Port forwarding problems
I can't really help you if you don't answer any of my questions.
ok, I'm trying to open ports for servers eg minecraft. i have opened the ports and yet no one outside my wan can connect, also i'm not sure about nat reflection
hey Strayan have you tried my suggestion? ??? you may give it a shot. it is up to you ;)
OK, what is the actual IP address of your Minecraft server? Is it 192.168.1.4 or 192.168.1.11? Considering you can't connect from outside the network, we don't need to worry about NAT reflection for now.
as per image#1…he has not initialized which interface to be used. That is why he's having an issue.
ip to the server is 192.168.1.11, i tried perdong suggestion and still isn't working
http://puu.sh/am0mO/73536b3347.png
http://puu.sh/am0nO/ce6360bf47.png
Get the ISP modem set to bridgemode and do not use double NAT.
When done, write again.
thanks bridged mode works! :) btw screw your internet speed supermule :(
http://www.speedtest.net/result/3640741297.png -
Nice to hear :) and yes Fiber is the way forward here :D
Hello!
I'm trying to access an internal website from outside network. I have a fixed IP address 177.43.90.40, and my website is on the port 9060. The internal access is ok, but from outside, doesn't work. My internal server IP address is 192.168.200.127.
My modem address is 192.168.25.1 and its set DMZ to my pfsense proxy: 192.168.25.3My nat settings:
WAN TCP * * WAN address 9060 192.168.200.127 9060 SISecxus
What am I doing wrong???
You also need a firewall rule on your WAN port allowing that traffic to traverse from outside in. Do you have that?
If you do have the rule turn logging on for that rule then check the firewall logs to see if the connection shows there.
