    Problems between iphone and dhcp?
    56 Posts 5 Posters 12.6k Views 4 Watching
      @stephenw10 said in Problems between iphone and dhcp?:
      there's really no reason the iphone should react at all to dhcpd restarting.
      exactly - the only thing I could see having any possible effect at all is a reload of the firewall rules.. if that got hung up then maybe ok, but states are not flushed on a reload, I don't think that is a default setting - mine don't flush the states, etc..
      So if you started a ping just as the firewall rules were reloading I could see maybe an issue?
      • E Offline
        edpbettinelli @johnpoz
        @johnpoz Last night I tried from home in vpn to reload the rules I am attaching the ping screen to pfsense.
        There was an iphone connected which never lost the ping during all my tests (the ping, however, was from my pc in vpn to the iphone).
        This morning I tried to activate a dhcp on a test vlan and my iphone crashed as usual,
        while the rest of the devices had no problems (same behavior of the attached snap).
        I forgot the iPhones are managed by a mdm in the cloud.
        Other tests I will be able to do only when the company is stopped.
        Do you have tests to recommend to me to get more data to find the cause of the problem?
        Thank you very much for your support, I will keep you updated on the developments.
        Luca Bottini
          stephenw10 Netgate Administrator @edpbettinelli
          @edpbettinelli said in Problems between iphone and dhcp?:
          my iphone crashed
          I assume you mean it was unable to connect out via WIFI?
          It didn't actually crash?
          • E Offline
            edpbettinelli @stephenw10
            I mean that the iphone has lost the connection to the pfsense for the usual minute.
            After that everything goes back to normal even on iPhones
              How exactly are you seeing this on the iphone?
              You are running a ping?
              You can't connect to the webgui?
              Can't pull a new IP?
              I have a phone connected via wifi to pfSense here but unless I was actively testing I wouldn't notice if it got disconnected for 1min.
              Even if dhcp failed completely any client should just continue to use it's existing IP until the lease expires.
              Is the iphone pulling a very short dhcp lease? Like 1min?
              E johnpozJ 2 Replies Last reply Reply Quote 0
              • E Offline
                I launch an extended ping to pfsense from the iphone no problem, I do an apply on dhcp vlan test activation and the ping stops responding (between 50 and 60 lost pings)
                The phone can only communicate with devices on the same vlan, no internet, no GUI,no routing to other vlan. When the iphone loses the ping client just continue to use existing ip.
                Default lease time on this VLAN 7 days.
                  Yeah the only thing that would make sense on dhcp issue like that is lease time crazy crazy low!! I mean insane low!!
                  • E Offline
                    @johnpoz said in Problems between iphone and dhcp?:
                    I don't know the details of how iPhones manage dhcp.. Sniffing with wireshark ?
                      Try running a packet capture on pfSense for the pings during the outage.
                      Are the pings arriving?
                      Are the replies going back to the correct MAC?
                      • E Offline
                        As soon as I find the time since these tests cause voice problems in the company I try to do everything and let you know. Thanks a lot for the moment.
                        Luca
                          Gertjan @edpbettinelli
                          Look in the pfSense log for details.
                          Look at the dhcp leases file (the file the DHCP uses to store all the leases it gave away to devices)
                          On the apple.com site, the 'dev' part, there are tools to be downloaded to can detail much more a what can be seen in the apple phone GUI.
                          Is this iOS 14.6 ?
                          This is the lease duration as the DHCP server registered my "192.168.2.222" iPhone lease :
                          lease 192.168.2.222 {
                            starts 4 2022/03/17 15:52:06;
                            ends 4 2022/03/17 21:52:06;
                          This doesn't mean the DHCP client on the iPhone side will respect this delay.
                          So, in theory, my iPhone will renew the lease after 3 hours.
                          But most probably I will walk out of the Wifi covered zone, walk back into it, so the DHCP client will kick in again, and most probably ask a new lease, etc etc.
                          Btw ; I've read here that there are VLANs in play.
                          There is another factor, not mentioned because we can't see, smell or hear it :what about the AP used ? These devices are not all equal. What about the equality of the radio waves ? Other radio devices near by ? Is there a micro wave close by that blast out of orbit the frequency range from 0 to 5 Ghz ??
                          I've been using iStuff from day one, on good AP's and plain crap ones. Very rare that I even suspected that the Apple stuff was doing things wrong. And if so, an Apple update took care of things.
                          Right know, I"m using iOS 14.x 6 ? (as since this morning) : no issues known to me.
                          • E Offline
                            edpbettinelli @Gertjan
                            @gertjan
                            I'm trying to create a small factory to be able to test without impacting the company. Soon the wifi bubble created by 60 old AP extreme will be replaced with 50 AP Aruba. I will try factory testing using both an Aruba AP and an old extreme to evaluate any differences. Maybe so I'll have a little clearer ideas. A thousand thanks
                            Luca
                              Yeah, the iphones could still be requesting a very short lease time. Check the logs to see what they are actually being given.
                              • E Offline
                                Hi guys update..
                                i have implemented a small lab with a switch an ap and the same pfsense 2440 model with the same rules. After going through all the operations (dhcp restart, reservation, resolver restart) that could give me the problem, my iphone never lost a ping.
                                At the level of the production FW I noticed that there was a problem on the pfsense ntp in the release of the lease time and after fixing this thing the problem seems to have changed, the disconnection from pfsense is much shorter and above all it affects only some phones apparently random.
                                Occurred on multiple simultaneous voip calls only a couple of people lost the ping and consequently the call with pfsense. I am a little confused.
                                I was able with packet capture to take a snapshot of when the problem occurs. attached
                                error_fonia2.cap error_fonia.cap
                                  johnpoz LAYER 8 Global Moderator @edpbettinelli
                                  @edpbettinelli ok a quick look at those - and 2 things jump out at me as odd.
                                  You keep trying to talk to this
                                  ;; QUESTION SECTION:
                                  ;35.231.241.80.in-addr.arpa.    IN      PTR
                                  ;; ANSWER SECTION:
                                  35.231.241.80.in-addr.arpa. 38400 IN    PTR     mx1.ot-mail.it.
                                  on port 443, sending lots of syn - but never see a syn,ack back
                                  Other thing this is odd - is why I assume pfsense 10.135.0.1 keeps arping for 10.135.0.146 - but never sees a response. But when .146 arps for .1 - you get a response.
                                  So you can see here - you get a ping request, but no response - .1 arping for .146... But then after .146 arps for 1 and gets a response your pings get replies..
                                  I also see bunch of dns queries to 8888 and 1111 but never see any responses.. Are you blocking dns to them?
                                  • E Offline
                                    This is the picture of my problem.
                                    ot-mail (ip 80.241.231.35). is the company's mail server and 8.8.8.8 and 1.1.1.1 the dns assigned by dhcp are obviously not blocked. at that moment pfsense does not respond to the iphone, then as you can see without doing anything the connectivity restores the ping replies arrive the dns replies etc .
                                      They are not getting any answers..
                                      In neither of your sniffs do I see any dns answers.. Maybe its asking something else.. But there are no answers to dns in either of your sniffs.
                                      And why is .146 not answering any arps?
                                      • E Offline
                                        @johnpoz At this moment I don't know how to give you an answer. I'd like to say that I stopped packet capture before connectivity resumed. I will try to do other tests in the lab even if I haven't verified the problem yet. In production it is now risky to test now. However, at a company not in production I will try again to make some captures.
                                        Thank you very much for helping
                                          @edpbettinelli here is the thing - the really odd thing is why .146 is not answering the arps.. But pfsense for sure could not answer a ping, if he doesn't have the mac address of .146 in his arp table.. If he had the mac in his arp table, he shouldn't need to arp for it..
                                          I would really look to why not answering those arps..
                                          • E Offline
                                            @johnpoz I forced the situation and I think I can provide you with the correct capture. After the block comes the replies as well. I confirm that the previous capture was aborted before reconnection.completo-packetcapture.cap
