    Please help firewall major problem going crazy
    7 Posts 4 Posters 2.5k Views
      kfoster
      OK so im trying to setup my web server on port 22178 i have setup the NAT and port forwarding but i cannot figure out why it wont work
        blak111
        How are you trying to access the web server?
          kfoster
          Through my domain name it use to work fine with my old router
            blak111
            Ah, if you are trying to do hit the outside address from the inside you will need to enable NAT reflection.
            It is better to have a separate internal DNS record that points to the inside address.
            Also, make sure you have an allow rule on the Firewall for WAN that allows traffic to your web server.
              kfoster
              Did both still not working maybe im missing something
              • chpalmerC Offline
                chpalmer
                I believe the "to" spot on the forward page cannot be blank…
                Primary- Intel(R) Pentium(R) CPU G4400 @ 3.30GHz on an M470 WG box. pfSense CE 2.8.1
                Lab Unit- Intel(R) Core(TM) i5-4590T CPU @ 2.00GHz on an M400 WG box. pfSense+
                  cmb
                  Read http://doc.pfsense.org/index.php/Port_Forward_Troubleshooting
