    ICAP: using a different and dedicated and remote av engine?
    2 Posts 2 Posters 587 Views
      demux
      Hi.
      We are going to use a central ICAP-enabled AV scanner that runs on a dedicated machine.  We do not want to use clamav (neither locally nor remote).
      From looking at the various GUI settings I cannot find an easy way to configure squid to use another ICAP path except the one to the local clamav (c-icap).
      Is there a setting that I am missing or is there another way to set this up in a simple way (means without overriding the GUI config manually).
      I know that we could do that using a parent proxy setup, but we believe that taking the ICAP approach is faster and with less overhead - and makes more sense with regard to structure.
      (At the moment I cannot say which engine we are going to use as this is not yet finally decided.  But a written requirement is that we can talk to it using ICAP because of pfsense.)
      Where is the best place to configure another ICAP machine?
      Thanks for your help!
      demux.
        metteus
        @demux:
        Hi.
        demux.
        I'm looking for the same thing. I would like to have a GUI menu where i can specify the external ICAP Server IP address, reqmode/respmode and port.
        I suppose this could be easily done by developers.
        For now the best way i've found to config these parameters is by using the "Diagnostics –> Edit File" functionality to edit these two files:
        • /usr/local/pkg/squid_antivirus.inc
        • /usr/local/etc/squid/squid.conf
        Just edit the following lines using the correct IP/port/etc...and restart squid:
        icap_service service_req reqmod_precache bypass=1 icap://127.0.0.1:1344/request
        adaptation_access service_req allow all
        icap_service service_resp respmod_precache bypass=0 icap://127.0.0.1:1344/response
        adaptation_access service_resp allow all
        I hope someone more expert than me can find a simpler way or maybe some developer can introduce this feature :)
