    Switched to Python unbound Mode and now have issue
    35 Posts 8 Posters 7.3k Views 9 Watching
      netblues @BBcan177
      @bbcan177 No such file exists
      Even tried touching and disabling - reenabling.
      Is the file name correct?
      BBcan177B RonpfSR 2 Replies Last reply Reply Quote 0
      • BBcan177B Offline
        BBcan177 Moderator @netblues
        @netblues
        Did you enable Python mode and Safe Search? Then Run a Force Update.
        "Experience is something you don't get until just after you need it."
        Website: http://pfBlockerNG.com
        Twitter: @BBcan177  #pfBlockerNG
        Reddit: https://www.reddit.com/r/pfBlockerNG/new/
        • RonpfSR Offline
          RonpfS @netblues
          @netblues Maybe save DNSBL Settings, SafeSearch Settings, Force Update / Reload ALL while monitoring pfblockerng.log.
          2.4.5-RELEASE-p1 (amd64)
          Intel Core2 Quad CPU Q8400 @ 2.66GHz 8GB
          Backup 0.5_5, Bandwidthd 0.7.4_4, Cron 0.3.7_5, pfBlockerNG-devel 3.0.0_16, Status_Traffic_Totals 2.3.1_1, System_Patches 1.2_5
            McFuzz @BBcan177
            @bbcan177 said in Switched to Python unbound Mode and now have issue:
            @netblues
            So - this worked for me, but only after I’ve done a second time! After the first time I had the same issue and after doing the second time, it started working flawlessly. Odd... could be something on my end but so far, everything’s working well.
              netblues @RonpfS
              Enabled safesearch, enabled python mode., applied and force updated
              Loading DNSBL Statistics... completed
              Loading DNSBL SafeSearch... enabled
              Loading DNSBL Whitelist... completed
              DNSBL - SafeSearch changes found - Rebuilding!
              -Assembling DNSBL database...... completed [ 03/29/21 22:26:48 ]
              Removing DNSBL Unbound python integration settings
              DNS Resolver ( enabled ) unbound.conf modifications:
              Removed DNSBL Unbound Python mode
              Removed DNSBL Unbound Python mode script
              Saving DNSBL statistics... completed [ 03/29/21 22:31:10 ]
              Resolver Live Sync analysis... completed [ 03/29/21 22:31:24 ]
              Resolver Live Sync finalizing:
              And hungs there, with no dns service, unbound process at 100% for 15 minutes now..
              After killing unbound process
              Resolver Live Sync ... FAILED!
              Stopping Unbound Resolver
              Unbound stopped in 1 sec.
              Additional mounts:
              Unmounting: /lib
              Removing duplicate mounts (2): /dev
              Unmounting: /var/log/pfblockerng
              Unmounting: /usr/local/share/GeoIP
              Removing DNSBL Unbound python mounts:
              Unmounting: /usr/local/bin
              Removing: /var/unbound/usr/local/bin
              Unmounting: /usr/local/lib
              Removing: /var/unbound/usr/local/lib
              Starting Unbound Resolver... completed [ 03/29/21 22:46:33 ]
              DNSBL update [ 801834 | PASSED ]... completed [ 03/29/21 22:46:35 ]
              and safesearch appeared on google search
              python mode was found disabled again.
              Re enabled python mode in resolver at this stage
              and
              Mar 29 22:55:55 unbound 55552 [55552:1] error: pythonmod: Exception occurred in function operate, event: module_event_new
              Mar 29 22:55:55 unbound 55552 [55552:1] error: pythonmod: python error: Traceback (most recent call last): File "pfb_unbound.py", line 1147, in operate if qstate_valid and pfb['safeSearchDB']: KeyError: 'safeSearchDB'
              STILL NO FILE!!!
              RonpfSR 1 Reply Last reply Reply Quote 0
                netblues @McFuzz
                @mcfuzz Is python mode on in resolver?
                • RonpfSR Offline
                  RonpfS @netblues
                  @netblues said in Switched to Python unbound Mode and now have issue:
                  You can not simply enable Python in DNS Resolver / General Settings tab, you have to do that in pfBlockerNG / DNSBL tab, then run a Force Update.
                    McFuzz @netblues
                    Yessir.
                      netblues @RonpfS
                      @ronpfs I did that, initially.
                      exactly as instructed!
                      • RonpfSR Offline
                        RonpfS @netblues
                        @netblues Same result with a Force Reload All?
                          netblues @RonpfS
                          @ronpfs it does take time doing aaforce reload
                          • RonpfSR Offline
                            RonpfS @netblues
                            @netblues 5-30 mins should be enough. But if some lists timeout after 5 mins, Update time can be much longer.
                            What kind of machine ? Under 4GB you have to limit the size of Feeds.
                            You may also have some lists that break DNSBL. Maybe disable all Groups and enable only one at a time to see if that complete fine.
                            Maybe something is running wild, was it rebooted lately?
                              netblues @RonpfS
                              @ronpfs @ 4Gigs, runs under kvm.
                              Disabled all tld option, for speedier updates.
                              I'm aware of lists overload et all. Without python mode, cron updates are normal, and force update complete in about 10-12 minutes.
                              Still, I can't enable python mode without loosing dns resolution.
                              So update fails due to no resolving.
                              Looks like a corner situation.
                                Gertjan @netblues
                                about 10-12 minutes
                                That's ..... long. Slow connection ? Huge number of feeds ? Both ? Underpowered device ?
                                But even so, during the update, unbound - and the underlying extension python script, just takes a couple of seconds to restart. Surely non "10 minutes".
                                It's possible that the download saturates the download "pipe", so even DNS traffic suffers. All your traffic could suffer from this.
                                One of the reasons I update my feeds ones a week at 0300 AM. As most lists - you can see the date/time stamp info - is updated less often then that.
                                  netblues @Gertjan
                                  @gertjan Downloads are instant.
                                  Filtering through 1m takes most of the time.
                                  And no, the pipes are not saturated @100Mbits
                                  And dns doesn't suffer overall.
                                  If I get the dreaded error in resolver logs, no resolution is possible.
                                  Ping with ip works great.
                                  I need to experiment a bit more, but since this is service affecting during normal hours
