    openvpn doesn't connect if there was a power loss
    3 Posts 2 Posters 644 Views 2 Watching
    • F Offline
      fabio1999ita
      i'm using pfsense 2.6 and if there are a power loss or for a test i switch off the power after boot the openvpn is not able to connect (i have 2 client and 1 server in same machine), the only workaround that i find is restart the 3th (2 client 1 server) openvpn services
      with a normal reboot all works fine
      • V Offline
        viragomann @fabio1999ita
        @fabio1999ita said in openvpn doesn't connect if there was a power loss:
        Switch of the power of pfSense only or even of a device like a router in front of it?
        And none of them is reconnecting?
        • F Offline
          fabio1999ita @viragomann
          @viragomann said in openvpn doesn't connect if there was a power loss:
          pfsense is installed in a computer so power of computer
          none get auto reconnect, need to do manually for make reconnect
