    What does "Left Column Labels" (System > General) do?
    11 Posts 4 Posters 3.9k Views 1 Watching
    • luckman212L Offline
      luckman212 LAYER 8
      Sorry for being dense but I cannot figure out what this option does?
        NOYB
        It does exactly what that description says.
        If that check box is checked, the left column labels are made active (link to that group).  Thus if clicked the first item of that group will be selected or toggled (depending on the type of form item).
        To see it, enable that, then click one of the labels in the left column.
        The main purpose behind this setting is because the left column is a very natural place for thumb scrolling on touch screen devices and thus results in unintended inadvertent config changes when the left column items are "active" (links).
          luckman212 LAYER 8
          Thanks for trying to explain – I must be having a bad day or something because I still for the life of me can't see any difference between having this "on" or "off".  I have tried 2 different mobile browsers (chrome + safari) and it looks and acts the same for me regardless of what the setting is.  Can you give me a specific example of somewhere I can tap or click where I would notice a difference? Sorry to be a P.I.T.A.
            NOYB
            Visually there will be no difference.
            1. Enable the feature by checking the box and saving.
            2. Click the "Left Column Labels" in the left column.
            The "Active" check box should state should toggle.
              luckman212 LAYER 8
              I give up.  No idea what this does still.  Can't see any difference.
              @NOYB:
              :-\ :-[ ::) ??? :o
              Maybe it's just not my day.
                NOYB
                Unless you want to be able to click the labels in the left column to toggle or select the form items then just leave it off.
                The only reason to enable it is for that.  There is no visual difference, only the behavior of clicking the labels in the left column.
                  luckman212 LAYER 8
                  Toggle what form items exactly?
                  I understand what you're saying, there there's no "visual" difference.  But for me I am not seeing any "functional" difference either between having this on or off.  Either way, for me I have to click once to expand the section, and then click again on one of the items beneath it to navigate to that page.  Nothing is selected/toggled/activated/etc simply by tapping on the left nav top sections.
                    NOYB
                    @luckman212:
                    The form items on configuration pages such as System / General Setup.
                    Where did I say anything about left nav top sections?
                    Think you are over thinking it.
                    1. Navigate to System / General Setup.
                    2. Scroll to bottom of the page.
                      (this is where you took that snapshot from so I know you can at least get this far)  ;)
                    3. Put a check mark in the that check box.  The one labeled "Active" in the "Left Column Labels" section.
                    4. Click the "Save" button at the bottom of the page.
                    5. Navigate to System / General Setup.
                    6. Scroll to the bottom of the page.
                    7. There should be a check mark in that check box.  The one labeled "Active" in the "Left Column Labels" section.
                      8 ) In the left-hand column where is says "Left Column Labels", click on that text.
                    8. The check mark in that check box should toggle (on/off).
                    9. Clicking other labels in the left-hand column will toggle or select the first item of it's group.
                    If you can't follow that then I can't help you.
                      luckman212 LAYER 8
                      Oh my GOD
                      I get it now.
                      Am I the only one that was confused by what this did?
                      Anyway, thanks for spelling it out for me so I finally get what we are talking about here
                        Sensiva
                        @luckman212:
                        Oh my GOD
                        I get it now.
                        Me too buddy.. thanks for seeking the truth :D
                        Thanks for those who spent the time and effort to explain it so we can sleep at night.
                        Happy pfsensing  ;)
                          msswift
                          Definitely not the only one. The language is poor. "Heading Labels" or "Option Heading Labels" would be a much clearer way to describe this option than "Left Column Labels."
                          Why?
                          (1) "Left Column Labels" implies there are "Right Column Labels" and maybe "Center Column Labels." One of multiple kinds of labels, in any case, for sure. Which in fact there are not. There is one kind of label, which happens to be typeset flush left. All the qualification "Left Column" does is mislead, creating the false idea of other kinds of labels from which these are distinguished. The reader wondering what labels are referred to will be looking for an object having a "left column" instance as well as other instances.
                          (2) Four options up on the "General Setup" screen is the option "Dashboard Columns" to select the number of visual layout columns for the dashboard web page. "Column" here is the commonly-known typesetting and visual layout term, used for both print and visual layout on web pages, in advertising, and so on. A two-column design, a one-column ad, columns gutters margins, etc. A reader who is carefully looking down the setup page will have this idea of what a column is when they get to "Left Column Labels" below. This time, however, "column" is a technical term referring to an HTML implementation of a visual Label or Heading. It's not a visual column, it's a programming strategy to implement a visual flush-left heading label (flush-left within a single layout "column"). Even readers very familiar with columns as a low-level typesetting implementation (e.g., HTML, LaTeX) can miss the fact that the meaning of "column" has changed.
