    Peer to Peer (SSL/TLS) - tap - LAN Bridge - Routing issue
    3 Posts 2 Posters 1.9k Views
    • L Offline
      LeoLinux
      I'm trying to setup a Peer to Peer (SSL/TLS) (tap) connection between two sites through the internet. The tunnel is connected and seems to operate from my point of view. Unfortunately the routes don't seem to operate at all. On both sites, the relevant OpenVPN interface is correctly bridged with the LAN interface. When I turn on the DHCP client for these interfaces, both get a valid IP from the corresponding site, which proves the tunnel is up and running accordingly. a ping from each pfSense shell also proves that the corresponding site is there and reachable. But this works only from pfSense locally - not from any host connected to it. Setting the IPv4 on each OpenVPN interface individually breaks it - only DHCP seems to work and setup at least the route to the pfSense on the other site.
      Site A (OpenVPN Peer to Peer Server):
      WAN: 192.168.49.100/24
      LAN: 192.168.50.1/24 (DHCP running for this net)
      Site B (OpenVPN Peer to Peer Client):
      WAN: 192.168.9.100/24
      LAN: 192.168.10.1/24 (DHCP running for this net)
      ================ Site A (Server) ================
      dev ovpns1
      verb 3
      dev-type tap
      dev-node /dev/tap1
      writepid /var/run/openvpn_server1.pid
      #user nobody
      #group nobody
      script-security 3
      daemon
      keepalive 10 60
      ping-timer-rem
      persist-tun
      persist-key
      proto udp
      cipher AES-256-CBC
      auth RSA-SHA512
      local 192.168.49.100
      engine cryptodev
      tls-server
      tls-verify "/usr/local/sbin/ovpn_auth_verify tls 'DOMAIN_TO_SITE_A.TLD' 1"
      lport 1196
      management /var/etc/openvpn/server1.sock unix
      max-clients 2
      push "route 192.168.49.0 255.255.255.0"
      push "route 192.168.50.0 255.255.255.0"
      route 192.168.9.0 255.255.255.0
      route 192.168.10.0 255.255.255.0
      ca /var/etc/openvpn/server1.ca
      cert /var/etc/openvpn/server1.cert
      key /var/etc/openvpn/server1.key
      dh /etc/dh-parameters.4096
      crl-verify /var/etc/openvpn/server1.crl-verify
      tls-auth /var/etc/openvpn/server1.tls-auth 0
      comp-lzo adaptive
      persist-remote-ip
      float
      netstat -nr4
      Routing tables
      Internet:
      Destination        Gateway            Flags      Netif Expire
      default            192.168.49.1       UGS         xn1
      127.0.0.1          link#4             UH          lo0
      192.168.49.0/24    link#6             U           xn1
      192.168.49.1       f0:ba:f0:ba:f0:ba  UHS         xn1
      192.168.49.100     link#6             UHS         lo0
      192.168.50.0/24    link#7             U       bridge0
      192.168.50.1       link#7             UHS         lo0
      192.168.249.0/24   192.168.249.1      UGS      ovpns5
      192.168.249.1      link#8             UHS         lo0
      192.168.249.2      link#8             UH       ovpns
      ================ Site B (Client) ================
      dev ovpnc3
      verb 3
      dev-type tap
      dev-node /dev/tap3
      writepid /var/run/openvpn_client3.pid
      #user nobody
      #group nobody
      script-security 3
      daemon
      keepalive 10 60
      ping-timer-rem
      persist-tun
      persist-key
      proto udp
      cipher AES-256-CBC
      auth RSA-SHA512
      local 192.168.9.100
      engine cryptodev
      tls-client
      client
      lport 0
      management /var/etc/openvpn/client3.sock unix
      remote DOMAIN_TO_SITE_A.TLD 1196
      auth-user-pass /var/etc/openvpn/client3.up
      ca /var/etc/openvpn/client3.ca
      cert /var/etc/openvpn/client3.cert
      key /var/etc/openvpn/client3.key
      tls-auth /var/etc/openvpn/client3.tls-auth 1
      comp-lzo adaptive
      resolv-retry infinite
      auth-nocache
      pull
      ns-cert-type server
      netstat -nr4
      Routing tables
      Internet:
      default            192.168.9.1        UGS         xn1
      192.168.9.0/24     link#6             U           xn1
      192.168.9.100      link#6             UHS         lo0
      192.168.10.0/24    link#7             U       bridge0
      192.168.10.1       link#7             UHS         lo0
      192.168.12.0/24    192.168.12.1       UGS      ovpns2
      192.168.12.1       link#9             UHS         lo0
      192.168.12.2       link#9             UH       ovpns2
      What am I missing, so both sites can communicate with each network behind it? I tried plenty of variations in my setup. To me it seems broken / like a bug somewhere. This is clearly not, how one expects a peer to peer connection.
      Best regards
      Leander
      • L Offline
        LeoLinux
        Any idea whether this might be a bug? Routes should be added accordingly by OpenVPN/pfSense. But it fails completely.
        • jimpJ Offline
          Why are you bridging if the subnets are different?
          You have given the two sides no way to reach each other. There is no tunnel network on the VPN for them to use as a gateway, and they have no subnets in common. Routing requires both sides to have an address in a common subnet. It can't push nor use routes because there is nowhere for them to go.
          Usually in a bridge scenario the LANs are the same subnet.
          From the look of your network layout, you don't need nor want a bridge. You could use tap but there is no advantage in this scenario. Remove the bridge components and follow this to setup the VPN using SSL/TLS like you have started: https://doc.pfsense.org/index.php/OpenVPN_Site-to-Site_PKI_(SSL)
          Do not Chat/PM for help!
