VOIP provider after schedule not registering debug help required
@stephenw10 I can confirm, it is 3min past the activation of the schedule and the states on the vlan are;
- ipfone -> mynetfone
- sipgate -> ipfone
- voiptalk -> ipfone
So it is being caused by the schedule turning on. i've masked some of the IPs
pfctl -vvsr
all udp 217.61.x.x:15777 (192.168.22.6:5160) -> 125.213.x.x:5060 MULTIPLE:MULTIPLE age 18:08:26, expires in 00:04:24, 1497:776 pkts, 477198:389009 bytes, rule 123 id: 6ba41a6300000003 creatorid: 5f2a04ac gateway: 185.29.x.x origif: pppoe0 all udp 217.61.x.x:26167 (192.168.22.6:5160) -> 217.10.x.x:5060 MULTIPLE:MULTIPLE age 17:07:50, expires in 00:10:21, 3396:4706 pkts, 363541:343808 bytes, rule 123 id: 82af1a6300000003 creatorid: 5f2a04ac gateway: 185.29.x.x origif: pppoe0 all udp 217.61.x.x:14782 (192.168.22.6:5160) -> 77.240.x.x:5065 MULTIPLE:MULTIPLE age 17:10:46, expires in 00:14:53, 5808:3018 pkts, 1960523:1098668 bytes, rule 123 id: 62db1a6300000001 creatorid: 5f2a04ac gateway: 185.29.x.x origif: pppoe0 all udp 217.10.x.x:5060 -> 192.168.22.6:5160 MULTIPLE:MULTIPLE age 00:09:53, expires in 00:14:50, 23:62 pkts, 736:29737 bytes, rule 122 id: a89b1b6300000003 creatorid: 5f2a04ac gateway: 0.0.0.0 origif: igb2.22 all udp 77.240.x.x:5065 -> 192.168.22.6:5160 MULTIPLE:MULTIPLE age 00:09:37, expires in 00:14:53, 20:88 pkts, 5760:43859 bytes, rule 122 id: b09b1b6300000003 creatorid: 5f2a04ac gateway: 0.0.0.0 origif: igb2.22 all udp 192.168.22.5:53 <- 192.168.22.6:32978 MULTIPLE:MULTIPLE age 00:07:14, expires in 00:14:44, 6:6 pkts, 408:504 bytes, rule 467 id: f49b1b6300000003 creatorid: 5f2a04ac gateway: 0.0.0.0 origif: igb2.22
pfctl -vvsr
@37 pass in quick on igb2.22 inet proto udp from any port = bootpc to 192.168.22.5 port = bootps keep state label "allow access to DHCP server" ridentifier 1000003592 [ Evaluations: 31 Packets: 62 Bytes: 20832 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @38 pass out quick on igb2.22 inet proto udp from 192.168.22.5 port = bootps to any port = bootpc keep state label "allow access to DHCP server" ridentifier 1000003593 [ Evaluations: 305 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @462 pass in quick on igb2.22 inet proto tcp from any to 192.168.22.5 port = domain flags S/SA keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 331137 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @463 pass in quick on igb2.22 inet proto tcp from any to 192.168.22.5 port = ntp flags S/SA keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 0 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @464 pass in quick on igb2.22 inet proto tcp from any to 192.168.22.5 port 67:68 flags S/SA keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 0 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @465 pass in quick on igb2.22 inet proto tcp from any to 192.168.22.5 port = time flags S/SA keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 0 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @466 pass in quick on igb2.22 inet proto tcp from any to 192.168.22.5 port 5351:5357 flags S/SA keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 0 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @467 pass in quick on igb2.22 inet proto udp from any to 192.168.22.5 port = domain keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 218 Packets: 466 Bytes: 40867 States: 1 ] [ Inserted: uid 0 pid 86711 State Creations: 1 ] [ Last Active Time: Sat Sep 10 00:09:41 2022 ] @468 pass in quick on igb2.22 inet proto udp from any to 192.168.22.5 port = ntp keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 1 Packets: 2 Bytes: 152 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @469 pass in quick on igb2.22 inet proto udp from any to 192.168.22.5 port 67:68 keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 0 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @470 pass in quick on igb2.22 inet proto udp from any to 192.168.22.5 port = time keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 0 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @471 pass in quick on igb2.22 inet proto udp from any to 192.168.22.5 port 5351:5357 keep state label "USER_RULE: Core Network Services (DNS/DHCP/BOOTP/etc)" label "id:1610264176" ridentifier 1610264176 [ Evaluations: 0 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @472 block drop in quick on igb2.22 inet proto tcp from any to ! (self:18) port = domain label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 260 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @473 block drop in quick on igb2.22 inet proto tcp from any to ! (self:18) port = ntp label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 95 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @474 block drop in quick on igb2.22 inet proto tcp from any to ! (self:18) port 67:68 label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 95 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @475 block drop in quick on igb2.22 inet proto tcp from any to ! (self:18) port = time label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 95 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @476 block drop in quick on igb2.22 inet proto tcp from any to ! (self:18) port 5351:5357 label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 95 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @477 block drop in quick on igb2.22 inet proto udp from any to ! (self:18) port = domain label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 260 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @478 block drop in quick on igb2.22 inet proto udp from any to ! (self:18) port = ntp label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 165 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @479 block drop in quick on igb2.22 inet proto udp from any to ! (self:18) port 67:68 label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 165 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @480 block drop in quick on igb2.22 inet proto udp from any to ! (self:18) port = time label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 165 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @481 block drop in quick on igb2.22 inet proto udp from any to ! (self:18) port 5351:5357 label "USER_RULE: Trap External: Core Network Services (DNS/DHCP/BO..." label "id:1610264228" ridentifier 1610264228 [ Evaluations: 165 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ] @482 block return in log quick on igb2.22 inet all label "USER_RULE: Default Block VOIP IPv4+IPv6" label "id:1610264385" ridentifier 1610264385 [ Evaluations: 186 Packets: 186 Bytes: 80780 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: Sat Sep 10 00:09:41 2022 ] @483 block return in log quick on igb2.22 inet6 all label "USER_RULE: Default Block VOIP IPv4+IPv6" label "id:1610264385" ridentifier 1610264385 [ Evaluations: 0 Packets: 0 Bytes: 0 States: 0 ] [ Inserted: uid 0 pid 86711 State Creations: 0 ] [ Last Active Time: N/A ]
So what are rules 122 and 123?
I suspect those will be the default allow out rules.
When the schedule stops and the pass rule no longer apply it's likely killing the states that are opened by it. That means the inbound states on igb2.22. But the States on WAN remain, you can see the age of the states there, and that allows replies from the provider to come back in and open new states outbound on igb2.22. Hence what you see. Unclear why those states cause an issue but the tests you did prove they do. Also unclear why the upgrade to 22.0x would behave any differently. It does kill the states more precisely which was not previously possible so it could be it was killing all the states in 2.5.2 preventing this happening.
So you should be able to prevent this by adding rules to stop those states being created.
You could create with the schedule but since you should never need those outbound states on the VoIP VLAN I would just add floating outbound block rules on there as specifically as possible.
So from the HOST_SVR_VOIP alias to the phone on port 5160.Steve
@stephenw10 I don't know how you resolve the rule number, but looking at the states that are passing, the rules would be;
I'll add that floating rule now, and check it tonight when the schedule kicks in. (I renamed HOST_SVR_VOIP to HOST_CLN_VOIP to better reflect what is actually is)
HOST_SVR_VOIP
@stephenw10 hi steve, similarly, thanks to your test, i have also identified something that shouldn't be happening.
I have a nat forward rule to intercept port 53 and use pfsense as the dns server which forwards to 1.1.1.1 port 853
But I see an android device is able to get a connection to google port 53.
How is this possible?all udp 192.168.40.5:53 (8.8.8.8:53) <- 192.168.40.81:53992 SINGLE:MULTIPLE age 00:00:36, expires in 00:01:54, 1:1 pkts, 60:106 bytes, rule 1173 id: a5851b6300000002 creatorid: 5f2a04ac gateway: 0.0.0.0 origif: bridge1 all udp 192.168.40.5:53 (8.8.4.4:53) <- 192.168.40.81:41940 SINGLE:MULTIPLE age 00:00:36, expires in 00:01:54, 1:1 pkts, 60:106 bytes, rule 1173 id: a6851b6300000002 creatorid: 5f2a04ac gateway: 0.0.0.0 origif: bridge1
It isn't. That state shows the destination is translated to 192.168.40.5 for both 8.8.8.8 and 8.8.4.4 which I imagine is what you want.
The rule number is shown at the beginning of the entry, so this is rule 37:
Those rogue states are almost certainly being passe by one of the internal 'allow out' rules not a user rule. That's why you will need to use a floating outbound rule to block it.
I would change that floating rule to be on the VoIP VLAN only since those are the only states actually causing an issue and being more precise there is less likely to cause problems later.
Though it looks like you understood what I meant since I used the wrong alias there and you have used the correct ones!Steve
@stephenw10 Yes, that is what I want. Thanks for the clarification.
Made the change. Let you know tomorrow how it goes.Thanks again. Couldn't have got this far without your help.
@stephenw10 worked liked a charm. Thanks so much for all the help. Very much appreciated
Nice result!
