    Routing problems between virtual subnet and remote client machine
    3 Posts 1 Posters 955 Views
    • N
      nz6nGFfD
      Dear pfsense pros,
      I'm new both to PfSense and BSD, and I reached a point where I don't know how to continue by myself. I read lots of threads and followed several manuals, without success. I guess my problem could be very simple, but I can't find the solution by myself using just trial and error. Maybe anybody would agree to give me a hand?
      What I have
      • A Windows 10 PC with IP 10.41.0.100, firewall disabled
      • A Pfsense virtual appliance with IP 192.168.151.2/24 "in the front", and 192.168.51.1/24 "in the back"
      • virtual Network is 192.168.52.0/24, Pfsense gets 192.168.52.1, the PC gets 192.168.52.2
      • There are several physical and virtual interfaces in subnet 192.168.51.0/24
      • The OpenVPN connection from the PC 10.41.0.100 to the pfSense virtual appliance 192.168.151.2 works inside the OpenVPN virtual network, I can ping the pfSense on interface 192.168.52.1 and even administer it via Web-GUI.
      • Packet filtering in Pfsense menu "firewall" is set to "no filtering" -> act as a router only
      What I want
      • reach all interfaces of 192.168.51.0/24 from that single Windows PC
      Problem
      • I cannot reach any interface in 192.168.51.0/24, not even the pfsense interface 192.168.51.1.
      Traceroute:
      When I perform a traceroute on machine 192.168.51.68 (random machine in Subnet behind pfSense) to 192.168.52.2 (virtual OpenVPN interface of the Windows PC), pfsense routes traffic via its default gateway:
      Tracing route to 192.168.52.2 over a maximum of 30 hops
      1 <1ms <1ms <1ms 192.168.51.1
      2 <1ms <1ms <1ms 192.168.151.1
      3 2ms 2ms 2ms          10.151.0.61
      4 ….. default route outside company network, to the internet
      When I perform a traceroute on machine 192.168.51.68 (random machine in Subnet behind pfSense) to 10.41.0.100 (physical interface of the Windows PC), the pfsense uses it's default gateway too.
      Tracing route to 10.41.0.100 over a maximum of 30 hops
      4 3ms 3ms 3ms          10.41.0.100
      When I perform a traceroute on Windows PC with interface 10.41.0.100 and virtual interface 192.168.52.2 to random machine in subnet 192.168.51.0/24, it routes traffic to the virtual interface of the pfsense, but not further
      Tracing route to 192.168.51.68 over a maximum of 30 hops
      1 3ms 3ms 3ms 192.168.52.1
      2 *      *    *      Request timed out.
      3 *      *    *      Request timed out.
      So it seems the pfsense doesn't route between its subnet 192.168.51.0/24 for which it is the default gateway and its openVPN virtual network.
      192.168.151.1 is default gateway for traffic leaving the PFSense. 192.168.151.1 is the IP of an Interface on a Fortigate 200B Firewall Appliance. There is an IPSEC connection between both interfaces 192.168.151.1 (Fortigate) and 192.168.151.2 (PfSense), and routing is dynamic using OSPF with Quagga_OSPF talking to the Fortigate interface.
      The virtual PFSense has 1 base-interface "vmx0" with a VMWare ESXi-interface tagged "vlan 4095" for "all vlans"
      pfSense interface "LAN" 192.168.51.1/24 is untagged on "vmx0", 192.168.151.2/24 is tagged in vlan 500 on "vmx0".
      OpenVPN is in "tun - Layer 3 Tunnel Mode"
      Ipv4 Routes in PFsense:
      default                 192.168.151.1 UGS 659 1500 vmx0.500
      192.168.51.0/24 link#1                   U 14565 1500 vmx0
      192.168.51.1         link#1                   UHS 0 16384 lo0
      192.168.52.0/24 192.168.52.2           UGS 0 1500 ovpns1
      192.168.52.1         link#23                   UHS 0 16384 lo0
      192.168.52.2         link#23                   UH     254 1500 ovpns1
      192.168.151.0/24 link#22                   U 29301 1500 vmx0.500
      192.168.151.2         link#22                   UHS 0 16384 lo0
      PFsense Version is
      2.4.1-RELEASE (amd64)
      built on Sun Oct 22 17:26:33 CDT 2017
      FreeBSD 11.1-RELEASE-p2
      I assume I do something wrong with routing since nothing goes back through the VPN tunnel, but I don't know what I'm doing wrong. What should be my next step in the troubleshooting list, could an expert help me out?
      1 Reply Last reply
      Reply Quote 0
      • N
        nz6nGFfD
        Asked 2 specialists and still no solution. It seems the problem is not that trivial :-(
        1 Reply Last reply
        Reply Quote 0
        • N
          nz6nGFfD
          can OpenVPNServer and IPSEC be used on the same interface? That's what I'm trying to do on IF vmx0.500. I guess that could be the source of the problem
          1 Reply Last reply
          Reply Quote 0
          Register Login
