    Weird problem with system states
    32 Posts 6 Posters 9.8k Views
    • E
      eri--
      Upgrade to a snapshot more recent than this post and it should start to behave ok.
      • H
        Hugovsky
        1.2.3-RC2
        built on Sun Jun 14 00:15:01 EDT 2009
        Same problem.
        • jimpJ
          That snapshot is from early this morning, a new one has not yet been made.
          Do not Chat/PM for help!
          • H
            Hugovsky
            @jimp:
            OK, nevermind, I can reproduce this now.
            Talked to another dev and he says it is likely from the recent (June 11th) patch for fixing multi-wan sticky connections and there is another patch to merge, but there is more testing to do first.
            So it should be fixed before too long, and if you roll back to a snap before June 11th you should be OK for now.
            I'll wait for 1 more update. If it doesn't get fixed, I'll roll back. Thx all for the answers.
            @jimp: Yes, I know. I've tryed it now just to see if it was already fixed. ;)
            • R
              ryates
              Thanks for the info - I have been on Jun 11 17:41:59 EDT 2009 as a workaround.
              small matter: the updater informs  the latest version as "Sun Jun 14 05:33:50 EDT 2009" yet it is in fact a build from 00:15:xx or so.  Why the mismatch in the version file?
              • jimpJ
                @ryates:
                Probably a mismatch of time zones, GMT vs. local time.
                • R
                  ryates
                  Ah yes, of course.  Devs might fix that, though it is trivial.
                  • B
                    Bern
                    I was having the problem with states during the week.
                    I've updated to:
                    1.2.3-RC2
                    built on Sun Jun 14 18:15:10 EDT 2009
                    and it looks like it's fixed now.
                    • jimpJ
                      @Bern:
                      I've updated to:
                      1.2.3-RC2
                      With the latest snap my test box also appears to be normal. I haven't reflashed my embedded box yet, the new snap just appeared for that a couple minutes ago.
                      • H
                        Hugovsky
                        Just updated. I'll post the results asap.
                        • H
                          Hugovsky
                          The problem seems gone. I have now 98 states. Thx for fixing it. ;)
                          • jimpJ
                            My states are also back to normal on my embedded box.
                            Thank ermal for fixing it, he's the one who put the patch in that corrected it :)
