    dpinger problem after powerfail system startup
    Scheduled Pinned Locked Moved Plus 23.05 Development Snapshots (Retired)
    9 Posts 3 Posters 3.1k Views 3 Watching
      tedquade
      23.05-RC (amd64)
      built on Tue May 09 22:45:57 UTC 2023
      FreeBSD 14.0-CURRENT
      After a complete system shutdown after a power failure, on powerup, dpinger was stuck pounding away on 192.168.0.1 and not the proper default gateway. There was proper connectivity to the ISP and beyond. Gateways status showed off-line even though the system was on-line.
      Status > Services > dpinger restart corrected the errant Gateways status.
      Ted
        What is 192.168.0.1? Cable modem?
          tedquade @stephenw10
          @stephenw10 That's my guess but no proof. Modem status is 192.168.100.1. It's a Hitron coda 4582 in bridge mode. Internal lan IP is 192.168.0.1 when used as a wireless router/cable modem.
          Ted
            rcoleman-netgate Netgate @tedquade
            @tedquade Look at https://docs.netgate.com/pfsense/en/latest/interfaces/configure-ipv4.html#dhcp and the "reject leases from" header.
            Ryan
            Wireless: Aruba, Ubiquiti
              tedquade @rcoleman-netgate
              @rcoleman-netgate In my case should I set that to 192.168.0.1 or ?
              Ted
                @tedquade Check your DHCP logs to see what system gave you the 192.168.0.x IP and set it to that.
                Ryan
                  @rcoleman-netgate Looks like 192.168.0.1 is the culprit.
                  DHCP log is as follows:
                  May 10 14:23:00 dhclient 26539 DHCPOFFER from 192.168.0.1
                  May 10 14:23:02 dhclient 26539 DHCPACK from 192.168.0.1
                  May 10 14:23:02 dhclient 33064 ifconfig igc0 inet 192.168.0.13 netmask 255.255.255.0 broadcast 192.168.0.255
                  May 10 14:23:02 dhclient 33632 New IP Address (igc0): 192.168.0.13
                  May 10 14:23:02 dhclient 33907 New Broadcast Address (igc0): 192.168.0.255
                  May 10 14:23:02 dhclient 34176 New Routers (igc0): 192.168.0.1
                  May 10 14:23:02 dhclient 26539 bound to 192.168.0.13 -- renewal in 15 seconds.
                  May 10 14:23:17 dhclient 36373 DHCPREQUEST on igc0 to 192.168.0.1 port 67
                  May 10 14:23:17 dhclient 36373 DHCPACK from 192.168.0.1
                  May 10 14:23:17 dhclient 36373 bound to 192.168.0.13 -- renewal in 14 seconds.
                  May 10 14:23:31 dhclient 36373 DHCPREQUEST on igc0 to 192.168.0.1 port 67
                  May 10 14:23:31 dhclient 36373 DHCPACK from 192.168.0.1
                  May 10 14:23:31 dhclient 36373 bound to 192.168.0.13 -- renewal in 14 seconds.
                  May 10 14:23:45 dhclient 36373 DHCPREQUEST on igc0 to 192.168.0.1 port 67
                  May 10 14:23:45 dhclient 36373 DHCPACK from 192.168.0.1
                  May 10 14:23:45 dhclient 36373 bound to 192.168.0.13 -- renewal in 14 seconds.
                  May 10 14:23:59 dhclient 36373 DHCPREQUEST on igc0 to 192.168.0.1 port 67
                    Yup, reject leases from that. At least it only gives you a 30s lease though.
                    T 1 Reply Last reply Reply Quote 2
                      @stephenw10 Done.
                      Ted
