    pfSense 2.5.2 VLANs with Cisco 2960X not working..Please help.
    23 Posts 2 Posters 2.8k Views 3 Watching
      McNile @johnpoz
      @johnpoz Well, I think I found the problem. I completely wiped the switch to a factory reset and updated the IOS. I now have the main LAN working again. I did find before the reset that the settings of Vlan 1 were buggy (done before I took over here). It was set to shut down and some other odd settings. There were also other issues in the IOS too that is why I wiped it and loaded the new image. going to start fresh with pfSence too.
      @johnpoz Thank you so much for your help and thoughts. It helps to have others give input for ideas and places too look.
        johnpoz LAYER 8 Global Moderator @McNile
        @mcnile glad to hear - here to help.. Yeah even if just sounding board for your own thoughts always good to get opinions on what it could be, what it couldn't be - etc.. Glad I could help in some way.
        Let us know when your all up and running. Something was not right for sure - because this should only be couple of minutes to get running.
          McNile @johnpoz
          @johnpoz I have the factory reset pfSense running with two Vlans and the switch reset with a new IOS image and running with the two Vlans and getting IPs, internet. Everything is working as it should. I think that whoever configured the switch before me had some odd settings because it worked after the wipe and image upgrade, it worked.
