    Latest Snort Upgrade error in library engine
    30 Posts 12 Posters 10.7k Views 1 Watching
    • morrealeM Offline
      morreale
      not running the nanobsd version.
      i will remove all remnants and try again.
      thanks for the help
      Release: pfSense 2.3.4 p1(amd64)
      M/B: Supermicro A1SRi-2758F-O
      SSD: 128GB
      RAM: 2x8Gb Kingston 1600MHz DDR3L PC3-12800 ECC
      AP: Cisco
      • morrealeM Offline
        morreale
        @bmeeks:
        Or for an even more radical approach, remove the Snort package again, open a shell command line session and delete all the snort directories you see in /usr/local/lib, then reinstall Snort.
        Bill
        did this.  i like clean :)
        now working again.  thanks Bill
        SSD: 128GB
        AP: Cisco
        • bmeeksB Offline
          bmeeks
          @morreale:
          @bmeeks:
          Bill
          Great!  Thanks for the feedback.  Not sure why those directories did not get cleaned on the remove and reinstall, though.  That is supposed to happen.
          Bill
          • F Offline
            freebs
            Thanks to this thread I was able to get snort working again, but I stall can't get VRT rules or community rules to update at all or even openAppID rules for that matter only ET rules.
            here is a pastebin of the log..  http://pastebin.com/uG6akM28
            Disable SSL Peer is checked… i've also regenerated a new Oinkmaster Code with no good results.
            snort ver. 3.2.9.1_14  snort -2.9.8.3 and barnyard2-1.13 installed
            Any help appreciated!
            • F Offline
              freebs
              omg.. never mind.. it was the dnsbl in pfBlocker that was causing my issue…  now i feel stupid.. pffft!
                kidalabama
                Aug 9 20:37:15 php-fpm 23902 /snort/snort_interfaces.php: The command '/usr/local/bin/snort -R 11181 -D -l /var/log/snort/snort_em011181 –pid-path /var/run --nolock-pidfile -G 11181 -c /usr/local/etc/snort/snort_11181_em0/snort.conf -i em0' returned exit code '1', the output was ''
                Aug 9 20:37:15 snort 26537 FATAL ERROR: The dynamic detection library "/usr/local/lib/snort_dynamicrules/server-webapp.so" version 1.0 compiled with dynamic engine library version 2.4 isn't compatible with the current dynamic engine library "/usr/local/lib/snort_dynamicengine/libsf_engine.so" version 2.6.
                2.3.2-RELEASE (amd64)
                built on Tue Jul 19 12:44:43 CDT 2016
                FreeBSD 10.3-RELEASE-p5
                  kidalabama
                  i have solved problem.
                  remove interface and add wan interface after.
                    humps
                    @bmeeks:
                    Try completely removing the Snort package and then install it again.  If you have "save settings" checked on the GLOBAL SETTINGS tab, you won't lose any configuration.
                    Bill
                    Just upgraded to PfSense 2.3.2 with snort-2.9.8.3 and experienced this issue… worked like a charm thanks much.
                      mukpfsense
                      I am still having this issue. I have tried ALL tips from the Interwebs. No luck.
                      Any more tips?
                        DmitryS @mukpfsense
                        It helped me:
                        ln -s /usr/lib64/libdnet.so.1.0.1 /usr/lib64/libdnet.1
