2100 LAN(1-4) Lights Are Solid Green In All States Except For No Power
What does
etherswitchcfgreport at the CLI? -
says file dne. apologies... got a severe cold or allergies this weekend -
@luckman212
console is the only thing i can use... was unable to access the gui when providing the wan a private ip. -
says file dne
dne ... is that short for "does not exist" ? I checked a few 2100s in my fleet and they all had it at
/sbin/etherswitchcfg -
@luckman212
correct... sorry for the incoherent lingo... once i feel better, i can pull exactly what the console stated when i ran the etherswitchcgfg. my memory was that the console said it was missing -
If it said 'unable to open switch device' then first try a full power cycle. Not a reboot. Seeing that implies the switch IC is not responding but I have seen that happen if it somehow gets into some invalid mode. After a voltage spike perhaps.
i was thinking along those lines, but I do have it plug into a Furman PL-PLUS Series 11 power conditioner. I have tried multiple reboots to no avail. TAC did provide me with and RMA late Friday. I appreciate all of your time and help, but I don't want to waste any more of it. -
Rebooting does not reset the switch IC. If it is in that state then you need to actually remove the power to reset it.
@nadaesbuenien said in 2100 LAN(1-4) Lights Are Solid Green In All States Except For No Power:
etherswitchcgfg
etherswitchcfg *
@SteveITS
please see my reply about being sick... thank you for consideration
