    half network speed after upgrading
    Scheduled Pinned Locked Moved Plus 23.01 Development Snapshots (Retired)
    25 Posts 4 Posters 3.5k Views 5 Watching
      High_bounce
      it changes the options for the interface but no change in throughput. also i changed boot environment back to 22.05 to check for differences i found a few i have no idea if they make a difference:
      boot logs
      23.01 8 txq/rxq, 22 MSI-X, 46eq, 21iq
      22.05 4 txq/rxq, 14 MSI-X, 30eq, 13iq
      ifconfig looks all the same but 23.01 has an option called "NOMAP" i am not sure what it means and cant find anything online about it
        NOMAP is to allow unmapped mbufs. I don't expect it to make any difference but I can't find any way to disable it! It looks like you should be able to ifconfig cxl0 -nomap but that doesn't work for me.
        You can almost certainly tune the queues back to 4x in the sysctls/tunables but it's hard to imagine that would help. 22 MSI-X interrupts.... I couldn't say but again it's hard to see how more would be worse.
        If you run top -HaSP during a test do you see the loading spread across the cores correctly?
          High_bounce
          no change in cpu utilisation im still at a lost as to cause are you able to replicate on your end?
            I don't have a Chelsio 10GBase-T NIC to test with unfortunately. But I haven't seen anything like that on any other NICs.
              High_bounce
              no worries i just switch to an old intel x540-t2 should be fine until i upgrade the rest of my network to multi-gig thank you for all your help. i hope it gets fixed at some point i have always herd that Chelsio nics were the best with bsd maybe that is changing now
              • B battlebot32 referenced this topic on
