    Trouble with WAN not being able to get correct speed
    69 Posts 4 Posters 12.5k Views 4 Watching
      kilasin
      So here is my problem guys.. I am running Unraid and in my VM i got pfsense . I have allocated my dual 10g nic 1 is for my WAN and the other LAN. I have a 10G switch so all is working fine except I am only getting 1G connection from my WAN. I have read up everything from disablin limiters to mtus i know my nic works fine as I get 10g iperf but why is my WAN only doin 1G? Any help would be greatly appreciated it.
      Best Regards
        Jarhead @kilasin
        @kilasin Are you saying it's only linking at 1g or you're only seeing 1g of bandwidth?
        Is your Internet connection faster then 1g?
        What is your WAN linked to? Your ISP device may only have a 1g port so you'll never link higher than that.
          kilasin @Jarhead
          @Jarhead my connection is 2G and im connected through ppoe bypassin the isps router
            How are you testing where you see 1Gbps?
            How did you run iperf where it showed 10Gbps?
            Do the NICs show as linked at 10G?
            K 2 Replies Last reply Reply Quote 0
              kilasin @stephenw10
              @stephenw10 ok so my LAN link says 10G as shown here:
              fc254425-af7a-4069-8f9e-0a624d953788-image.png now i test iperf as such .. I put my router as a server and my machine as client then i do vise versa. Yes my internet connection should be 2G which ive checked with their wifi router.
                So you are testing iperf from another VM on the LAN side to/from pfSense directly?
                How are you testing the WAN connection?
                Check the WAN parent NIC is linked at the correct speed, run: ifconfig -va
                  kilasin @stephenw10
                  @stephenw10 i tried testin iperf from another VM which i get the real speeds then i tried connectin my makeshift router to my machine directly good speeds just the WAN. However, when i put the isps router i get the exact 2G speeds but unfortuantely the ports are only 1 G only. Hence, I made this router from my old machine 4 10gs cards and 1 2.5G but im gettin capped at 1G speeds which suck. I will try that command thanks.
                    kilasin @stephenw10
                    @stephenw10 There it is.. You are correct i was only connecting at 1G speeds check this out :
                    Now how to change that is the next step lol any help would be greatly appreciate it
                      Jarhead @kilasin
                      @kilasin As I said, verify the device you're plugging into first.
                      There may be a 1g port and a 10g port on it.
                        So you're passing that NIC through to the VM?
                        What is the actual connection here, the physical link?
                        Try running: ifconfig -vvvm ix0 to see what speeds it can link at.
                          kilasin @stephenw10
                          @stephenw10 Yes, I am passing the 10G nic through the VM so Unraid does not see it.
                          The actual connection is being connected to 10G nic card. Here is what I ran from your command
                          ix0: flags=1008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500
                          options=48138b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,HWSTATS,MEXTPG>
                          capabilities=4f53fbb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,NETMAP,RXCSUM_IPV6,TXCSUM_IPV6,HWSTATS,MEXTPG>
                          ether 6c:92:bf:48:c0:a0
                          inet6 fe80::6e92:bfff:fe48:c0a0%ix0 prefixlen 64 scopeid 0x1
                          media: Ethernet autoselect (1000baseT <full-duplex>)
                          status: active
                          supported media:
                          media autoselect
                          media 100baseTX
                          media 1000baseT
                          media 10Gbase-T
                          nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
                          It appears to auto select the 1G speed, how do I change that into the 10G speed?
                            It's set to auto negotiate and is negotiating 1G. So the port at the other end might be 1G or the cable might not support 10G.
                            If you set the port to 10G fixed you may need to set the other end to 10G fixed also and that may not be possible.
                            Try running: sysctl dev.ix.0.advertise_speed to see what link rates it's trying to negotiate to.
                            You might be able to restrict that to 10G only using: sysctl dev.ix.0.advertise_speed=4
                              kilasin @stephenw10
                              @stephenw10 said in Trouble with WAN not being able to get correct speed:
                              Ok this what I am getting when using the command sysctl dev.ix.0.advertise_speed: dev.ix.0.advertise_speed: 7
                              and this is what i got when using this command sysctl dev.ix.0.advertise_speed=4 : dev.ix.0.advertise_speed: 7 -> 4 (It disconnected my connection) So i just changed it back to 7 and i got connection back.
                                Ok, so it fails to link when it can only negotiate 10G. Check/replace the cable. Try linking to something else if you can.
                                [23.09.1-RELEASE][admin@6100.stevew.lan]/root: sysctl -d dev.ix.0.advertise_speed
                                Control advertised link speed using these flags:
                                	0x1 - advertise 100M
                                	0x2 - advertise 1G
                                	0x4 - advertise 10G
                                	0x8 - advertise 10M
                                	0x10  - advertise 2.5G
                                	0x20  - advertise 5G
                                	100M and 10M are only supported on certain adapters.
                                advertise_speed=7 implies 10G, 1G and 100M.
                                  kilasin @stephenw10
                                  Ok so I tried 10 and 20 and none worked unfortunately. I did see something curious though when the cable gets connected to my switch i see this :
                                  The LAN from the WAN nic card is connected at 10G to my switch and my computer is only at 2.5G which should be 10G but that might just be a cable issue. Sorry for digressing.
                                  Back to the WAN its weird i tried
                                  0x1 - advertise 100M (works)
                                  0x2 - advertise 1G (works)
                                  0x4 - advertise 10G(not working)
                                  0x8 - advertise 10M(invalid arguement)
                                  x10(invalid arguement)
                                  x20(invalid arguement)
                                    That NIC likely doesn't support 2.5G or 5G so you can't set those advertise speeds.
                                    I assume that switch is on the LAN side?
                                    The WAN is connected to the ISP/ONT directly?
                                      kilasin @stephenw10
                                      @stephenw10 Correct on both questions .
                                        kilasin @stephenw10
                                        @stephenw10 I do have another 10G card that i can physically put in the machine but then that only leaves me with a 2.5G nic however I want my speeds lol i have another 2.5G card installed in the server but that is an rtl and pfsense does not like rtl cards as i tried implementing it into pfsense to no avail
                                          Does the ISP/ONT device support 2.5G?
                                          A Realtek 2.5G NIC in pfSense requires the realtek-kmod driver package.
                                            kilasin @stephenw10
                                            the ISP/ONT supports it as their router gets those speeds. I tested their speed test and im getting exactly what I pay for but only in Wifi not Ethernet cuz of the port which makes no sense to me but that is how it is.
                                            I see il try to install that package and try to use that nic as my WAN ..But I think i will bite the bullet and buy another 2.5G card that is compatible with pfsense
