    help with forwarding for home assistant
    51 Posts 6 Posters 20.3k Views 6 Watching
    • wgstarksW Offline
      wgstarks
      I'm trying to forward traffic on port 8123 to home assistant. I thought this would be simple but I can't get it to work.
      If I try to connect to home assistant via the external IP I get a timeout. Same if I use a port checker to test the port. What did I get wrong?
      Box: SG-4200
      • V Offline
        viragomann
        What you're showing here is a firewall rule, not a port forwarding. So we can assume you have it set correctly.
        Does the home assistant accept access from outside its subnet? You may test that by attempting to access from another internal network.
        wgstarksW 1 Reply Last reply Reply Quote 0
        • wgstarksW Offline
          wgstarks @viragomann
          @viragomann
          I dont have another subnet to try this. Here is the port forward rule-
          I tried enabling logging for this rule but I'm not seeing anything related to it in the firewall log. Maybe I'm looking at the wrong log?
          Box: SG-4200
          • wgstarksW Offline
            wgstarks
            I think maybe I found the issue. I was trying to connect from the same LAN using the external IP. Don't understand why that doesn't work but if I connect from my iPhone via LTE I'm successful.
            Box: SG-4200
            • V Offline
              viragomann @wgstarks
              @wgstarks
              If you can't see anything in the log maybe the port is blocked by your ISP.
              You Packet Capture from the Diagnostic menu to investigate.
              Take a capture on WAN interface, set the port filter to 8123 and attempt to access it from outside.
              If you get nothing there, the packets don't reach your WAN.
              • V Offline
                @wgstarks said in help with forwarding for home assistant:
                So its working as expected?
                No idea how you have done that.
                • wgstarksW Offline
                  @viragomann said in help with forwarding for home assistant:
                  Just a browser window and enter <MyWANIP>:8123
                  This works from outside my local network but not internally? Not sure why?
                  The port is being forwarded though. Thanks for your help.
                  Box: SG-4200
                  • V Offline
                    This only works with NAT reflection.
                    You can activate it in a single NAT rule or globally in system settings. However, its recommended to better use hostnames and split DNS.
                    • wgstarksW Offline
                      @viragomann
                      Like this?
                      Box: SG-4200
                        Why would you want to expose your home assistant to the public internet? Doesn't seem like a very smart thing to do from a security point of view..
                          tman904
                          Maybe use IPSEC or OPENVPN instead of exposing your server directly to the WAN.
                          • V Offline
                            Like this?
                            Yes, using pfSense for DNS resolution presumed. So can access the home assistant with the same host name from within your network as well as from outside.
                            However, security concerns are not regarded with this recommendation.
                            • wgstarksW Offline
                              wgstarks
                              Is there really a security concern? I'm asking this as a legitimate question. I only have a basic layman's knowledge regarding network security but I have a very strong password set for HA and would think that it would be adequate. Maybe that's not true?
                              Box: SG-4200
                              • wgstarksW Offline
                                wgstarks @tman904
                                @tman904 said in help with forwarding for home assistant:
                                I have OpenVPN setup on my iPhone but at the time I set it up I couldn't find a way to keep it active. Maybe that has changed now (it's been a few years)?
                                Box: SG-4200
                                  Why do you think you even need to open the port? There should be zero reason for opening inbound ports to control your home smart things while outside your home.. They phone home (company servers) and you control via that connection.
                                  I can turn on/off my lights, change the temp on the hvac, etc. without having any ports open.
                                  If your using some home grown thing - that you need to talk to while remote, then yes vpn would be the secure way to do that.. Not opening it up to the whole internet..
                                  • wgstarksW Offline
                                    wgstarks @johnpoz
                                    @johnpoz said in help with forwarding for home assistant:
                                    My iOS app fails to connect without a connection to my local network.
                                    Box: SG-4200
                                      You are using this?
                                      https://www.home-assistant.io/
                                      • wgstarksW Offline
                                        wgstarks @wgstarks
                                        Yes
                                        Box: SG-4200
                                          Yeah you would want vpn then... If they server doesn't make a connection to outside services, like alexa, google, all the other 3rd brand lights and switches, and etc.. That you can use to control your devices. VPN is the way to do it securely.
                                          https://www.home-assistant.io/docs/configuration/remote/
                                          "Just putting a port up is not secure. "
                                          They recommend using ssl - but that still leaves it exposed.. From a security point of view you should setup vpn on your phone to your pfsense box.. Then you can access your remote assistant through the vpn.. This does not expose it to the public internet and anyone hitting that port.
                                          wgstarksW 2 Replies Last reply Reply Quote 0
                                          • wgstarksW Offline
                                            wgstarks @johnpoz
                                            They do have a paid service for this but I would rather connect manually (turn the vpn on/off) and save the money if I can't find anyway to keep the vpn active.
                                            Box: SG-4200
