    Help with starting to use HAProxy - LB ip address is not delegated to virtual machines
    1 Posts 1 Posters 1.4k Views 1 Watching
    • V Offline
      veljko
      I am total beginner for HAProxy so please any advice will be much useful.
      I have two virtual machines on Microsoft Azure.
      They are in virtual network, and they have private IP addresses 10.0.9.4 and 10.0.9.5
      I created new Network interface on Microsoft Azure in the same virtual network with IP address 10.0.9.7
      Of course this is not delegated to any virtual machines.
      Name of interface is : lb.oozie.local, private IP address 10.0.9.7
      I added in /etc/hosts on .4 and .5
      10.0.9.7 lb.oozie.local
      I installed haproxy on both machines 4 and 5.
      haconfig file is the following:
      global
      log /dev/log local0
      log /dev/log local1 notice
      chroot /var/lib/haproxy
          stats timeout 30s
          #user haproxy
          #group haproxy
          daemon
          # Default SSL material locations
          ca-base /etc/ssl/certs
          crt-base /etc/ssl/private
          # Default ciphers to use on SSL-enabled listening sockets.
          # For more information, see ciphers(1SSL).
          ssl-default-bind-ciphers kEECDH+aRSA+AES:kRSA+AES:+AES256:RC4-SHA:!kEDH:!LOW:!EXP:!MD5:!aNULL:!eNULL
      defaults
      log global
      mode http
      option httplog
      option dontlognull
      timeout connect 5000
      timeout client 50000
      timeout server 50000
      frontend localnodes
      bind lb.oozie.local:80
      mode http
      default_backend nodes
      backend nodes
      mode http
      balance roundrobin
      option forwardfor
      http-request set-header X-Forwarded-Port %[dst_port]
      http-request add-header X-Forwarded-Proto https if { ssl_fc }
      option httpchk HEAD / HTTP/1.1\r\nHost:localhost
      server oozie1 10.0.9.4:11000 check
      server oozie2 10.0.9.5:11000 check
      listen stats lb.oozie.local:1936
      stats enable
      stats uri /haproxy?stats
      I did also:
      sudo service haproxy restart
      Redirecting to /bin/systemctl restart haproxy.service
      Validation returns that haproxy is valid:
      haproxy -f /etc/haproxy/haproxy.cfg -c
      [WARNING] 284/112531 (110051) : config : frontend ‘GLOBAL’ has no ‘bind’ directive. Please declare it as a backend if this was intended.
      Configuration file is valid
      As I understood my servers should get the ip address (10.0.9.7).
      I try from 10.0.9.4 and 10.0.9.5 ping to 10.0.9.7
      but on both servers I am getting it is not recognized.
      ping 10.0.9.7
      PING 10.0.9.7 (10.0.9.7) 56(84) bytes of data.
      From 10.0.9.4 icmp_seq=1 Destination Host Unreachable
      From 10.0.9.4 icmp_seq=2 Destination Host Unreachable
      Also if it is relevant:
      i installed keepalived mechanism
      I did not set public IP address for Load Balancer address, it has only private IP 10.0.9.7, because service is invoked directly from servers 10.0.9.4 and 10.0.9.5
      please help.
      Thank you in advance,
