Need Help with getting my clients to communicate over LAN (Plex, RDP, etc.)
Kidding…
Something like this is probably nice.
If you wanted to get very overkill you could get bigger.
https://www.newegg.com/Product/Product.aspx?Item=N82E16833127450
For your rig, since it has lots of power, I can recommend this switch:
https://www.newegg.com/Product/Product.aspx?Item=9SIA91N4D32331
thanks for the help, I really needed to know for sure cause I do want to get the most out of my pfsense router in performance. The only thing that sucks is that i just blew all that money on this mobo for the extra etho ports because I wanted it to be a all-in-one as much as possible.
damn i think i locked myself out of my router xC gonna try to RDP my server pc and see if i can connect to the GUI through it.
Well - About the ports… Probably just needed 2 if gigabit is fast enough for you. I'd probably stack a couple of 8 port switches for $30 each and be done with it.
However if bridging the ports works for you and you don't see lost bandwidth, go for it. Its nice and neat, thats for sure.
If your password doesn't work, I can let you try mine…
i mean that I can't access the GUI period but I found out the issue tho. I made a grave mistake…. Im not 100% sure this is the actual cause but evidence points to it. When i was applying firewall rules for all the OPT ports, I forgot to put all the IPv4 rules on top of the IPv6 rules for each OPT. The main reason I believe this to be the culprit is two reasons. One: The firewall reads the rules from first to last and Two: I can only access the IPv6 internet, I did a test and noticed that only IPv6 protocol was only being used and IPv4 isn't working. It just works for the LAN, but access to IPv4 on the internet has been disabled for some reason. :(
You do have your default anti-lockout rules in place… Right?
just for the LAN port, but not the other OPT ports, why? is there a way to get in even though the 192.168.1.1 isn't accessible?
Yes - pull up the console
Go to shell
type pfctl - d
Then log in via the web
Fix your rules -
Go to shell
type pfctl - d
Fix your rulesThere's just one problem… my keyboard isn't correctly being identified by pfsense, only "A" key works and it only works as "Enter". :( I just reinstalled it to make things easier but I just locked myself out again after setting up the bridge, it keeps locking out IPv4 access and only IPv6. I don't think I'm setting up the bridge right :/. I'm doing exactly what I explained in my so called "fix". Do you see anything out of the ordinary with those configs? Any help would be greatly appreciated.
I fuuuq, i just noticed what was in that link, couldn't see it earlier due to IP config issues, btw I finally got everything working now. :)
You are better off without the bridge.
What kind of CPU, RAM and HDD did you put in. Sizes please. Specs.
My Pfsense build consist of:
CPU: i7 6700T @2.80GHz
Motherboard: Jetway NF592-Q170 Intel Core Skylake LGA1151 w/ 8x Intel Multi LAN Networking Motherboard
RAM: 16GB Crucial DDR3/DDR3L 1600 MT/S (PC3-12800) Unbuffered SODIMM 204-Pin Memory
Storage: SanDisk Internal SSD 120GB -
Since you obviously enjoying playing with tech, you might enjoy installing a vmware hypervisor, installing pfsense and giving it 2 cores and installing some other type of server with access to the other 2 cores. 2 (or 3) machines in one. You have the horsepower.
Maybe just give pfsense 1 core. or 2 max. It will be fun.
thanks for the idea, I might seriously take you up on that. I would love to have my pfsense and Plex server all in one place. I might do 1 core for pfsense (cpu usage for it never goes above 3 percent lmao!) and then 3 for Plex. That does sound like fun and then I can use my old Plex server as a vpn download server where I’ll run torrents and stuff without worry. So many possibilities. Thanks for the idea!
Pfsense 2 vcore…
A small share, 2vcore...
plex - 4vcoresIt can take it. Its fast. Assuming its just 1 or 2 people on the plex at a time.
You bought a fast machine.
