    EXAMPLE OF Layer 2 Ethernet Firewall Rules
    3 Posts 1 Posters 749 Views 1 Watching
    • JonathanLeeJ Offline
      JonathanLee
      Hello fellow Netgate community,
      Can someone please help?
      I have an issue with blocking layer 2 traffic on 23.09.01.
      Goal I want the Guest pcie mini wifi card 10.0.0.0/24 to not be able to send layer 2 traffic to the AP secure side 192.168.1.0/27
      This worked in the 23.05.01
      Does anyone have an example of this if I add my default blocks now I get locked out of the GUI they worked before.
      Am I doing something wrong here? These are different broadcast domains I want to add a rule that says block all OPT1 layer 2 traffic to anything else. I just want that traffic to go to the wan and forget about it.
      Any default block I add stops all traffic but I have all the IP addresses accounted for all the subnets I am stumped here.
      If I have 2 different broadcast domains one the PCIE mini card and the other the AP plugged into the marvel switch what is different in 23.09.01 where I can't add my default blocks anymore?
      Make sure to upvote
        JonathanLee
        This seemed to resolve all my issues changing it to address and not subnet. I have my ARP storm protection back it seems.... I wonder what the difference is between address and subnet.
        You can not enter in anything with address also...
        Make sure to upvote
          JonathanLee
          The rule numbers do not change with the added blocks so I do not think it seems them
          Make sure to upvote
