    pfSense as wireless AP transmit power adjustments?
    45 Posts 4 Posters 11.6k Views 4 Watching
    • provelsP Offline
      provels @JonathanLee
      @JonathanLee Weird, but whatever works. With ng I get a -40db signal, with na I get -70.
      Peder
      MAIN - pfSense+ 25.07.1-RELEASE - Adlink MXE-5401, i7, 16 GB RAM, 64 GB SSD. 500 GB HDD for SyslogNG
      BACKUP - pfSense+ 23.01-RELEASE - Hyper-V Virtual Machine, Gen 1, 2 v-CPUs, 3 GB RAM, 8GB VHDX (Dynamic)
        5Ghz is more easily attenuated by anything.
        • JonathanLeeJ Offline
          JonathanLee @johnpoz
          @johnpoz
          It is the same upstream.
          https://github.com/freebsd/freebsd-src/pull/880
          https://redmine.pfsense.org/issues/14925
          Make sure to upvote
          provelsP 1 Reply Last reply Reply Quote 0
          • provelsP Offline
            @JonathanLee Is this the Compex or the Apple card? I have the Compex and my txpower was set at 30 by pfSense. Also, the "txpower 40" argument seems to have no effect, stays at 30 for me.
            Maybe that's because you're using na and not ng. EDIT - Yeah, that's it.
            [23.05.1-RELEASE][root@fw.workgroup]/root: ifconfig ath0_wlan0 txpower 40
            ath0_wlan0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
                    description: ATH0_WLE200
                    ether 04:f0:21:4f:6e:e3
                    inet6 fe80::6f0:21ff:fe4f:6ee3%ath0_wlan0 prefixlen 64 scopeid 0x9
                    groups: wlan
                    ssid WIFI_LAN_nomap channel 11 (2462 MHz 11g ht/20) bssid 04:f0:21:4f:6e:e3
                    regdomain FCC country US indoor ecm authmode WPA2/802.11i
                    privacy MIXED deftxkey 3 AES-CCM 2:128-bit AES-CCM 3:128-bit
            =>        txpower 30 scanvalid 60 pureg protmode OFF ampdulimit 64k
                    ampdudensity 8 shortgi puren -ldpc -uapsd wme burst -apbridge
                    dtimperiod 1 -dfs
                    parent interface: ath0
                    media: IEEE 802.11 Wireless Ethernet autoselect mode 11ng <hostap>
                    status: running
            Peder
              JonathanLee @provels
              @provels
              @provels Take a look at this file with the built in editor in pfsense GUI
              This may have blocked you from turning it up. It might be limited by way of this file. . .
              Scroll down and find WiFi 11g and check for something called max power
              Make sure to upvote
