PFsense with VLANs > Brocade switch > Devices and Unifi Controller/APs
@dabdad You have to untag it with vlan 6. You're untagging it with vlan1.
There should be a pvid setting in your switch. For ports 1-24 the pvid should be 6.
If you use the cli of your switch the command's are here
https://www.alteeve.com/w/Configuring_Brocade_Switches#Configure_VLAN -
@jarhead said in PFsense with VLANs > Brocade switch > Devices and Unifi Controller/APs:
VLANs per console layout:
port 25 is tagged in each vlan
drilling into port 24 within the GUI:
it says VLAN 6 and registered as tagged.
I'm not seeing any issues with the switch
I was able to get the switch ports to grab the correct IP based on the VLAN assigned.
I swapped the interfaces within pfsense to the 'new' interfaces that were created when i created the additional vSwitches within HyperV. thanks @AndyRH for the recommendation.
THEN.. i had to go to each port and select IEEE tagging to "untag".
This was a pain as you have to go to each port and switch this setting. i tried within the console but no luck in doing it en mass then either. Thank @Jarhead for the info here, pretty sure this is what you were referring to.
Now, the APs are connected via Port 47 and 48 with POE enabled on those ports.
I tried to trunk them but this seems to be a limitation within the switch? its only allow me to trunk a single port..which right now is port 25 for the uplink to pfsense.
the controller/aps are not passing the correct tagged traffic through those ports to pfsense, wifi devices on 2 SSID's are still not resolving. any thoughts here would be appreciated. -
@dabdad It works??? Imagine that!
Can you believe how much time you could've saved just by listening?There's no way you can only trunk one port in that switch.
Set both ports to dual and add the vlans as needed. -
@jarhead By listening? interesting..
While i appreciate your help, i dont appreciate the sassyness of your comment. To be honest, Your replys are hard to understand and most of them contradict what was already mentioned in my OP. Again, thank you for your help, but if you are wanting to be negative in some manner, then why help at all? -
@dabdad Funny, I got you as being the negative one.
Every reply I made never contradicted a thing.
And if you had listened to my very first post, none of the others would have been needed.
But glad you got it working.
