    How to block cell phones using SquidGaurd
    5 Posts 2 Posters 1.2k Views
      werner725
      ;D
      Sup pf legends!!!
      Just a quick question on blocking with squid gaurd.
      I have setup squid in non transparent mode severing proxy files using dns forwarder and using generated certs.
      All seems to be working great blocking https websites like a monster!!!
      Issue is when someone wit a Android phone or apple phone joins the network, they can browse any sites!!!
      Any Ideas???
      • KOMK Offline
        KOM
        Put a block on LAN for tcp 80/443 above your Default Allow rule.
          werner725
          Hey!
          Thanks for the reply, i did this works 100% but how is it going to work now with Auto proxy discovery?
          If i want to connect a phone and put it on auto i need to specify proxy.pac file.
          This server is running at a school so to specify the proxy.pac file on 500 devices is going to be rough  :'(
          • KOMK Offline
            KOM
            ??? It's going to work exactly the same.  Perhaps I don't understand your question.
            You need more than just a proxy.pac file.
            WPAD Autoconfigure for Squid
            Android does not support WPAD btw, so those clients will need to manually config the proxy.
            These are all squid/squidguard questions now so you should start a new thread in the Cache/Proxy forum.
              werner725
              ;D
              Thanks will do so!
