Will 1.2.3 fix the Dead Peer Detection problem?
Having issues with VPN tunnels and pfSense not being able to re-establish the tunnel and having to manually delete the SAD entries for the tunnel in order to get it to re-establish connectivity.
If you configure DPD appropriately. There was never a problem with it, it just wasn't supported. It is in 1.2.3.
Is this done via the GUI or in the vpn.inc file?
Look for DPD Interval in the GUI. I pulled this from a 1.2.3-RC1 install.
Dead Peer Detection interval in seconds.
Leave this empty to only respond to DPD requests and not send any requests. -
Thanks,
Mark
