    [SOLVED] pfSense SG-1000 lan-interface missing IP with snapshot 20171007
    24 Posts 7 Posters 5.3k Views
      kpa
      Another full reinstall, this time using the config rescue option. No difference, syslogd still spits out the same errors.
      • L Offline
        lololo
        @kpa:
        Same problem… clean install on a vm
        Have you found a solution?
          kpa
          @lololo:
          @kpa:
          Upgrade to the 2.4 release version and reset your log files.
            bastolino
            Hi Guys
            Thank you for that fix - I honestly thought I made a brick  :o
            Best wishes
            Bastolino
