    Strange connectivity problem with 1.2.3-RC2 embedded
    22 Posts 5 Posters 7.5k Views
      Briantist
      For now this could be "sorta" fixed by adding something like <shellcmd>ifconfig tap0 10.0.8.1/24</shellcmd> to your config file, but if the tunnel re-establishes itself after start up the mask will be reset again. I am using OpenVPN with bridging too and have seen the crazy netmask but so far it hasn't affected me. I just assumed that it wouldn't affect anything and left it alone, but apparently that might not always be the case. I'll have to keep an eye out for this if I see strange behavior.
      Fixing this before 1.2.3 would be amazing.
        Sostris
        It depends on what you set for the remote network on the tap interface. By trial and error I found one that doesn't seem to cause interference with the part of the Internet that I use.
        If the Avahi package worked on nanobsd, I don't think bridging would be needed. But it doesn't.
