    Best rules to best protection in WAN and LAN Interface
    31 Posts 10 Posters 22.2k Views 14 Watching
    • bmeeksB Offline
      bmeeks @torefloo
      @torefloo said in Best rules to best protection in WAN and LAN Interface:
      @bmeeks iis server (web server) in the LAN network with the WAN interface to go out and request from outside. In this case it is only necessary to activate the snort on the LAN interface.
      two interfaces are available WAN and LAN.
      Yes, it is only necessary to install Snort on the internal firewall interfaces; be that a single LAN or multiple internal interfaces such as a LAN, Wireless LAN, DMZ, etc.
      Do not get single-focused on the use of the word "LAN". I only mean that to represent internal (behind the WAN) firewall interfaces. If you have a DMZ with servers in it, then of course you can run a Snort instance there. I didn't literally mean just put Snort on the LAN and nowhere else.
      • bmeeksB Offline
        bmeeks @trumee
        @trumee said in Best rules to best protection in WAN and LAN Interface:
        @bmeeks Instead of saying setup SNORT on LAN, isn't it better to suggest putting SNORT on all the interfaces which are receiving port forwards from WAN. This would then cover DMZ and all other Vlan interfaces.
        See my most recent reply to @torefloo. When I say "LAN" I am just using that as a reference for any internal interfaces.
          maksimred20
          Help me understand something. I have HAProxy set up on pfSense that proxy's over to backend servers on the LAN. I understand the noise that get's generated if i set up Snort on the WAN interface, by default all unsolicited WAN traffic is dropped, but when I have port 80 and 443 allowed through the firewall to "This firewall" to the pfSense, how can I set up Snort to only apply the snort rules if ports 80 or 443 are alerted?
          I do get a bunch of noise as mentioned on the WAN interfaces on other Dports 1433, 3389, etc that I do not have opened in the firewall rules, but I also get port 80 and 443 targeted with attacks and would like to mitigate them. Short of offloading ha proxy duties to a VM that resides on a dedicated LAN interface, I am not sure on what I can do.
          Setting monitor mode on the LAN interface does me no good because the attacks are hitting the pfsense firewall on port 80/443 and are not sent down to a LAN machine to respond to.
          Current WAN firewall rules:
          Snort Alerts on WAN Interface Port 80:
          The destination IP is my WAN interface IP.
          Snort Alerts on WAN Interface Port 443:
          Bob.DigB bmeeksB 2 Replies Last reply Reply Quote 0
          • Bob.DigB Offline
            Bob.Dig LAYER 8 @maksimred20
            • bmeeksB Offline
              bmeeks @maksimred20
              @maksimred20 said in Best rules to best protection in WAN and LAN Interface:
              Huh? What you are asking really makes no sense. Try restating your issue again in another way to see if I can understand what you are asking.
              Each rule has its own set of criteria derived from the particular threat that rule is designed to detect. That means the rules are looking at all kinds of criteria for matching including (usually) destination port numbers.
                maksimred20 @bmeeks
                @bmeeks said in [
                This is the answer I was looking for.
                • bmeeksB Offline
                  bmeeks @maksimred20
                  @bmeeks said in [
                  Maybe you are asking why those ET Dshield rules were alerting on port 443?? Those rules, and a few other similar categories such as CIARMY, are simply looking at the source IP address. If the source IP is in a list of "known bad actor IPs", then the rule alerts. Has nothing to do with the destination port (usually) for those kinds of rules. But other rules categories would be looking at the destination port. It all depends on what the rule is looking for.
                    maksimred20 @bmeeks
                    @bmeeks
                    I guess what I was asking is if Snort/Suricata can only add offenders to the block list if Dports 80 or 443 rules are triggered, all other alerts can be ignored, don't add to block list, they are blocked anyway.
                    • bmeeksB Offline
                      bmeeks @maksimred20
                      @bmeeks
                      No, that's not really possible nor desirable. I think you are fundamentally misunderstanding how an IDS/IPS works and what it looks for, or else you would not be asking that question. Do some Google research for how IDS/IPS operates and how to select rules to match threats and exposed attack surfaces within a network, and I think you will be able to see that your question is not logical with regards to an IPS/IDS.
                        gspatton
                        I challenge the idea that there is no point in having snort on the LAN interface if there are no open ports to the LAN. Having snort on the LAN interface should block malicious code from reaching out to the internet. So this will mitigate the damage of a bad download. Do you agree?
                          patrykk @gspatton
                          @gspatton I think the point with enabling Snort on LAN is that you have control of what kind of traffic is going out from the network. Let say you have critical tools on LAN and multiple developers with access to those servers. They can misconfigure or install some malicious software. IPS/IDS will detect it once such application tries to connect to the Internet and based on rules configured on IPS/IDS will block such traffic. At least that how I see it. Most important you will know something is not right and start further investigation. Can you use other tools for that - sure, but IPS might actually save your bacon :)
