    Wifi and LAN on same subnet (SOLVED)
    45 Posts 4 Posters 30.4k Views
      Rickinfl
      SOLVED:  Here is the solution so you don't have to read all the pages:
      Got to give the Credit to "Derelict" for getting this working!  Thanks!!!
      This is to setup a WiFi card on the same subnet
      Here are the Steps. (After you get a pfsense box up and running, connected to the internet.)
      (I setup my LAN to 10.10.0.99 before I started this so when I got done my gateway would be 10.10.0.1) Remember after changing LAN IP you'll need to
      change your browser address to get back in on webConfigurator.
      (I renamed Opt1 and Opt2 You don't have too)
      1. Shut down install WiFi card (Card is on the recommended list of cards that work with Pfsense)
      2. Interfaces > Added WiFi card (Opt1) renamed it to WiFi. > Setup WiFi settings.
      3. Interfaces > WiFi > Allow intra-BSS communication > Check Box. < For WiFi devices to talk to each other
      4. Interfaces > Assign > Bridges > Created a Bridge > Renamed it to Bridge > Selected LAN and WiFi
      5. Interfaces > Added new Interface > Opt2 > Renamed to Bridge > Network Port = Bridge > IPv4 Configuration Type = Static IPv4 > IPv4 address = 10.10.0.1/24
      6. Services > DHCP Server > Turned on DHCP for Bridge > Enabled > Set Range. (No DHCP on LAN or WiFi)
      7. Firewall > Rules > Added New Rule > Interface > LAN > Source = Bridge Net > Protocol = ANY > Rest set to ANY.
      8. Firewall > Rules > Added New Rule > Interface > WiFi > Source = Bridge Net > Protocol = ANY > Rest set to ANY.
      9. Firewall > Rules > Added New Rule > Interface > Bridge > Source = Bridge Net > Protocol = ANY > Rest set to ANY.
      10. Interfaces > LAN > IPv4 Configuration Type = None  > IPv6 Configuration Type = None
      11. Interfaces > WiFi > IPv4 Configuration Type = None  > IPv6 Configuration Type = None
      My Configuration:
      Old:
      WAN > DHCP
      LAN > 10.10.0.99 >( Changed from .1 to .99 so when I finished it would be 10.10.0.1) > (Bridge becomes 10.10.0.1)
      New:
      WAN > DHCP
      LAN >
      WiFi >
      Bridge > 10.10.0.1> DHCP
      Again Thanks Derelict.
      I need some help with this… First I know I need a Bridge. That's not an issue.
      My Setup.
      Pfsense
      WAN = DHCP from provider
      LAN = Static 10.10.0.1
      WiFi = Static 10.10.0.2
      Opt2 - Static 10.10.0.3
      1. I created new Interface Opt2
      2. Activated Opt2 and Setup the IP address for Opt2
      3. Created DHCP on Opt2
      4. Created a Bridge
      5. I edited Bridges and selected LAN and WiFi
      6. Made sure DHCP was Deactivated on LAN and WiFi
      7. Added Firewall Rule = Source = Bridge Net and the rest was Any
      8. Under Interfaces I made sure Opt2 network port Bridge was selected
      9. Under System Tuneables I set net.link.bridge.pfil_member> 0
      I can connect via WiFi and get an IP address with no problem. But that's about it.
      DHCP gave me and IP address of 10.10.0.41, But I can't ping anything and says my gateway is 10.10.0.3
      Anyone got any suggestions why this doesn't work? Or did I miss something?
      Thanks,
      Rick
      • DerelictD Offline
        Derelict LAYER 8 Netgate
        All of your interfaces are on the same subnet.
        Remove the IP addresses from the bridge member interfaces.
        You will then need to set one interface address on BRIDGE0 instead.
        You will need pass any any any rules on the bridge members and normal LAN rules on BRIDGE0.
        Why are you messing with OPT2?  Do you want it to be a member of the bridge too?
        It looks like you want two interfaces.  BRIDGE0 (members LAN and WiFi) and OPT2.  If that's not the case please be more specific.
        Or are you trying to make your BRIDGE0 named OPT2?
        Chattanooga, Tennessee, USA
          Rickinfl
          I've done that and I can't access the web gui on the pfsense box.
            Rickinfl
            I had it setup like this:
            LAN = NONE
            WiFi = NONE
            Opt2 = 10.10.0.3
            Under bridge I Linked it to LAN and WIFI.
            I ended up locking myself out and still couldn't ping pfsense box. I was still able to connect to WiFi but go nowhere.
            • DerelictD Offline
              Done what?
              You will need pass any any any rules on the bridge members and normal LAN rules on OPT2 (assigned to BRIDGE0).
              You lose the benefit of the auto lockout rule when you stray from the normal LAN so you'll need to figure out how to add the right rules.
              Create a bridge containing only WiFi as a member.  Make sure it has all the rules you need.  See if you can get at pfSense over Wi-Fi, then add LAN to the bridge and make sure it has all the right rules.
              If you have another interface make it management and plug into it to make changed to the LAN bridge.
              Something.
                Rickinfl
                Sorry kind of new to this.
                You will need pass any any any rules on the bridge members and normal LAN rules on BRIDGE0. > Not sure what you're asking me to setup here.
                Why are you messing with OPT2?  Do you want it to be a member of the bridge too? > Do I need to edit the bridge and add Opt2 so then LAN, WIFI, and Opt2 will be attached to the Bridge0?
                  Rickinfl
                  Here are some of my settings
                  ![Assign network ports.png](/public/imported_attachments/1/Assign network ports.png)
                  ![Assign network ports.png_thumb](/public/imported_attachments/1/Assign network ports.png_thumb)
                  Bridge.png_thumb
                  DHCP1.png_thumb
                  Rules.png_thumb
                    Rickinfl
                    Other settings
                    LAN.png_thumb
                    Opt2.png_thumb
                    Wifi.png_thumb
                    • DerelictD Offline
                      @Rickinfl:
                      If that's what you want, yes.
                      In a bridge there are two sets of firewall rules that dictate what traffic can pass into the bridge.  First is on the bridge members themselves.  These are typically pass any any any.
                      Second is on the bridge itself.  This is the actual bridge interface that gets assigned an IP address, runs DHCP, etc.  These rules are just like the rules on a typical LAN interface.
                      • DerelictD Offline
                        I think you want to remove OPT2 from the bridge membership.  OPT2 is a bridge interface consisting of LAN and WIFI.
                          Rickinfl
                          Well I'm a little confused now since you asked me about Opt2.  I got the information from a post on here and followed it.  Question I have no is do I need Opt2?
                          Here is what this guy posted and I followed. Maybe this is wrong?
                          Finaly i got it working but it was a hard peace of trail and error.
                          1. create a new interface -> Opt2
                          2. Setup the interface IP for Opt2 (interfaces ->Opt2) and change the name if you want
                          3. Setup the DHCP Server for Opt2
                          4. Create a "Source=Bridge subnet; rest=any" Firewall rule for Opt2
                          5. create a bridge: Interfaces -> Bridges, and select LAN and Wifi
                          6. Select the Bridge as "Network port" for Opt2; Interfaces-> asign
                          7. Deactivate the DHCP server of LAN and Wifi
                          8. Set the Type of LAN and Wifi to "None"
                          Now your LAN and Wifi clients should get an IP from the DHCP server configured for Opt2 and these clients should be able to access the internet.
                          But they are currently not able to access each other WLAN <-> LAN.
                          So solve that i added two rules for the Firewall:
                          1. LAN: Source=Bridge subnet; rest = any
                          2. WLAB: Source= Bridge subnet; rest=any
                          Instead of adding these two rules you can also change the value at : System -> Advanced -> System tuneables -> net.link.bridge.pfil_member->  "0"
                          At that point my clients where able to ping each other and also wake up on lan from my tablet to a PC was working.
                          If you have any hints what i can do better on my configuration feel free to let me know.
                          « Last Edit: May 21, 2012, 04:28:12 pm by nimanic »
                          • DerelictD Offline
                            You selected LAN, WIFI, and OPT2, not LAN and WIFI.
                            Change that and if you did everything else it should work.
                              Rickinfl
                              Still not working.
                              UpdatedBridge.png_thumb
                                Rickinfl
                                This is a fresh Install of Pfsense. I've connected to it so it has internet access.
                                Maybe if someone could give me the instructions on how to do this from start.
                                Here is all I want.
                                Pfsense on 10.10.0.1
                                Wifi on 10.10.0.2
                                Pretty simple. I must have gotten something messed up.
                                • DerelictD Offline
                                  The instructions you already posted look pretty good.
                                  Typical debugging should probably be done.
                                  Do you get DHCP on the WIFI port?  On the LAN port?
                                  Can you ping the OPT2 address from the WIFI port?  From the LAN port?
                                  Can you ping the next hop gateway from the WIFI port?  From the LAN port?
                                  Can the Hosts on LAN ping the hosts on WIFI?  Vice versa?
                                  What DNS is being handed out to the DHCP clients?  Is that the DNS server actually in use by the clients? Can you resolve names using that address?
                                  Etc.
                                    Guest
                                    I am of the mind that things could be done easier in pfSense for the creation of bridges and wireless access points. I have considered requesting forum help for a wireless setup wizard -using something like what pfSense includes now at initial setup in WebConfigurator. I know everybody hates wizards but pfsense setup wizard is easy enough to click thru. I would like to see enhanced functionality with it. Is this something that seems logical to  anyone else? I hate doing the cable swap for bridge creation but it works..
                                    A suggestion for help is disable firewall from Advanced Settings on the Menu. It will prevent lockout until you figure it out what is what. And  i know i hate  re-imaging my  CF card -so i do the restore last backup from console - to save time on lockouts when i was  learning. pfsense  automatically saves backups at each settings change it seems. Very convenient.
                                      Rickinfl
                                      Yes I'll have to do some debugging. Just keep cutting myself out.
                                      Do you get DHCP on the WIFI port?  On the LAN port? WiFi yes. Not sure about LAN since I static those.
                                      Can you ping the OPT2 address from the WIFI port?  From the LAN port? I can't ping anything but the wifi device I'm testing with
                                      Can you ping the next hop gateway from the WIFI port?  From the LAN port? No same as above.
                                      Can the Hosts on LAN ping the hosts on WIFI?  Vice versa? No. It's like the bridge blocks everything and isolates the wifi.
                                      What DNS is being handed out to the DHCP clients?  Is that the DNS server actually in use by the clients? Can you resolve names using that address? Even static with DNS still doesn't work.
                                      I'm going to have to do more research on this and try and break it down piece by piece and see what's going on. I've been driving myself crazy trying to figure this out. I know on paper its right and I drew it out many times then applied it.
                                      Just strange.
                                      Thanks for all your time and help.
                                      Rick
                                      • DerelictD Offline
                                        What firewall rules are on LAN and WIFI?
                                        Does anyone know for sure that the xl driver still works?
                                        Can you try?  If you can get DHCP (and have ARP, etc) then it's not a layer2 problem and we really need to look at rules.
                                          Rickinfl
                                          Wow… Someone really needs to document how to do this!  Need Documentation on Normal setup of WiFi and then WiFi on the Same Subnet.
                                          I've been researching this for almost 2 weeks now and I'm really tied of trying to get this to work.
                                          I have read every post I could find on this. I've watched every Youtube Video and Even the one on Pfsense Site...  The problem is NOT 2 of any of the documentation is the same. Seems everyone does it different, but none of it works.
                                          Really wish someone could post how to do this that's done it already.  :(
                                          • DerelictD Offline
                                            It's just not that difficult.  Bridging works fine.
                                            The instructions you have already posted cover everything you need to do.
                                            If it doesn't work you need to be able to troubleshoot it to find out what was done incorrectly or where the problem otherwise lies.
