    Problem configuration OpenVPN
    42 Posts 4 Posters 14.8k Views 4 Watching
      kilian77 @johnpoz
      @johnpoz my ISP router: 192.168.10.1
      my pfsense WAN port: 192.168.10.22
      my pfsesne LAN port: 192.168.1.1
        Gertjan @kilian77
        @kilian77 said in Problem configuration OpenVPN:
        Ok, that's fine.
        As that is what I have.
        My pfSense WAN IP (DHCP) is :
        What about the other Livebox settings ?
        You've set a DMZ ?
        What is the firewall setting ?
        I use :
        This (uPNP) has been shut down :
        as, as it says (translation) : this option can make your live hard ...
        Nothing here :
        As said earlier :
        Because 'why not'. (pfSense is the only LAN device of my Livebox [except the Orange TV decoder ])
        If with these settings you still won't fine a solution.
        RESET the Livebox (and do not restore faulty settings back in !!).
        You have to give manually the fti/xxxxxxxx and the connection ISP password
        Make the connection work.
        Then change the LAN network from 192.168.1.1/24 to 192.168.10.1/24
        And make that work - test with pfSense.
        Then : make the NAT OpenVPN rule UDP to pfSense, port 1194.
        And test.
        It is and should be as easy as that.
        Remember : These Livoboxes are world's most stupid ISP routers on the planet.
        It still does't work : throw it out of the windows.
        Call 3901 (Orange Support).
        And also : visit the neigbor : test at his place.
        Or come pay me a visit, I'll show you.
