    Captive portal not redirecting on https requests. problem on every browser
    32 Posts 3 Posters 11.9k Views 3 Watching
    • F Offline
      fahad77678
      Hi every one
      KInldy Please help me on this:
      I am using pfsense 2.4.4 p1. I have a problem that captive portal not redirecting automatically on DNS. when i entered ip against dns it redirects to me captive portal login page. like when i dail 8.8.8.8 its fine but when i entered google or something else its not reaching. when i enable https login in captive portal page shows to me unsafe error and not proceeding as well. in Firefox https login just then working when i manually entered the captive portal ip or port to exeptions.
      • F Offline
        free4 Rebel Alliance @fahad77678
        @fahad77678 said in Captive portal not redirecting on https requests. problem on every browser:
        Hi every one
        First of all, if you plan to enable HTTPS on your captive portal in production, you should get a valid certificate for your captive portal (you can use either let's encrypt or someting else).
        But even if you get a valid certificate, you may have an HTTPS/HSTS error when browsing https://google.com . That's completly normal and that's simply how HTTPS works. There is no way to mitigate this
        On recent firefox/chrome/safari versions, any browser that get opened try first to make an HTTP request to a "test website", to check if there is a captive portal on your network :
        alt text
        • F Offline
          fahad77678
          For https loging would i have to import certificate on every browser or system ?
          currently when i manually entered the certificate to browser then redirects to login page only in firefox. otherwise chrome chow unsafe error.
          is it possible to add certificate in pfsense for secure connection? because if i have a 500 pcs it would be very difficult for me to add certificates manually on every sytem
            Gertjan @fahad77678
            No.
            Exemple : When you visit https://www.papypal.com you do not have to import the paypal cert neither. Your browser recognizes that that certificate has been build using a known certificate organization, and accepts it.
            With the acme package you can obtain a certificate from LetEnscrypt, also recognized by all browsers.
            Enabling https login is ok, if you have a valid certificate, not some "home made" one (like the one pfSense makes for you for it's GUI access).
            is it possible to add certificate in pfsense for secure connection? because if i have a 500 pcs it would be very difficult for me to add certificates manually on every system
            That's why the acme package exists ...
            So you broke the DNS for the clients visiting the portal.
            Check out this part.
            Normally, by default, the resolver running on pfSense will resolve for all LAN clients - and also for all clients connected to the portal. This is because a firewall rule exists on the captive portal interface that allows incoming connections for port 53 UDP, TCP on the pfSense's portal IP. So even when not authenticated yet, the client can resolve www.google.com (totally meaningless to a browser) to an IP like 74.125.140.101 - 74.125.140.139 - 74.125.140.100 - 74.125.140.113.
            Now, as you said, it can "dail out" (ans will be intercepted by the same ipfw firewall, and redirected to the captive portal web server that shows the login page).
            So, a lookup for google.com will resolve.
            • F Offline
              fahad77678
              I i gave you a teamviwer or any desk session can you configure the captive portal with proper settings. actually i have only this problem of redirecting on dns
                Gertjan
                I advise you to disable the https login on the captive portal if you do not want to use the acme package.
                Use the resolver in default mode.
                No extra DNS's like "8.8.8.8".
                Keep everything to default, and the captive portal works in a minute.
                • F Offline
                  fahad77678
                  Yes i disable https login but page not redirecting to captive portals page dont know what is the issue now
                  • F Offline
                    fahad77678
                    Its only works when i delete the browser history. Then when i entered the google.com and every dns with .com when i use the it redirects to login page. but when the session expire the its does not redirecting to me on login page. i want that if i entered only a single word in google it should redirect to me into login page if i am not logged in
                    GertjanG F 2 Replies Last reply Reply Quote 0
                      Gertjan @fahad77678
                      If you were visiting some site, and the portal session expires, then yes, your browser will hit the captive portal 'firewall' wall.
                      Your browser has the URL resolved (and local DNS is up to date) so
                      Also : if your were visiting a https site, then the portal can't kick in, because there is this law that says : "you can't break / intercept https traffic".
                      You should use high values for idle and hard time out.
                      You can login again by :
                      Rip out the RJ45 cable or switch off the Wifi connection for while.
                      Close your browser.
                      Enable the wire or radio connection.
                      Or, more easel y : visit any http site (not a https site, or a http site that has HTST activated) again and hit Ctrl-F5.
                      • F Offline
                        fahad77678
                        i want redirecting on every requests whether it http or https. kindly tell me the configuration tha do this for me. i am running captive portal on lan or vlan connections.
                        • F Offline
                          fahad77678
                          Just tell me is it possible to redirecting every page to captive portal ?
                            Gertjan
                            Any http page will get redirected to the portal login page - if the users isn't logged in already.
                            A https page : normally, no - but browsers could be smart about what to do.
                            Btw : never ever change captive portal settings if you have logged in users - if you really have to change settings, throw out users first.
                            • F Offline
                              fahad77678
                              U mean to say that normally captive portal cannot redirect the https request if user not logged in? mean this is not possible?
                                Gertjan @fahad77678
                                You know the ansswer already.
                                https == SSL traffic can NOT be intercepted. If that would be possible, that https:// sites are identical to http:// visits.
                                You do know what https:// is, right ? What it stands for - what it means ?
                                Example : if you type in https:/:www.google.com, your browser ill first resolve google.com. As soon as it gets an IP, it will do https://172.217.22.142/ (on port 443).
                                In the reply there will be a certificate that states that it is connected to "*.google.com" .
                                If the captive portal intercepts this request, it will not return the certificate of Google, but it own certificate - which will be anything but not "google.com". Your browser, being smart, knows that you want to connect to google.com, but some other site replied. The browser knows it's request is redirected- or their is some other MITM.
                                It will bail out with the famous certificate error message.
                                • F Offline
                                  fahad77678
                                  In simple words my captive portal not redirecting. please help me on this
                                    Gertjan
                                    On a device that you connect to the portal network - but not logged in yet, show what these commands show to you :
                                    ipconfig  /all
                                    nslookup google.com
                                    or better
                                    nslookup onisep.fr
                                    • F Offline
                                      fahad77678
                                      C:\Users\fahad>nslookup onisep.fr
                                      Server: pfsense.localdomain
                                      Address: 192.168.1.1
                                      Non-authoritative answer:
                                      Address: 213.162.50.177
                                      • F Offline
                                        fahad77678
                                        @gertjan said in Captive portal not redirecting on https requests. problem on every browser:
                                        nslookup google.com
                                        C:\Users\fahad>nslookup google.com
                                        Addresses: 2404:6800:4003:806::200e
                                        74.125.130.113
                                        74.125.130.102
                                        74.125.130.139
                                        74.125.130.138
                                        74.125.130.101
                                        74.125.130.100
                                        • F Offline
                                          fahad77678
                                          C:\Users\fahad>ipconfig/all
                                          Windows IP Configuration
                                          Host Name . . . . . . . . . . . . : Muhammad-Fahad
                                          Primary Dns Suffix . . . . . . . :
                                          Node Type . . . . . . . . . . . . : Hybrid
                                          IP Routing Enabled. . . . . . . . : No
                                          WINS Proxy Enabled. . . . . . . . : No
                                          DNS Suffix Search List. . . . . . : localdomain
                                          Ethernet adapter Ethernet:
                                          Connection-specific DNS Suffix . : localdomain
                                          Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connection
                                          Physical Address. . . . . . . . . : D4-C9-EF-E5-F4-27
                                          DHCP Enabled. . . . . . . . . . . : Yes
                                          Autoconfiguration Enabled . . . . : Yes
                                          Link-local IPv6 Address . . . . . : fe80::1998:6eb8:b089:d1a6%24(Preferred)
                                          IPv4 Address. . . . . . . . . . . : 192.168.1.10(Preferred)
                                          Subnet Mask . . . . . . . . . . . : 255.255.255.0
                                          Lease Obtained. . . . . . . . . . : Monday, January 7, 2019 4:05:06 PM
                                          Lease Expires . . . . . . . . . . : Monday, January 7, 2019 5:50:52 PM
                                          Default Gateway . . . . . . . . . : fe80::1:1%24
                                          192.168.1.1
                                          DHCP Server . . . . . . . . . . . : 192.168.1.1
                                          DHCPv6 IAID . . . . . . . . . . . : 164940271
                                          DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-21-ED-F6-29-D4-C9-EF-E5-F4-27
                                          DNS Servers . . . . . . . . . . . : 192.168.1.1
                                          NetBIOS over Tcpip. . . . . . . . : Enabled
                                          Connection-specific DNS Suffix Search List :
                                          localdomain
                                          Wireless LAN adapter Local Area Connection* 4:
                                          Media State . . . . . . . . . . . : Media disconnected
                                          Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3
                                          Physical Address. . . . . . . . . : 3C-A9-F4-2E-A0-41
                                          Wireless LAN adapter Local Area Connection* 5:
                                          Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4
                                          Physical Address. . . . . . . . . : 3E-A9-F4-2E-A0-40
                                          Wireless LAN adapter Wi-Fi:
                                          Connection-specific DNS Suffix . : Home
                                          Description . . . . . . . . . . . : Intel(R) Centrino(R) Ultimate-N 6300 AGN
                                          Physical Address. . . . . . . . . : 3C-A9-F4-2E-A0-40
                                            Gertjan
                                            92.168.1.1
                                            Ok, looks all good.
                                            DNS works - pfSense is the DNS resolver for your clients.
                                            You use the default login page ?
                                            What GUI firewall rules on your captive portal interface ?
