    Need your help will pay 20$: PIA on pfsense Netflix detects proxy
    54 Posts 14 Posters 11.9k Views 13 Watching
    • asphalt3A Offline
      asphalt3 @MrLinux
      @MrLinux said in Need your help will pay 20$: PIA on pfsense Netflix detects proxy:
      https://www.reddit.com/r/PFSENSE/comments/4lcfdf/netflix_to_wan_not_opt1vpn/d3mgta4/
      This guy got it and it works for me too. I'm not sure how his second approach works; I only did the first.
      On the same computer, I am now able to go to ipchicken.com and see my VPN IP address but Prime Videos doesn't give me a VPN warning anymore.
      It's somewhat related to: https://forum.netgate.com/topic/96559/routing-netflix-through-wan-and-else-through-vpn/4
      Thanks will try that again maybe this one will help.
      • JeGrJ Offline
        JeGr LAYER 8 Moderator @asphalt3
        @asphalt3 said in Need your help will pay 20$: PIA on pfsense Netflix detects proxy:
        Well I don’t wanna compromise my gigabyte speed using a slower vpn neither lose money on a vpn I already purchased before starting this thread
        Understandable, but if Netflix has anything from PIA listed it is pretty much useless for your usecase in running Netflix over it. That's just the way it is with Geo- and VPN-Blocking. Either you exclude Netflix/AWS/Amazon things from the VPN or you (mostly) get blocked for using a VPN. Nothing we can do about that if you don't want to either switch VPNs nor run Netflix "unencrypted" via your normal WAN.
        asphalt3A 1 Reply Last reply Reply Quote 0
          You can use whatever vpn want for your vpn stuff, but for netflix you just route that out your normal wan, without vpn... Which is what he linked too, and what brought up 22 days ago.. Policy Routing..
          If you insist on sending your netflix traffic through your vpn then its going to be wack-a-mole.. It may work, it may not - as soon as they block that vpn it will stop, etc. etc.
            Gertjan
            Netflix over a blocked - by Netflix - VPN can be made working ....
            The concession will be : look out for a second VPN that is accepted by Netflix - or run your own on a VPS or something like that. Or : run a VPN server at your neighbours house ^^
            Now, you must be willing to hook up your TV set - using a HDMI - to your PC - or use the Window 10 trick : stream your PC image to your TV set.
            Initial setup : pfSense tunnels everything - your entire LAN - through your initial VPN service.
            From your PC : before looking Netflix, launch a VPN to your own VPN server, the one that Netflix accepts. Throw the image on your TV set.
            You created a tunnel in a tunnel !
            This works !
            ( I tested it ones )
            Netflix works now .... but your new problem might be the black helicopters over your house. There are agencies that get nervous when you make tunnels in tunnels ... (darknet etc).
            • asphalt3A Offline
              asphalt3 @JeGr
              @JeGr said in Need your help will pay 20$: PIA on pfsense Netflix detects proxy:
              That’s exactly what I want to do “exclude Netflix/AWS/Amazon ” maybe I wasn’t clear
              • asphalt3A Offline
                asphalt3 @johnpoz
                @johnpoz said in Need your help will pay 20$: PIA on pfsense Netflix detects proxy:
                What do you mean by “route that out your normal wan”? Right now I’ve assigned a static ip to my smart tv that I route through wan. I am not sure to understand what you’re saying. You mean that by using policy routing there’s another way around... I don’t understand
                • bmeeksB Offline
                  bmeeks @asphalt3
                  That is a policy-based rule. It selects an outbound gateway using conditions defined in the rule. In your case, you have a static IP assigned to your Smart TV, and when the rule detects traffic from your Smart TV outbound to the Internet that matches the ports/protocols you may have specified, the rule triggers and routes the traffic out the normal WAN interface instead of out on the VPN.
                  You have two options for handling how you route. You can assign static IP addresses to your streaming devices that you want to use for Netflix and then use your existing policy-based rule. The other option is to create an alias containing all the known IP addresses for the CDN that make up the Netflix distribution chain. The pfBlockerNG package helps with that because it can download lists of IP addresses and maintain the aliases for you. The only difference in this case is that your policy rule would change so the source IP was "any" instead of your assigned Smart TV static IPS and the destination IP would be the alias (or aliases) containing all the CDN IP addresses for Netflix.
                  I personally would recommend the option you are already using with static IP addresses for your streaming devices. That alias option is going to have hiccups because the list of CDN (content distribution network) IP addresses is ever-changing. Sometimes the third-party maintainer of those free IP lists falls behind on updates. If that happens and your alias containing all the Netflix CDN IP addresses gets out of date, then Netflix could get erroneously routed out via your VPN (because the destination IP that a client looked up via DNS happened to not match any of the IPs in the "Netflix Alias" configured in pfBlockerNG).
                    Konstanti @bmeeks
                    @bmeeks
                    Hi
                    I had a similar problem and I had to separate the traffic of Netflix on the streaming device (Apple TV) from all other traffic and to put it on my desired direction.
                    Because the ip addresses of the servers Netflix is constantly changing (and a lot of them) , I have created a module in PFSense+Netgraph+parser DNS responses (written in C)
                    Now I can catch all dns responses that have text Netflix, nflxvideo or nflxso ,and put the ip addresses of these responses in the table PF .
                    And with the help of this table and PBR send the traffic where I need to go
                    It looks like this (the part of the log)
                    Sep 17 13:46:18 daemon started
                      Found file /usr/local/tmp/dns_parser/ip.db, restore table netflix_ip
                      Successfully restored 291 ip-addresses
                    Sep 17 13:50:39 Get DNS response for server: cast-uiboot.prod.http1.netflix.coM
                      Alias name(CNAME):  prod.http1.geo.netflix.coM
                      Alias name(CNAME):  prod.http1.eu-west-1.prodaa.netflix.coM
                      Domain name(ANAME):  prod.http1.eu-west-1.prodaa.netflix.coM
                       IP address 34.252.211.92 will be added to table
                       IP address 52.17.137.54 will be added to table
                       IP address 52.214.57.81 will be added to table
                       IP address 52.214.167.17 will be added to table
                       IP address 54.77.61.253 will be added to table
                       IP address 34.242.54.142 will be added to table
                       IP address 34.251.119.18 will be added to table
                       IP address 34.251.249.50 will be added to table
                      Total ip addresses to add 8, Succefully added 8 ip addresses  to table netflix_ip
                    Sep 17 13:50:40 Get DNS response for server: occ-0-38-2773.1.nflxso.neT
                      Domain name(ANAME):  occ-0-38-2773.1.nflxso.neT
                       IP address 23.246.26.150 will be added to table
                       IP address 23.246.26.157 will be added to table
                      Total ip addresses to add 2, Succefully added 2 ip addresses  to table netflix_ip
                    Sep 17 13:50:45 Get DNS response for server: ipv4-c079-arn001-ix.1.oca.nflxvideo.neT
                      Domain name(ANAME):  ipv4-c079-arn001-ix.1.oca.nflxvideo.neT
                       IP address 23.246.26.156 will be added to table
                    Total ip addresses to add 1, Succefully added 1 ip addresses  to table netflix_ip
                    This part of the table and rule for it
                    • JeGrJ Offline
                      One can also use pfBlockerNG for that. Import the Netflix AS delegations etc. and put that into an IP alias. Some of our customers are doing it like that without much problems. Netflix + AWS AS and a few minor IPs and you have a pretty solid working base.
                      • bmeeksB Offline
                        bmeeks @Konstanti
                        @Konstanti:
                        Yes, there are a couple of different ways to "skin this cat" so to speak. My personal preference would be either static IP addresses (or DHCP reservations) for my streaming devices. But using an IP list containing the Netflix or Amazon or Hulu, etc., IP addresses can work as well. I just know that from time to time those IP addresses are likely to change, and your streaming connection might hiccup if the destination IP the client obtained from its DNS lookup did not match an IP in your streaming provider alias list. That would then result in your streaming client being routed out via the VPN tunnel instead of your normal WAN IP and thus getting blocked.
                        Of course it is a hassle to assign static IP addresses, and especially so for "roaming" devices such as say your grandkids mobile devices (if you have grandchildren yet) or the mobile devices of other guests in your home. So I can definitely see the appeal of using the CDN list concept via pfBlockerNG or rolling your own solution.
                        In the end, though, I admit to being a huge non-fan of VPNs. I see them as required for only two scenarios: (1) to connect remote offices together into a company-wide LAN or (2) for secure remote access into my own LAN. I'm not a fan of the whole "privacy" thing so much. First of all, as has been stated here many times, you really have no meaningful guarantee of privacy from some of these VPN providers. Most certainly if you are doing something shady or patently illegal behind a VPN you don't have the protection you think you do. A subpoena or search warrant from a government law enforcement agency carries a lot of weight, and just about any VPN provider would cave (especially if they are located within your country of residence). Finally, for what little benefit you may convince yourself you are getting by hiding your web traffic behind a VPN, you also get a good bit of PITA (pain in the a**). Just do a search here on the pfSense forums for "vpn" and see how many folks have issues connecting to various services. You will find that most of the time the cause turns out to be their VPN configuration. In fact, just look at the origin of this very thread. The OP was having streaming issues trying to use the VPN.
                        K 1 Reply Last reply Reply Quote 1
                          static is not all that hard, just set a reservation - once this mobile client has connected once.. Just set reservation for it from the dhcp lease listing, just click the little button and assign it an IP.. Next time it gets IP from dhcp it would get the reserved one..
                          edit: Isn't that what PIA vpn name stands for? Pain In Ass ;) hehehehe
                          • bmeeksB Offline
                            bmeeks @johnpoz
                            edit: Isn't that what PIA stands for? Pain In Ass ;) hehehehe
                            Probably need to edit my acronymn to be PITA instead... ☺ . Still only one coffee down the hatch this morning ...
                            And by "hassle" I mean you have to login to the firewall, find the device's MAC and set the IP and reservation. True you won't have to repeat that again, though. I was mainly referring to that first time encounter with a particular device. It's difficult to concentrate on getting the static IP and reservation set up with a panicked 4 year-old in your ear who's "Dora the Explorer" show won't play on the iPad ... 😁 .
                              Konstanti @bmeeks
                              @bmeeks
                              My program updates the list of ip addresses of servers netflix dynamically based on the responses of the DNS server , and the list is constantly increasing in size . So at the moment I have ensured that I was able to split the traffic HBO and AMAZON PRIME traffic from NETFLIX on the same device.And the program is quite stable for 2 weeks.
                              I use VPN because HBO doesn't work in Russia , and I want to watch it )))
                              • bmeeksB Offline
                                bmeeks @Konstanti
                                @Konstanti said in Need your help will pay 20$: PIA on pfsense Netflix detects proxy:
                                @bmeeks
                                Your situation is a bit different. You are then, in fact, using the VPN to bypass HBO's geo-restriction policy.
                                  Well that is the actual real reason for vpn's as we all well know, circumvention of geo restrictions.. Not that silly nonsense about any sort of privacy ;)
                                    william333
                                    Very important discussion started here which help me to fix my problem.
                                      Gertjan
                                      Well, yeah, content suppliers can't supply without knowing your real geographical position, they stop supplying you when you 'mystify' your location.
                                      When you use a VPN, you're hiding your real 'view point' position.
                                      Solution : don't use a network that is considered as a VPN.
                                      Netflix, etc, they all mention this in their "selling conditions".
                                        just google wack a mole vpn ;)
                                          habanavee
                                          This thing works on Netflix but not for Amazon prime, do you any solution for that too?
                                          • bmeeksB Offline
                                            bmeeks @habanavee
                                            @habanavee said in Need your help will pay 20$: PIA on pfsense Netflix detects proxy:
                                            Yep! Disconnect the VPN and Amazon Prime will work just fine (and as a bonus, Netflix will work, too!).
                                            H 1 Reply Last reply Reply Quote 1
