    Policy based routing, multi-WAN and gateway on same subnet
    39 Posts 6 Posters 9.3k Views
      gslongo
      Hi All,
      We are facing to an issue in this particular situation.. We have two gateways on the same subnet 192.168.0.1 and 192.168.0.5. Default gateway on the firewall is 192.168.0.5.
      When creating a rule to route traffic to 192.168.0.1 it is not working. Traceroute show traffic pass through 192.168.0.5.. (and rule is correct).
      When changing, in that rule, for a gateway located into another subnet, traffic is correctly routed (traceroute OK).
      Any idea regarding this issue ?
      Thank you for advance !
        So you have the gateway created.. And then you created a rule to send specific traffic either on source IP, dest IP, port, etc. out a specific gateway.  And this rule is above the rule that would send said traffic out the default gateway.
        Post up your rules showing how your doing your policy routing.
          heper
          What issue? Gateway in the same subnet don't work.
            gslongo
            @heper:
            Do you know why ?
            Johnpoz, when you say "And this rule is above the rule that would send said traffic out the default gateway", what do you mean ? There is no such rule (policy based rule to default gateway)…
            Thanks guys
              do you have any rule that allow traffic above your policy based rule?
              Remember rules are top down, first rule to trigger wins no other rules are looked at.
              So if you have  rule that would allow the traffic and no gateway set, it would use the default gateway and normal routing.  And would never get to the rule that says hey go out this specific gateway.
              Is just easier if your post your rules so we can all see and be on the same page.
              As to using more than 1 gateway on the same network - I am not sure on that.  While its highly uncommon setup.  I have never tried it.. So not sure if pfsense would even let you create multiple gateways on the same network?
              But in general common issue people have with policy routing is placement of rules.  Either they place the policy rule on top and wonder why they can not get to their other local networks, or they have a rule above and wonder why they are not using the policy routing.
                heper
                i haven't tried it myself either, but i've read about it in the past.
                i think its the routes on the WAN interfaces that get messed up.  (the gateways themselfs might not be an issue)
                example:
                192.168.5.0/24	link#2	U	0	1500	vmx1
                192.168.5.3	link#2	UHS	0	16384	lo0
                192.168.5.0/24	link#3	U	0	1500	vmx2
                192.168.5.2	link#3	UHS	0	16384	lo0
                as I see it, both can't be in the routing table at the same time.
                  You can for sure have more specific routes in the table..  But yeah depending you could have an issue in the routing table that prevents such a thing.  I am remote currently, for sure not going to mess with pfsense gateways remotely in such a manner while I am vpn'd in - don't want to disconnect myself and then no way to get back in ;)  Have to give it test once I get home.
                  • DerelictD Offline
                    Derelict LAYER 8 Netgate
                    You might have to put a rule that matches the traffic coming from the routes behind 192.168.0.1 and disable reply-to there in the advanced settings on that rule, else replies will probably be explicitly sent to the gateway set on that interface configuration.
                    Naturally, the router at 192.168.0.1 would have to know to route the correct traffic back to pfSense, and not 192.168.0.5.
                    If you have traffic coming from behind 192.168.0.1, being sent to pfSense, and has to then be routed to 192.168.0.5 you get into hairpinning traffic and should consider a redesign.
                    Chattanooga, Tennessee, USA
                      ^ yeah that could be an issue if your not natting.. But I don't see why pfsense would have an issue with gateways on the same transit.. But sure if this .1 router had a default of .5 on the transit you could have issues as Derelict describes.
                      I think is always easier with a picture.  So from what the OP states we could have something like the below drawing.  Now if we assume no nat and this .1 router has a default gateway of .5 as well then we have a bit of problem if there is not route on the .1 to the 192.168.1 network in my drawing.
                      But such a scenario is common.  So I don't see why pfsense should have an issue with multiple gateways on the same network.
                      So pfsense (bottom router) has its default set to the 192.168.0.5 address.  This is how his clients get to all networks it doesn't have specific routes for.  Doesn't matter if it nats or not..  So if we add a new router into the mix on the transit on how I get to some specific networks.. The 192.168.2 in my drawing.  Pfsense needs to know that to get to 192.168.2 he sends traffic to 192.168.0.1
                      Now this policy route needs to be above a rule that would allow traffic and send it out the default gateway.
                      So pfsense send traffic to .1, he sends it on to the 192.168.2.x box.. That box answers then .1 router needs to send it back to our pfsense.3 in the example.  If we are natting so that traffic looks like it came from .3 we don't have an issue.  But we are not natting, then yes that .1 router needs to know to get to the 192.168.1 he needs to route that traffic to the .3 on the transit.. If he sends it over to .5 even if .5 know to send it to .3 you have a problem.
                      If the 192.168.2 is using some other gateway other than that .1 router you could have problems, etc. etc.
                      To troubleshoot the OP actual problem we could for sure use more info.  But If pfsense can not have more than one gateway in the same transit network then that would be a real serious flaw in its usability wouldn't it… In your typical home user or smb, this would be an uncommon setup to be sure.  But in enterprise transit network with multiple routers is very very common.
                      3routersontransit.jpg_thumb
                      • DerelictD Offline
                        It can deal with it. It's just that an interface with a gateway defined in the interface configuration is considered a WAN and thus all incoming states get reply-to to the WAN gateway (what 99.999% of installations want) so you need to bypass that so reply traffic on those states is routed according to the routing table.
                        So on WAN there you would add pass rules sourced from 192.168.2.0/24 with reply-to disabled on that rule.
                        When dealing with multiple gateways on an inside transit interface you don't run into that because you generally do not configure a gateway on inside interfaces.
                          Great info Derelict..  Yeah I have not actually done this on a pfsense, but I didn't think it would have an issue with it.. Since I know there are many instances of pfsense used in the enterprise with more and more all the time.. Which is fantastic news!!
                          And if something like this could not be done it would be a big issue ;)
                          So its clear - this is the checkbox your talking about right Derelict.
                          disablereplyto.jpg_thumb
                          • DerelictD Offline
                            Roger.
                              makz
                              Hello
                              I'm gslongo's collegue.
                              Here is in attachments a little diagram of what we have.
                              So the user network 10.1.1.0/24 reach internet through the default route -> 192.168.0.5.
                              But we want the Server (10.10.3.50) to reach internet through the second gateway -> 192.168.0.1.
                              I've also attached the rules screen, in this screen you'll find BACKUP SERVERS (Alias for 10.10.3.50), WANGW (Gateway name for 192.168.0.1)
                              In the rule, i've checked "Disable reply-to", the server still use the default route (but i'm not sure if i need to check this box in this rule).
                              Thank you.
                              ![Untitled Diagram (1).png](/public/imported_attachments/1/Untitled Diagram (1).png)
                              ![Untitled Diagram (1).png_thumb](/public/imported_attachments/1/Untitled Diagram (1).png_thumb)
                              ![Screenshot from 2016-12-09 14-06-21.png](/public/imported_attachments/1/Screenshot from 2016-12-09 14-06-21.png)
                              ![Screenshot from 2016-12-09 14-06-21.png_thumb](/public/imported_attachments/1/Screenshot from 2016-12-09 14-06-21.png_thumb)
                                And what interface do you have these rule setup on?  Clearly your backup servers on a different vlan than your users..  You sure your placing the rules on the correct interface.
                                  makz
                                  Yep, differents VLAN
                                  In fact, we have a lot of VLAN the intervlan routing are done by the core switches and we have a vlan named INTERCO
                                  In all vlan, the default gateway are the core switchs.
                                  All core switches have a default route to the pfsense vIP (10.10.8.12).
                                  Like that, pfsense get all packets destinated of internet in his INTERCO interface and the filtering is done on this interface.
                                  My rule is done in INTERCO interface.
                                  I didn't included the core switching part in my diagram to keep it simple.
                                  • DerelictD Offline
                                    Looks like you kept it even simpler by not including a diagram at all.
                                      makz
                                      Hello,
                                      I've included coreswitching part and some more informations on this diagram
                                      As seen in older screenshots, two gateway are configured on WAN interface (192.168.0.1 & 192.168.0.5), my rule "Matching source 10.10.3.50 -> Gateway 192.168.0.1" is done in INTERCO interface and it's on top of the rule list.
                                      Thank you.
                                      ![Screenshot from 2016-12-12 10-19-54.png](/public/imported_attachments/1/Screenshot from 2016-12-12 10-19-54.png)
                                      ![Screenshot from 2016-12-12 10-19-54.png_thumb](/public/imported_attachments/1/Screenshot from 2016-12-12 10-19-54.png_thumb)
                                      ![Untitled Diagram (5).png](/public/imported_attachments/1/Untitled Diagram (5).png)
                                      ![Untitled Diagram (5).png_thumb](/public/imported_attachments/1/Untitled Diagram (5).png_thumb)
                                        makz
                                        Hello,
                                        I'm back with some news !
                                        Today i've configured a little freebsd router to try my setup on a vanilla bsd.
                                        My basic setup work well on this vanilla router.
                                        pass out quick on $int_if route-to ($ext_if 192.168.0.1) inet from $bck_srv
                                        pass in quick on $int_if route-to ($ext_if 192.168.0.1) inet from $bck_srv
                                        Now i know this is not a freebsd issue but more a pfsense issue.
                                        I've read the pf rules generated by pfsense and i saw some hidden rules
                                        pass out  route-to ( lagg0_vlan2000 192.168.0.5 ) from 192.168.0.10 to !192.168.0.0/24 tracker 1000008011 keep state allow-opts label "let out anything from firewall host itself"
                                        pass out  route-to ( lagg0_vlan2000 192.168.0.5 ) from 192.168.0.12 to !192.168.0.0/24 tracker 1000008012 keep state allow-opts label "let out anything from firewall host itself"
                                        I've removed those rules from pf and magic it work !
                                        So,
                                        I saw in the bug tracker, if i place my rule in "Floating rules" this should disable the hidden rule <https: 1823="" redmine.pfsense.org="" issues="">This still won't work … Here is all my "route-to" rules from my non working pf configuration
                                        pfctl -sa | grep route-to
                                        pass out route-to (lagg0_vlan2000 192.168.0.5) inet from 192.168.0.10 to ! 192.168.0.0/24 flags S/SA keep state allow-opts label "let out anything from firewall host itself"
                                        pass out route-to (lagg0_vlan2000 192.168.0.5) inet from 192.168.0.12 to ! 192.168.0.0/24 flags S/SA keep state allow-opts label "let out anything from firewall host itself"
                                        pass out quick on lagg0_vlan1008 route-to (lagg0_vlan2000 192.168.0.1) inet from <backup_servers> to any flags S/SA keep state label "USER_RULE: TEST ROUTING"
                                        pass in quick on lagg0_vlan1008 route-to (lagg0_vlan2000 192.168.0.1) inet from <backup_servers> to any flags S/SA keep state label "USER_RULE: TEST ROUTING"</backup_servers></backup_servers>
                                        I've tried to inverse the rules (my rule before the hidden rule), this still won't work
                                        I've also tried to remove the route-to argument to the hidden rule
                                        pass out  from 192.168.0.10 to !192.168.0.0/24 tracker 1000008011 keep state allow-opts label "let out anything from firewall host itself"
                                        pass out  from 192.168.0.12 to !192.168.0.0/24 tracker 1000008012 keep state allow-opts label "let out anything from firewall host itself"
                                        and this work great !
                                        For now i have some questions …
                                        What is the purpose of this hidden rule ?
                                        Can i disable it permanently ?
                                        Can i just remove the route-to argument permanently ?
                                        Is there any option to bypass this rule for some cases ?
                                        Thank you !
                                        Have a great day.</https:>
                                          gslongo
                                          A bug related to this has been opened here : https://redmine.pfsense.org/issues/7033
                                          Can it be analysed by a developper ?
                                          //EDIT: Also found user having same issue here : https://redmine.pfsense.org/issues/6625
                                          • jimpJ Offline
                                            The floating rules do not "disable" the hidden rule, they override it. When you make your floating rules, be sure to check "quick" and that the rules will match the traffic going to your other gateway. The hidden rules do not have quick, so a quick rule will match and the non-quick rule will never be processed.
                                            Post the exact floating rules you made and it should be fairly easy to tell why they aren't working.
                                            Do not Chat/PM for help!
