listening on BPF/igb3/00:0e:c4:d2:10:2c/10.20.63.0/24 Nov 23 15:46:16 dhcpd Sending on BPF/igb3/00:0e:c4:d2:10:2c/10.20.63.0/24 Nov 23 15:46:16 dhcpd Sending on Socket/fallback/fallback-net Nov 23 15:46:16 dhcpd Server starting service. Nov 23 15:46:20 dhcpd Internet Systems Consortium DHCP Server 4.3.6-P1 Nov 23 15:46:20 dhcpd Copyright 2004-2018 Internet Systems Consortium. Nov 23 15:46:20 dhcpd All rights reserved. Nov 23 15:46:20 dhcpd For info, please visit https://www.isc.org/software/dhcp/ Nov 23 15:46:20 dhcpd Config file: /etc/dhcpd.conf Nov 23 15:46:20 dhcpd Database file: /var/db/dhcpd.leases Nov 23 15:46:20 dhcpd PID file: /var/run/dhcpd.pid Nov 23 15:46:20 dhcpd Internet Systems Consortium DHCP Server 4.3.6-P1 Nov 23 15:46:20 dhcpd Copyright 2004-2018 Internet Systems Consortium. Nov 23 15:46:20 dhcpd All rights reserved. Nov 23 15:46:20 dhcpd For info, please visit https://www.isc.org/software/dhcp/ Nov 23 15:46:20 dhcpd Wrote 0 deleted host decls to leases file. Nov 23 15:46:20 dhcpd Wrote 0 new dynamic host decls to leases file. Nov 23 15:46:20 dhcpd Wrote 73 leases to leases file. Nov 23 15:46:20 dhcpd Listening on BPF/igb3/00:0e:c4:d2:10:2c/10.20.63.0/24 Nov 23 15:46:20 dhcpd Sending on BPF/igb3/00:0e:c4:d2:10:2c/10.20.63.0/24 Nov 23 15:46:20 dhcpd Sending on Socket/fallback/fallback-net Nov 23 15:46:20 dhcpd Server starting service. Nov 23 15:55:36 dhcpd reuse_lease: lease age 1448 (secs) under 25% threshold, reply with unaltered, existing lease for 10.20.63.133 Nov 23 15:55:36 dhcpd DHCPREQUEST for 10.20.63.133 from a0:99:9b:14:37:55 (Petes-MBP) via igb3 Nov 23 15:55:36 dhcpd DHCPACK on 10.20.63.133 to a0:99:9b:14:37:55 (Petes-MBP) via igb3
