How to get (strong)VPN thrue fire wall ? (I will pay for remote help (100 $))
I have read several post about this topic.
http://www.ibvpn.com/billing/knowledgebase/63/OpenVPN-setup-on-pfSense-firewall.html
https://forum.pfsense.org/index.php?topic=29944.0
https://forum.pfsense.org/index.php?topic=76015.0
http://www.reddit.com/r/PFSENSE/comments/1zqiwr/how_do_i_route_some_traffic_through_a_vpn/
http://swimminginthought.com/pfsense-routing-traffic-strongvpn-openvpn/
Step 10:
navigate to the system dropdown menus Status –-> System Logs, and click on the OpenVPN tab.
if the last thing you see in this log is "Initialization Sequence Completed" you are connected to StrongVPN; but, you are not done yet, as none of your traffic is traversing this line.This i achieve. I am able to set up the VPN connection. The VPN connection gets an ip adress. But i am not able to get any traffic thrue it.
I need some help. Or perhaps there is a new tutorial i have not yet found. Thx in advance.
The last reference of yours http://swimminginthought.com/pfsense-routing-traffic-strongvpn-openvpn/ has some reasonable stuff from its step 10.
"go to Interface –> Assign and hit the “+” sign and you’ll add a new interface (probably called OPT1 with a pull down box next to it. Select the OpenVPN connection." - that makes an interface that heads down the OpenVPN link.
Step 11, rename the interface for convenience.
Step 12 - changing to Manual Outbound NAT - should not be required, the system should automatically generate the outbound NAT rules for an interface like this (I think there was an old bug in the Automatic NAT rule generation, but that is fixed in current releases, e.g. 2.1.5)
Step 13 - edit the rule on LAN (or make new rule/s on LAN) specifying traffic to match and push down the OpenVPN link - good stufNow go to the the WAN Tab and create the same rule. (Weird,while it doesn’t make sense, if this rule is missing, it didn’t work for me.)
Don't do that - no need for opening up random stuff on WAN!
Step 14 and 15 - putting pass all rules on StrongVPN and OpenVPN tabs - again you should not need this if all your connections are outbound from LAN devices. The stateful firewall will allow the reply packets back in already. It would only be if you are port-forwarding in to a web server or something like that that you need to open some specific things there. -
Thx you very much your reply. I will let you know how it works out.
If i read your pointers correctly i only have to add the fire wall rule in the lan section and add the interface.
I did this in the main screen i get my vpn interface with a green arrow and a ip adress. But i have have no more internet acces.
My rule looks exactly like this
Is there any thing i should have done extra or have not read correctly in your post ? Thx for your effort.
Maybe you do need something in Manual Outbound NAT - turn that on and see if it shows some rules for the OpenVPN interface.
From your loss of internet, it sounds like LAN packets are going somewhere other than WAN (hopefully down OpenVPN tunnel!).
One reason they would get no reply is if NAT was not happening on the way out (the public server/s you are accessing would receive connects with a source IP being still your private LAN IP, so they cannot deliver the reply back). -
I see no rules for the openVPN. Could you tell me what rules i should apply or copy from tutorial ?
You should not need rules on OpenVPN. Your connections are originating on LAN, once they start from LAN, the state will allow reply packets to pass back in on OpenVPN.
These are my settings it is not yet working out. Does any one see what is wrong with them ?
Can you post a screenshot of your LAN firewall rules and StrongVPN rules?
I found that I did need to add a pass rule for traffic arriving on the strongvpn interface (well, PIA vpn, in my case). While your explanation about why it shouldn't be need sounds reasonable, I assumed it was related to UDP being stateless. Remember what Yogi said about theory and practice ….
Thx for your reply i will post info in a few hours.
I hope this enough info to take the problem. Thx in advance.
![NAT Outbound.PNG](/public/imported_attachments/1/NAT Outbound.PNG)
![NAT Outbound.PNG_thumb](/public/imported_attachments/1/NAT Outbound.PNG_thumb)
You need to move your last LAN rule up to the top. Rules are matched from the top down, and the first rule that matches is the only one carried out (see the 'hint' at the bottom of the page). So right now your "Default LAN to any" rule is seen first and packets go out by the default GW from the routing table; nothing gets down to your strongvpn rule to be sent out by the strongvpn gateway.
Note if you only want some of your LAN clients to pass through the VPN, you can make an alias such as 'strongVPN_clients', and enter their IPs. Then use that alias for the source in your vpn pass rule.
Thx i am most definitely going to follow your advice. I will let you know how it works out.
Even if i put the lan rule first i can not connect to web pages. All connection are up and have an ip adress.
Sorry, no idea. Is there nothing suspicious in the logs?
There probably is. But my knowledge is limited….
Perhaps there is some one who wants to take a look at it remote, message me. Ofcourse i will pay you for effort. Somebody with skills should be able to make this work in 20 min or so.
I will pay you via payal, bitcoin what ever you want. I really want to have this problem solved.
This is probably an obvious question, but have you set the routing between your two LANs correctly? Your VPN connection could be up but if your hosts at either end don't know which way to route traffic to one another then you won't be able to communicate between the two points.
As a test, try pinging a host at one end of the VPN tunnel from a host at the other end. If they don't ping, try adding a route to each host to point back to each others' networks. For instance, if you have a network at site A with address range 192.168.1.0/24 and a network at site B with address range 10.10.1.0/24, with your pfsense firewalls at either end having addresses 192.168.1.1 and 10.10.1.1 respectively, you'll need to type something like 'route add -net 10.10.1.0/24 gw 192.168.1.1 metric 1' at the host in the 192.168.1.0 network, and 'route add -net 192.168.1.0/24 gw 10.10.1.1 metric 1' at the host in the 10.10.1.0 network.
Re-run the ping test if it failed the first time and see if that solves the issue.
I am just a client trying to connect to StrongVPN. I am not connecting 2 lan's.
Sorry if i understand you completely wrong.
Apologies - I should have read the previous posts more closely.
