    Firewall Rule to Allow RDP from WAN to LAN......Need help
    76 Posts 7 Posters 11.8k Views 8 Watching
      And is unbound running on pfsense?
      Or did you turn it off - why do you keep asking 30.10 anything?
      Lets see query from your boxes you say work, and then from your wireless client... This isn't freaking rocket science here.. I don't care you if you query 30.1 or 8.8.8.8 - you have yet to show a sniff that your actually getting to pfsense..
      do a dns query from one of your other physical boxes, not some VM... Lets see it query pfsense 30.1 for dns, and then do the query from your wifi.
      Also lets actually see your LAN rules..
        DINU @johnpoz
        @johnpoz said in Firewall Rule to Allow RDP from WAN to LAN......Need help:
        I have removed my wifi router cable connected to second NIC of physical machine. Now, I have connected network switch and from switch I have connected my Windows 10 laptop to do simple test whether internet is working through direct connection. Attached Outbound and LAN firewall rule.
        when do DNS query to 192.168.30.1 I can see below :
        What I can see is any thing goes through second NIC of physical server (ie) through LAN network .. unable to get internet...
        Second NIC of physical host is taking IP from Windows DHCP server...
          Dude freaking sniff already... And is anything even listening on 30.1 for dns???
          Going to say this one last time - pfsense can not do anything with traffic it never sees.. I have showed you multiple times how to do a sniff and validate dns query actually gets to pfsense lan interface so it can do something with it.. Be it answer it itself or pass it on to some other dns..
            DINU @johnpoz
            dude freaking sniff already... And is anything even listening on 30.1 for dns???
            I have tried DNS query from one of the machine (ie) VM which is sitting on LAN network and able to query..
              I said do it from a physical network device.. And that sure doesn't look right.. how come it didn't come back with pfsense name for the 30.1 address?
              $ nslookup
              Default Server:  pi-hole.local.lan
              Address:  192.168.3.10
              > server 192.168.9.253
              Default Server:  sg4860.local.lan
              Address:  192.168.9.253
              See how the IPs resolve to their name... sg4860.local.lan for pfsense IP 9.253
              So what your saying is no physically connected device can do a dns query that actually gets to pfsense for pfsense do anything with? How is that a pfsense problem? You have something wrong in your VM host setup..
                DINU @johnpoz
                $ nslookup
                when I do nslookup pfSenseFR.localdomain I can get queried and get IP as 192.168.30.1 in my local VM..But when I do same in another physical machine dns is not working .
                Yes you are correct.. I am saying this from beginning....
                Can you guide me how to connect physical device through second NIC to use as LAN network to connect pfsense network
                  How are you pinging it if not connected??? Your saying you never pinged it from a physical device?
                  How do you have it setup, what are you using for a VM host software?
                    DINU @johnpoz
                    I never said that I am unable to connect to LAN network. I am saying that unable to browse the internet from my physical device connected through LAN network..
                    I have windows 2012 R2 in my physical host and VMware workstation as host software..
                    I have two physical NIC in my host..
                    one is connected (ie) bridged to pfsense WAN and
                    Second NIC is bridged with pfsense LAN
                      DINU
                      Pls find below my network connected :
                      • bmeeksB Offline
                        bmeeks @DINU
                        @DINU said in Firewall Rule to Allow RDP from WAN to LAN......Need help:
                        In your drawing, two devices have the same IP address. Virtual Machine #3 (DHCP and Sec DNS) is shown as having IP 192.168.30.11, but so is the Windows 10 Laptop machine shown hanging off the external switch. That won't work. Is it a typo?
                          DINU @bmeeks
                          @bmeeks said in Firewall Rule to Allow RDP from WAN to LAN......Need help:
                          it is typo error Windows 10 Laptop is 192.168.30.111
                          • bmeeksB Offline
                            bmeeks @DINU
                            I just noticed another issue that hopefully is also a typo. You have the Asus router shown with IP 192.168.30.100, but you are also showing that same IP address apparently assigned to the eth1 interface on the VM Physical Host. That can't be correct.
                            And the external switch you are showing, is it a dumb switch or a managed switch? If managed, are any VLANs defined in it and is at least one trunk port configured?
                            And which hypervisor are you using? Is it ESXi, Hyper-V or something else?
                              DINU @bmeeks
                              YEs that is also typo error eth1 is 192.168.30.150
                              It is managed no Vlans or trunk port configured. When I am trying to use same subnet in the LAN, internet is not working in External devices.. then no use of using VLAN here
                              Vmware workstation
                                DINU
                                @johnpoz :
                                Thanks a ton johnpoz for your help and spending your valuable time to check the issue and provided the solution.....
                                Issue is resolved, I can able to access the internet from my external LAN devices through wifi and through switch as well...
                                (i) Issue is with pfsense in System => General Setup => DNS Server that was pointed to WAN_IP I have changed to none and added local DNS as well and it started working fine.
                                (ii) I have tried another way of using all interfaces to go through pfsense DNS of creating NAT port forward DNS 53 to 127.0.0.1 and solved the issue..
                                But (i) looks good and I have used that..
                                Thanks Once again !!!!
                                  Sorry but NO... That would have zero to do with it.. You would of gotten an answer from unbound if running.. What you put in general has ZERO to do with that unless you had changed it to forwarder?
                                  And would of had zero to do with your client talking to 8.8.8.8 for dns.. So whatever you think the problem was - it sure wasn't that..
                                  So your now redirecting dns?? I had asked you before if you were doing such thing.. Which sure that could of cause you all kinds of grief if that was setup wrong. Which you could of validated in like 2 seconds with as simple sniff that you could actually even talk to pfsense for dns.
                                    DINU @johnpoz
                                    I went into deep dive and found the biggest culprit is SEP (Symantec Endpoint protection)....
                                    If I enable firewall it is not allowing DNS , If i disable it is working...
                                    In symantec in firewall it has to "Allow IP Traffic" not "Allow only application traffic" this SEP culprit made me mad...
                                    Thanks Again...
