    "tun_wg0: loop detected" following WireGuard gateway 100% loss and WAN interface rc.newwanip
    29 Posts 3 Posters 9.9k Views 2 Watching
      Mixka
      Problem is that some times per day (around three to six) I get system log spammed "tun_wg0: loop detected" following WireGuard gateway 100% loss and WAN interface rc.newwanip (even IP did not change).
      I have now used tremendous amount of hours to trying to solve this problem. Simplified config much as I can, tried different settings, rebooted machine many times, google'd about this problem, etc...
      I am using latest stable 2.6.0 version. WireGuard package is also latest 0.1.6_2.
      Here is WG peer settings:
      WG interface:
      Interface groups: (Should there be members in WireGuard group?)
      Static route:
      WG gateway:
      Addittional settings if it helps to pin down problem:
      Reason for static route is that I have WG GW as my default GW. All trafic from LAN is supposed to go through WG VPN. Firewall rule LAN to outside have tagging and another rule which reject every tagged traffic to WAN. Everything seems to be working as it should.
      Does anythign looks off or does anything comes to mind what to check?
      Any help is really appreciated!
      Logs of two occurances:
      Aug 4 09:44:52 	check_reload_status 	484 	Reloading filter
      Aug 4 09:44:52 	check_reload_status 	484 	Restarting OpenVPN tunnels/interfaces
      Aug 4 09:44:52 	check_reload_status 	484 	Restarting IPsec tunnels
      Aug 4 09:44:52 	check_reload_status 	484 	updating dyndns *SNIP*GW
      Aug 4 09:44:52 	rc.gateway_alarm 	30334 	>>> Gateway alarm: *SNIP*GW (Addr:1.1.1.1 Alarm:0 RTT:1.709ms RTTsd:1.061ms Loss:12%)
      Aug 4 09:43:07 	kernel 		tun_wg0: loop detected
      Aug 4 09:43:06 	kernel 		tun_wg0: loop detected
      Aug 4 09:43:06 	check_reload_status 	484 	Reloading filter
      Aug 4 09:43:06 	check_reload_status 	484 	Restarting OpenVPN tunnels/interfaces
      Aug 4 09:43:06 	check_reload_status 	484 	Restarting IPsec tunnels
      Aug 4 09:43:06 	check_reload_status 	484 	updating dyndns *SNIP*GW
      Aug 4 09:43:06 	rc.gateway_alarm 	64108 	>>> Gateway alarm: *SNIP*GW (Addr:1.1.1.1 Alarm:1 RTT:1.417ms RTTsd:.426ms Loss:21%)
      Aug 4 09:43:05 	kernel 		tun_wg0: loop detected
      Aug 4 09:43:04 	kernel 		tun_wg0: loop detected
      Aug 4 09:43:03 	kernel 		tun_wg0: loop detected
      Aug 4 09:43:02 	kernel 		tun_wg0: loop detected
      Aug 4 09:43:01 	kernel 		tun_wg0: loop detected
      Aug 4 09:43:00 	kernel 		tun_wg0: loop detected
      Aug 4 09:42:59 	kernel 		tun_wg0: loop detected
      Aug 4 09:42:45 	check_reload_status 	484 	Reloading filter
      Aug 4 09:42:45 	php-fpm 	446 	/rc.newwanip: rc.newwanip: on (IP address: *SNIP*) (interface: WAN1[wan]) (real interface: igb0).
      Aug 4 09:42:45 	php-fpm 	446 	/rc.newwanip: rc.newwanip: Info: starting on igb0.
      Aug 4 09:42:44 	kernel 		tun_wg0: loop detected
      Aug 4 09:42:44 	check_reload_status 	484 	rc.newwanip starting igb0
      Aug 4 09:42:43 	kernel 		tun_wg0: loop detected
      Aug 4 09:42:43 	kernel 		arpresolve: can't allocate llinfo for *SNIP* on igb0
      Aug 4 09:42:42 	kernel 		tun_wg0: loop detected
      Aug 4 09:42:42 	kernel 		arpresolve: can't allocate llinfo for *SNIP* on igb0
      Aug 4 09:42:41 	kernel 		tun_wg0: loop detected
      Aug 4 08:02:26 	check_reload_status 	484 	Reloading filter
      Aug 4 08:02:26 	check_reload_status 	484 	Restarting OpenVPN tunnels/interfaces
      Aug 4 08:02:26 	check_reload_status 	484 	Restarting IPsec tunnels
      Aug 4 08:02:26 	check_reload_status 	484 	updating dyndns *SNIP*GW
      Aug 4 08:02:26 	rc.gateway_alarm 	27596 	>>> Gateway alarm: *SNIP*GW (Addr:1.1.1.1 Alarm:0 RTT:1.319ms RTTsd:.092ms Loss:11%)
      Aug 4 08:02:19 	php 	24641 	[pfBlockerNG] filterlog daemon started
      Aug 4 08:02:19 	tail_pfb 	24365 	[pfBlockerNG] Firewall Filter Service started
      Aug 4 08:02:19 	lighttpd_pfb 	23131 	[pfBlockerNG] DNSBL Webserver started
      Aug 4 08:02:19 	php_pfb 	20548 	[pfBlockerNG] filterlog daemon stopped
      Aug 4 08:02:19 	lighttpd_pfb 	20483 	[pfBlockerNG] DNSBL Webserver stopped
      Aug 4 08:02:19 	tail_pfb 	20298 	[pfBlockerNG] Firewall Filter Service stopped
      Aug 4 08:02:18 	php-fpm 	445 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] Applied package default settings as necessary.
      Aug 4 08:02:18 	php-fpm 	445 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] Installed Unbound ACL group (WireGuard).
      Aug 4 08:02:18 	php-fpm 	445 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] De-installed Unbound ACL group (WireGuard).
      Aug 4 08:02:18 	php-fpm 	445 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] Installed interface group (WireGuard).
      Aug 4 08:02:18 	php-fpm 	445 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] De-installed interface group (WireGuard).
      Aug 4 08:02:18 	check_reload_status 	484 	Syncing firewall
      Aug 4 08:02:18 	php-fpm 	445 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] Installed earlyshellcmd(s).
      Aug 4 08:02:18 	php 	96980 	haproxy: started new pid:99506
      Aug 4 08:02:18 	php 	96980 	haproxy: reload old pid:47840
      Aug 4 08:02:18 	php-fpm 	445 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] De-installed earlyshellcmd(s).
      Aug 4 08:02:18 	php-fpm 	445 	/rc.start_packages: Restarting/Starting all packages.
      Aug 4 08:02:17 	check_reload_status 	484 	Starting packages
      Aug 4 08:02:17 	php-fpm 	93998 	/rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - 0.0.0.0 -> *SNIP* - Restarting packages.
      Aug 4 08:02:14 	php-fpm 	93998 	/rc.newwanip: Creating rrd update script
      Aug 4 08:02:14 	php-fpm 	93998 	/rc.newwanip: Resyncing OpenVPN instances for interface WAN1.
      Aug 4 08:02:13 	php-fpm 	93998 	/rc.newwanip: phpDynDNS (*SNIP*): No change in my IP address and/or 25 days has not passed. Not updating dynamic DNS entry.
      Aug 4 08:02:09 	php-fpm 	93998 	/rc.newwanip: IP Address has changed, killing all states (ip_change_kill_states is set).
      Aug 4 08:02:09 	check_reload_status 	484 	Reloading filter
      Aug 4 08:02:09 	check_reload_status 	484 	Restarting OpenVPN tunnels/interfaces
      Aug 4 08:02:09 	check_reload_status 	484 	Restarting IPsec tunnels
      Aug 4 08:02:09 	check_reload_status 	484 	updating dyndns *SNIP*GW
      Aug 4 08:02:09 	rc.gateway_alarm 	74833 	>>> Gateway alarm: *SNIP*GW (Addr:1.1.1.1 Alarm:1 RTT:0.000ms RTTsd:0.000ms Loss:100%)
      Aug 4 08:02:08 	php-fpm 	93998 	/rc.newwanip: Removing static route for monitor 1.1.1.1 and adding a new route through *SNIP*.2
      Aug 4 08:02:08 	php-fpm 	93998 	/rc.newwanip: Removing static route for monitor 8.8.4.4 and adding a new route through *SNIP*
      Aug 4 08:02:07 	php-fpm 	93998 	/rc.newwanip: rc.newwanip: on (IP address: *SNIP*) (interface: WAN1[wan]) (real interface: igb0).
      Aug 4 08:02:07 	php-fpm 	93998 	/rc.newwanip: rc.newwanip: Info: starting on igb0.
      Aug 4 08:02:06 	check_reload_status 	484 	rc.newwanip starting igb0
      Aug 4 08:02:06 	kernel 		tun_wg0: loop detected
      Aug 4 08:02:06 	kernel 		arpresolve: can't allocate llinfo for *SNIP* on igb0
      Aug 4 08:02:05 	kernel 		arpresolve: can't allocate llinfo for *SNIP* on igb0
      Aug 4 08:02:05 	kernel 		tun_wg0: loop detected
      Aug 4 08:02:04 	kernel 		tun_wg0: loop detected
        Hmm, so you see this when the WAN gateway goes down causing the WG tunnel to fail?
          Mixka @stephenw10
          I do not see WAN gateway going down. When problem occurs WAN gateway have 0% loss when WG gateway at same time 100%. I also tried to disable WAN gateway monitoring, but logs and problem is still the same.
          I do not know if its related or not (maybe not), but today some LAN clients were totally offline (could not even ping to pfSense box). All had IP's assigned so that was not the case. I pin down problem that they all was behind same dummy switch. I restarted that switch and everything worked like 2 minutes and then goes down. I removed that switch and everything back to normal. After that my original problem stayed away about 12 hours which is very long. I was almost celebrating, but then see those log messages again.
          I also looked firewall logs and there was also spammed new lines. Have not seen any "let out anything from firewall host itself" before. For some reason some LAN traffic seems to originating from WG interface, which I think is strange. There are DNS and HTTPS destination.
          Logs:
            You would only see that if you have Log packets matched from the default pass rules put in the ruleset set in the log settings.
            With that set you are seeing log entries for all the traffic from WG clients leaving the WAN. Probably, since I can't see the interface or IPs in the connection.
              Mixka @stephenw10
              Thanks. Do not remember to touch on that settings. I did change "Log Rotation Size" recently. I had same as this one https://forum.netgate.com/topic/169923/tons-sshguard-log-entries-and-its-not-enabled
              That anyway did not fix/change my original problem.
                Yup, that wouldn't be related to the loop issue, just confusing the logs.
                This entry implies there is no longer a subnet on igb0 for the gateway yto be added in:
                I assume igb0 is the WAN?
                If you disable 'State Killing on Gateway Failure' does that stop the loop errors?
                M 2 Replies Last reply Reply Quote 0
                  Mixka @stephenw10
                  Actually those "arpresolve" messages have been non-existing for couple of days. Trying now anyway to disable "State Killing on Gateway Failure" option. Let see how it works. Thanks!
                    Mixka @stephenw10
                    Loop messages still continues...
                    Log (removed some lines and code tags, because it was getting marked as spam):
                    Aug 8 02:47:23 check_reload_status 487 Reloading filter
                    Aug 8 02:47:23 check_reload_status 487 Restarting OpenVPN tunnels/interfaces
                    Aug 8 02:47:23 check_reload_status 487 Restarting IPsec tunnels
                    Aug 8 02:47:23 check_reload_status 487 updating dyndns WG_VPN_GW
                    Aug 8 02:47:23 rc.gateway_alarm 25152 >>> Gateway alarm: WG_VPN_GW (Addr:1.1.1.1 Alarm:0 RTT:1.316ms RTTsd:.151ms Loss:12%)
                    Aug 8 02:45:36 kernel tun_wg0: loop detected
                    Aug 8 02:45:34 check_reload_status 487 Reloading filter
                    Aug 8 02:45:34 check_reload_status 487 Restarting OpenVPN tunnels/interfaces
                    Aug 8 02:45:34 check_reload_status 487 Restarting IPsec tunnels
                    Aug 8 02:45:34 check_reload_status 487 updating dyndns WG_VPN_GW
                    Aug 8 02:45:34 rc.gateway_alarm 68371 >>> Gateway alarm: WG_VPN_GW (Addr:1.1.1.1 Alarm:1 RTT:1.597ms RTTsd:1.754ms Loss:21%)
                    Aug 8 02:45:34 kernel tun_wg0: loop detected
                    Aug 8 02:45:12 check_reload_status 487 Reloading filter
                    Aug 8 02:45:12 php-fpm 448 /rc.newwanip: rc.newwanip: on (IP address: SNIP) (interface: WAN1[wan]) (real interface: igb0).
                    Aug 8 02:45:12 php-fpm 448 /rc.newwanip: rc.newwanip: Info: starting on igb0.
                    Aug 8 02:45:12 kernel tun_wg0: loop detected
                    Aug 8 02:45:11 check_reload_status 487 rc.newwanip starting igb0
                    Aug 8 02:45:11 kernel tun_wg0: loop detected
                    Aug 8 02:37:26 check_reload_status 487 Reloading filter
                      Jarhead @Mixka
                      @mixka You're static route is using your WAN DHCP gateway, should be the WG gateway.
                        Mixka @Jarhead
                        @jarhead
                        No. WG gateway is default gateway and it's need route to out via WAN gateway.
                          Jarhead @Mixka
                          @mixka Right, it will. But the peer is on the other end of the tunnel, correct? It should use the WG gateway, then you have the WG gateway set as the upstream gateway in the interface or maybe I'm missing something. You have a lot redacted that doesn't need to be.
                            Mixka @Jarhead
                            @jarhead
                            I'm new with WG (this abbreviation always got me, because WG is WatchGuard for me 😄) so this setup might be wrong in many places. I applied this guide for my use https://youtu.be/wYe7FzZ_0X8 (not using Mullvad).
                            What might be right way to use WG gateway as default gateway? Peer endpoint is in public domain and interface+gateway private.
                              Yes, the static route for subnets at the remote end of the tunnel must be the Wireguard gateway.
                              The public peer end point IP would not normally need a static route. The only reason you might need that is if you change the system default route to be the Wireguard gateway. I would not recommend doing that though.
                                Jarhead @Mixka
                                @mixka Use this:
                                https://youtu.be/2oe7rTMFmqc
                                  Mixka @Jarhead
                                  @jarhead
                                  Golden video as Christians videos always are. But I can't see relations to my setup there (other than that WG is used to make tunnel). Video anyway explains routes and NAT's nicely.
                                  So, setup is somewhat right, but not recommended. I see, but goal is to use WG gateway as default route, so recommended or not this is the way.
                                  Anything else to test out?
                                  I also found when started to look other logs, that ntpd have log lines just after first "loop detected" message is timestamped. Is it root cause or just following system melt down?
                                  Log:
                                  Aug 8 20:16:14 	check_reload_status 	487 	Reloading filter
                                  Aug 8 20:14:26 	kernel 		tun_wg0: loop detected
                                  Aug 8 20:14:05 	ntpd 	1691 	Listen normally on 25 igb0 80.221.147.161:123
                                  Aug 8 20:14:02 	ntpd 	1691 	Deleting interface #24 igb0, 80.221.147.161#123, interface stats: received=0, sent=0, dropped=0, active_time=14804 secs
                                  Aug 8 20:14:01 	kernel 		tun_wg0: loop detected
                                  Aug 8 16:09:28 	check_reload_status 	487 	Reloading filter
                                  Aug 8 16:07:42 	kernel 		tun_wg0: loop detected
                                  Aug 8 16:07:18 	ntpd 	1691 	Listen normally on 24 igb0 80.221.147.161:123
                                  Aug 8 16:07:16 	ntpd 	1691 	Deleting interface #23 igb0, 80.221.147.161#123, interface stats: received=0, sent=0, dropped=0, active_time=14756 secs
                                  Aug 8 16:07:15 	kernel 		tun_wg0: loop detected
                                  Aug 8 12:03:30 	check_reload_status 	487 	Reloading filter
                                  Aug 8 12:01:44 	kernel 		tun_wg0: loop detected
                                  Aug 8 12:01:20 	ntpd 	1691 	Listen normally on 23 igb0 80.221.147.161:123
                                  Aug 8 12:01:18 	ntpd 	1691 	Deleting interface #22 igb0, 80.221.147.161#123, interface stats: received=0, sent=0, dropped=0, active_time=1782 secs
                                  Aug 8 12:01:17 	kernel 		tun_wg0: loop detected
                                    Mmm, it's unclear where the loop is being created there but I'd have to guess it's because the system default route is switched back to the WAN when the WG gateway goes down and you have something else routing traffic back.
                                    Do you have the default gateway set specifically to the WG gateway or to a group?
                                      Jarhead @Mixka
                                      @mixka Did you fix the WG config? That's what the video was for.
                                      From what I can see, you need to remove the upstream gateway on the interface and correct the static route.
                                        Mixka @stephenw10
                                        Specifically to WG gateway.
                                        @Jarhead
                                        I found out that video really helpful, but not on my case. I do not want to remove upstream gateway, because traffic out of tunnel needs to be NAT'd. Or does NAT rules still operate even upstream gateway is disabled? What does it help in that case? That video did not mention. And what comes to static route, I think there is no things to correct. In video WAN gateway was used and I need to use WG as my gateway.
                                          If you have a gateway on the interface automatic outbound NAT will be applied but you can still add manual rules to an interface that has no gateway.
                                          You need a gateway there to use as the default route or to add policy routing for but it doesn't have to be on the interface itself. However I wouldn't expect it to make any difference.
                                            Mixka
                                            It's been long days trying to solve this. I even deleted all firewall rules and redo only basic setup.
                                            I have for example tried these:
                                            • Disable NTP: No affect
                                            • Disable WG interface upstream gateway: Interface errors out statistics goes down by ~90%
                                            • Disable Negate rules: No affect
                                            • Disable gateways monitoring: After that it did not recover from loop
                                            • Started firewall rules from scrach with basic setup: Maybe loop occurances are lower, or not...
                                            • Put "supersede interface-mtu 0" to WAN interface DHCP option modifiers: Definately made loop occurance lower, or maybe just coincidence
                                            Now I did get 15 hours before problem occured after reboot.
                                            Should I try to play with WAN interface DHCP protocol timing or other options? Connection is optical fiber 100/100M.
                                            I also found this Reddit post https://reddit.com/r/PFSENSE/comments/ln14gu/arpresolve_cant_allocate_llinfo_ip_crippling_wan
                                            Should I try dumb switch before WAN interface and what difference it might doing? I do not think this is tagged traffic anyway.
                                            I just did speedtest with different services and my connection speed is low like 8/30M. I have run speedtest often and haven't got problems before. I think only thing what I have changed after last time is that DHCP option modifier.
                                            During speedtest:
                                            I have had traffic shaper, but disabling it won't help any. I do not know if this is related in anyway, but is this right way to reduce buffer bloating? It is (was) working really well for me. https://forum.netgate.com/topic/112527/playing-with-fq_codel-in-2-4/775
                                            And I have this spam for 1000 lines per minute:
                                            (51820 is WG peer endpoint port and 43279 is WG tunnel listening port)
                                            Aug 14 14:06:00 	WAN1 	Default deny rule IPv4 (1000000103) 	*WG_Endpoint_IP*:51820		*WAN_Interface_IP*:43279		UDP
                                            Should I allow this traffic or is there misconfiguration?
                                            I have now used way over 50 hours to trying to solve this. I am even thinking to clear install whole box. I do not know what to do. I have tried everything and problems just pile up.
                                            Loop occurance:
                                            Aug 14 10:18:34 	check_reload_status 	484 	Reloading filter
                                            Aug 14 10:18:34 	check_reload_status 	484 	Restarting OpenVPN tunnels/interfaces
                                            Aug 14 10:18:34 	check_reload_status 	484 	Restarting IPsec tunnels
                                            Aug 14 10:18:34 	check_reload_status 	484 	updating dyndns *WG_GW*
                                            Aug 14 10:18:34 	rc.gateway_alarm 	17746 	>>> Gateway alarm: *WG_GW* (Addr:8.8.8.8 Alarm:0 RTT:7.390ms RTTsd:36.380ms Loss:11%)
                                            Aug 14 10:18:25 	php 	14097 	[pfBlockerNG] filterlog daemon started
                                            Aug 14 10:18:25 	tail_pfb 	13938 	[pfBlockerNG] Firewall Filter Service started
                                            Aug 14 10:18:25 	lighttpd_pfb 	12699 	[pfBlockerNG] DNSBL Webserver started
                                            Aug 14 10:18:25 	php_pfb 	10645 	[pfBlockerNG] filterlog daemon stopped
                                            Aug 14 10:18:25 	lighttpd_pfb 	10375 	[pfBlockerNG] DNSBL Webserver stopped
                                            Aug 14 10:18:25 	tail_pfb 	10461 	[pfBlockerNG] Firewall Filter Service stopped
                                            Aug 14 10:18:24 	php-fpm 	30665 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] Applied package default settings as necessary.
                                            Aug 14 10:18:24 	php-fpm 	30665 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] Installed Unbound ACL group (WireGuard).
                                            Aug 14 10:18:24 	php-fpm 	30665 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] De-installed Unbound ACL group (WireGuard).
                                            Aug 14 10:18:24 	php-fpm 	30665 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] Installed interface group (WireGuard).
                                            Aug 14 10:18:24 	php-fpm 	30665 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] De-installed interface group (WireGuard).
                                            Aug 14 10:18:24 	check_reload_status 	484 	Syncing firewall
                                            Aug 14 10:18:24 	php-fpm 	30665 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] Installed earlyshellcmd(s).
                                            Aug 14 10:18:24 	php-fpm 	30665 	/rc.start_packages: Configuration Change: (system): [pfSense-pkg-WireGuard] De-installed earlyshellcmd(s).
                                            Aug 14 10:18:24 	php 	83866 	haproxy: started new pid:87304
                                            Aug 14 10:18:24 	php 	83866 	haproxy: reload old pid:42610
                                            Aug 14 10:18:23 	php-fpm 	30665 	/rc.start_packages: Restarting/Starting all packages.
                                            Aug 14 10:18:22 	check_reload_status 	484 	Starting packages
                                            Aug 14 10:18:22 	php-fpm 	10714 	/rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - 0.0.0.0 -> *WAN_Interface_IP* - Restarting packages.
                                            Aug 14 10:18:20 	php-fpm 	10714 	/rc.newwanip: Creating rrd update script
                                            Aug 14 10:18:20 	php-fpm 	10714 	/rc.newwanip: Resyncing OpenVPN instances for interface WAN1.
                                            Aug 14 10:18:15 	php-fpm 	10714 	/rc.newwanip: IP Address has changed, killing all states (ip_change_kill_states is set).
                                            Aug 14 10:18:15 	check_reload_status 	484 	Reloading filter
                                            Aug 14 10:18:15 	check_reload_status 	484 	Restarting OpenVPN tunnels/interfaces
                                            Aug 14 10:18:15 	check_reload_status 	484 	Restarting IPsec tunnels
                                            Aug 14 10:18:15 	check_reload_status 	484 	updating dyndns *WG_GW*
                                            Aug 14 10:18:15 	rc.gateway_alarm 	70659 	>>> Gateway alarm: *WG_GW* (Addr:8.8.8.8 Alarm:1 RTT:0.000ms RTTsd:0.000ms Loss:100%)
                                            Aug 14 10:18:13 	php-fpm 	10714 	/rc.newwanip: Removing static route for monitor 8.8.8.8 and adding a new route through *WG_GW_IP*
                                            Aug 14 10:18:13 	php-fpm 	10714 	/rc.newwanip: Removing static route for monitor 8.8.4.4 and adding a new route through *WAN_GW_IP*
                                            Aug 14 10:18:11 	php-fpm 	10714 	/rc.newwanip: rc.newwanip: on (IP address: *WAN_Interface_IP*) (interface: WAN1[wan]) (real interface: igb0).
                                            Aug 14 10:18:11 	php-fpm 	10714 	/rc.newwanip: rc.newwanip: Info: starting on igb0.
                                            Aug 14 10:18:10 	check_reload_status 	484 	rc.newwanip starting igb0
                                            Aug 14 10:18:10 	kernel 		tun_wg0: loop detected
                                            Aug 14 10:18:10 	kernel 		arpresolve: can't allocate llinfo for *WAN_GW_IP* on igb0
                                            Aug 14 10:18:09 	kernel 		tun_wg0: loop detected
                                            Aug 14 10:18:09 	kernel 		arpresolve: can't allocate llinfo for *WAN_GW_IP* on igb0
                                            Aug 14 10:18:08 	kernel 		tun_wg0: loop detected
                                            Aug 14 10:18:08 	kernel 		arpresolve: can't allocate llinfo for *WAN_GW_IP* on igb0
                                            Aug 14 10:18:34 	dpinger 	65033 	*WG_GW* 8.8.8.8: Clear latency 7390us stddev 36380us loss 11%
                                            Aug 14 10:18:15 	dpinger 	65033 	*WG_GW* 8.8.8.8: Alarm latency 0us stddev 0us loss 100%
                                            Aug 14 10:18:13 	dpinger 	65033 	send_interval 500ms loss_interval 2000ms time_period 60000ms report_interval 0ms data_len 1 alert_interval 1000ms latency_alarm 500ms loss_alarm 20% dest_addr 8.8.8.8 bind_addr *WG_Interface_IP* identifier "*WG_GW*"
                                            Aug 14 10:18:13 	dpinger 	64735 	send_interval 500ms loss_interval 2000ms time_period 60000ms report_interval 0ms data_len 1 alert_interval 1000ms latency_alarm 500ms loss_alarm 20% dest_addr 8.8.4.4 bind_addr *WAN_Interface_IP* identifier "WAN_DHCP"
