    OpenVPN recommended Data Encryption Algorithms when using SG-2100 appliance's crypto engine?
    cryptographicsg2100openvpnsmidencryption
    23 Posts 6 Posters 8.2k Views 6 Watching
    • JonathanLeeJ Offline
      JonathanLee
      Hello fellow Netgate community,
      Can you please help?
      I am working on OpenVPN in pfSense. I used OpenVPN in our cybersecurity class in the past, and I thought why not test it out on pfSense for accessing my NAS as it worked great in class labs.
      Everything is working as expected, I thought maybe my 2100 can be more secure as it has that built in crypto chip on it. I followed a nice guide online to help me configure it.
      This setting is what I want to check in on. What is recommended for Data Encryption when using OpenVPN to access a private NAS?
      I can access everything I need right now however I want to utilize the Netgate SG-2100's Hardware crypto chip to start using the SMID instruction set to its fullest extent for security.
      I am currently using OpenVPN to access my NAS remotely it works great.
      What's recommended here to make it more secure?
      Keep in mind I want to use the Hardware Crypto, I do not want to avoid it as it is part of the 2100.
      Make sure to upvote
        mcury Rebel Alliance @JonathanLee
        @JonathanLee I'm not sure if the SG-2100 uses the same chip for that purpose as the SG-3100.
        But, if that is the case, read here: https://forum.netgate.com/topic/171261/openvpn-and-sg-3100-crypto-support/11
          JonathanLee @mcury
          @mcury my OpenVPN lists the chip so it sees it, does your Sever profile list it too on the 3100?
          Make sure to upvote
            @JonathanLee said in OpenVPN recommended Data Encryption Algorithms when using SG-2100 appliance's crypto engine?:
            Unfortunately I don't have the SG-3100 anymore.. Sold it to a friend who is loving it, that integrated switch is really nice and I miss that .. :)
            Here you can read more details about it:
            https://docs.netgate.com/pfsense/en/latest/config/advanced-misc.html#cryptographic-thermal-hardware
            It seems that it will use it automatically if it is supported, no need to select anything.
              JonathanLee
              https://forums.openvpn.net/viewtopic.php?p=119900
              I posted here also to see what OpenVPN community says about the chips
              ๐Ÿ“จ
              Make sure to upvote
                jrey
                @JonathanLee
                I got the impression from the discussion that was had here:
                https://forum.netgate.com/topic/184893/resolved-the-command-usr-local-sbin-ping-auth-s-etc-thoth-thothid-2-dev-null-returned-exit-code-127-the-output-was/49?_=1704212012655
                and specifically
                @stephenw10 said in Resolved: The command '/usr/local/sbin/ping-auth -s > /etc/thoth/thothid 2>/dev/null' returned exit code '127', the output was '':
                It is not. The current 2100s do not include it.
                that the newer (2100's) don't have the chip anymore and that "they" would prefer it just not be used. Hence the issue you saw when you installed to a fresh SSD the install didn't include "stuff".
                I have no background in the choice they made in this regard, but it likely boils down to simply a choice of don't support the chip even if the device has one. or dev speak support 1 code path, not 2.
                Did you ever get a comment on the redmine you opened?
                JonathanLeeJ 2 Replies Last reply Reply Quote 0
                  JonathanLee @jrey
                  @jrey My 2100 has it and in OpenVPN it sees it, the comments on the redmine is that the application that can read the chip id is no longer supported in 23.09 so they are going to remove the GUI window for it in future releases. Again my 2100 was purchased with it and it seems to be functional in that regard so I am a bit confused. Maybe going forward all 2100s will not support it.
                  Make sure to upvote
                    JonathanLee @jrey
                    @jrey haha didn't include "stuff"
                    Well it does after we fixed the missing file
                    Make sure to upvote
                      jrey @JonathanLee
                      Yes, but i'd be betting that if this ^ "stuff" was removed this round, eventually so will support for the chip for those of us (you, me and others that still have the chip) vs. the newer 2100's that don't have it.
                      Certainly OpenVPN can see it now and the problem of it not being supported at all can be pushed down the road. (maybe even past the life of the equipment) That's all.
                      However, if they "wanted" the GUI to display the ID, the logic could have been added to "you Have one = display it" , "Not there = don't" but the choice was made to simply remove it for all fresh installs. Always step one in eventual feature removal.
                        JonathanLee @jrey
                        @jrey 23.09.01 does not see it in OpenVPN but it does see it in the menus and advance configuration, 23.05.01 listed it in openVPN
                        Make sure to upvote
                        • jimpJ Offline
                          FYI- The "thoth" chip on the 1100/2100 is not associated with cryprographic acceleration, it's for other operations such as authentication. Not quite the same as a TPM but closer to that than an accelerator.
                          The accelerator on the 2100 is SafeXcel.
                          DCO only supports ChaCha and AES-GCM, and the only one of those that the SafeXcel chip accelerates is AES-GCM, so remove ChaCha from the list on the server and it should be OK.
                          Though you may be better off disabling SafeXcel and enabling the newer IPsec-MB acceleration since (a) in most cases it's faster than crypto accelerator chips, and (b) it can accelerate both AES-GCM and ChaCha so you aren't limited in algorithm choices. Despite the name, IPsec-MB also accelerates OpenVPN DCO and WireGuard. See https://docs.netgate.com/pfsense/en/latest/hardware/cryptographic-accelerators.html#supported-devices
                          You can change that under System > Advanced on the Misc tab, enable IPsec-MB and disable SafeXcel and then reboot.
                          Do not Chat/PM for help!
                          M JonathanLeeJ 2 Replies Last reply Reply Quote 2
                            michmoor LAYER 8 Rebel Alliance @jimp
                            @jimp
                            curious for platforms that support QAT which is better? To enable IPsec-MB or to rely on QAT?
                            Im running an ovpn client privacy vpn and with DCO enabled im getting great speeds but i noticed wireguard has the edge in performance.
                            Wireless: Unifi, Aruba IAP
                            JNCIP,CCNP Enterprise
                            jimpJ 1 Reply Last reply Reply Quote 1
                            • jimpJ Offline
                              jimp Rebel Alliance Developer Netgate @michmoor
                              @michmoor said in OpenVPN recommended Data Encryption Algorithms when using SG-2100 appliance's crypto engine?:
                              @jimp
                              I don't have any exact results handy (they may be posted on the shop somewhere) but in many cases IPsec-MB meets/exceeds the speed of QAT. There are some hints in the docs about using both together.
                              https://docs.netgate.com/pfsense/en/latest/hardware/cryptographic-accelerators.html#crypto-accel-tune-ipsec-mb
                                @jimp
                                Ahh gotcha. Whats interesting is that IPsec MB works with chacha20.
                                In my use case it makes sense to actually enable MB as i get the best of both worlds - Support for both types of encryption (GCM/chacha) and the implicit support of WireGuard which QAT doesnt support (yet?!).
                                I need to do more testing but this is interesting.
                                For what its worth im testing on a 6100
                                • jimpJ Offline
                                  @michmoor There are some newer QAT devices that support ChaCha but IIRC they are not yet widely available and even if they were, I don't think FreeBSD has drivers for them yet. But since IPsec-MB performs so well (and it really flies on the CPU in the 4200 with AVX2), there are even less reasons to lean on hardware QAT in the future for these sorts of roles.
                                  But the hardware is always evolving, we try to keep on top of whatever is best as new things develop.
                                  JonathanLeeJ M 3 Replies Last reply Reply Quote 1
                                    JonathanLee @jimp
                                    @jimp I still can't get vmstat to show anything for OpenVPN on the SafeXcel chip use with IPsec-MB enabled, disabled ChaCha removed, added, DOC enabled, disabled, it shows this ID error.
                                    Is there something I am doing wrong? I think you told me it should be automatically used but its showing nothing for use and this ID error when I connect. I created a different post for that as that is issues not related to this post.
                                    dco_update_peer_stat: invalid peer ID 1 returned by kernel
                                    https://forum.netgate.com/topic/185411/23-09-01-hardware-crypto-showing-no-hardware-crypto-acceleration-for-system-with-crypto-chip-installed/
                                    I understand that it is automagic now but it still is having issues for my 2100 in 23.09.01
                                    Make sure to upvote
                                      @jimp
                                      Ive loaded IPsec MB, fresh reboot, and so far its about the same with QAT. Doesnt hurt to keep it enabled so i'll leave it.
                                      We know that DCO takes the load off the CPU but i just want to share my monitoring graph. Can you tell when DCO was enabled? haha
                                        @jimp
                                        Internet line is 500/500 but ATT Fiber does over-provision.
                                        Here are the wireguard results with IPsec MB
                                        Im not complaining.
                                        • jimpJ Offline
                                          jimp Rebel Alliance Developer Netgate @JonathanLee
                                          ARM is not like x86, not everything shows up like interrupts, IIRC there is no visible way to tell that SafeXcel is being used except by secondary observations (e.g. improved encryption throughput when enabled vs disabled or lower CPU usage when enabled vs disabled).
                                          I'd keep that discussion going on your other thread since it's more relevant there. But if you can pass traffic, the error is probably not harmful. And you'll need to run performance tests with it enabled/disabled and measure at least CPU usage and throughput when testing. But again, do all that and post it in the other thread.
                                          JonathanLeeJ 1 Reply Last reply Reply Quote 2
                                            JonathanLee @jimp
                                            @jimp thanks I got it to show logs I posted everything in the other forum.
                                            Have a good one
                                            Make sure to upvote
