    23.09.01 Hardware Crypto showing No Hardware Crypto Acceleration for system with crypto chip installed
    41 Posts 6 Posters 8.1k Views 7 Watching
      Hmm, those seem very low numbers. I can't imagine you'd be able to see the difference at those rates.
      • JonathanLeeJ Offline
        JonathanLee @stephenw10
        @stephenw10 low bill too :) that ID error is why I think it has issues would ath0 cause this ?
        Make sure to upvote
          No this is nothing to do with the ath card or newer 2100s without the crypto cert device. OpenSSL no longer supports BSD cryptodev as an engine so the option to select it was removed from OpenVPN for all hardware.
          Which ID error are you referring to?
            The id error shows on 23.09.01 every time does not show in 23.05.01
            Make sure to upvote
              Ah OK. That seems unlikely to be related to the crypto hardware. If you disable safeXcel but keep DCO enabled does it still show?
                @stephenw10 I have to swap boot environments when my wife goes to work after that I can check.
                To confirm you want me to disable the chip on the advanced menu?
                Make sure to upvote
                  Yes, then boot so the safexcel module is not loaded. Then check the openvpn logs again. I expect that ID error to still be present.
                    @stephenw10 side note, can I do a boot environment and load 24 dev os or will that cause issues going back to 23.09?
                    Make sure to upvote
                      Yes you can do that. There's no problem booting back to 23.09.1.
                        Yes this is as you expected. It still occurs with the hardware disabled.
                        Make sure to upvote
                          Ok digging into that. I can only see one other reference to that kind of ID error.
                          Is that process an OpenVPN server?
                          How are the clients defined?
                            I also see this id error in my 23.05.01 ssd on connects. I didn’t notice it until today
                            Make sure to upvote
                            PippinP 1 Reply Last reply Reply Quote 0
                            • PippinP Offline
                              Pippin @JonathanLee
                              I see no error in the logs posted above but that aside.....
                              The message
                              dco_update_peer_stat: invalid peer ID 0 returned by kernel
                              is not related to the issue described.
                              This can happen if userland has already forgotten a peer and kernel sends "post-disconnect stats" which seems to be the case
                              openvpn server 'ovpns1' user 'LeeFamilyVPN'address 'x.x.x.x' disconnected
                              right after the message.
                              I gloomily came to the ironic conclusion that if you take a highly intelligent person and give them the best possible, elite education, then you will most likely wind up with an academic who is completely impervious to reality.
                              Halton Arp
                                Yup that's not an error that should ever prevent the service starting or cause connection issues etc.
                                Or has anything to do with hardware crypto support.
                                  @stephenw10 how can I prevent this issue?
                                  Make sure to upvote
                                    You don't have to it's not an error that causes an problems.
                                      petrt3522
                                      I am seeing this same bug on 23.09.1 (I had to do a reinstall last week. This is a Lab/home license, install of 2.7 then upgrade to 23.09.1.) running on an HP thin client with AMD RX-427BB (x64) processor.
                                      The Dashboard show AES + ChaCha Encryptions listed, but under OpenVPN server and clients it lists 'no hardware crypto acceleration' ?? I don't recall the processor usage before so I can not say what the difference is/is not.
                                        That's not a bug. There can never be a crypto accelerator listed there because OpenSSL no longer accepts user mode engines in FreeBSD.
                                        If you have a crypto device that is supported by the cryptodev framework then kernel mode operations will use that. So that's OpenVPN with DCO or IPSec.
                                          keleticsaba
                                          Just did a fresh re-install, what was planned a long ago.
                                          My system:
                                          CPU Type AMD GX-415GA SOC with Radeon(tm) HD Graphics
                                          4 CPUs: 1 package(s) x 4 core(s)
                                          AES-NI CPU Crypto: Yes (active)
                                          QAT Crypto: No
                                          Version 2.7.2-RELEASE (amd64)
                                          The old - but up-to-dated - 2.7.2 install had AES-NI working, after clean install the openvpn can not set hw-crypto :(
                                          (despite it is enabled/active)
                                          dmesg | grep -i aes
                                          Features2=0x3ed8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,F16C>
                                          aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS>
                                          So, as i read the prev. replys it is the new normal, because by kernel it will be used?
                                          But then why was it acting different (can-be selected) before the re-install?
                                            The previous ability to set a hardware device in OpenVPN directly was a holdover from much older versions. It used to be that could set a hardware crypto engine for OpenSSL to use and that setting in OpenVPN passed that through. But that has not been possible for several FreeBSD versions now, that setting no longer did anything.
                                            If your CPU is AES-NI capable OpenSSL will just use it directly without any additional setting.
