Problem with 24.03 and Interface Bound States. Proxmox OUT!
My whole system was working fine. When I connect with Wireguard I have access to my entire internal network with no problem.
When I upgraded to the new version and enabled “Interface Bound States” from wireguard I no longer have access to all proxmox. Curiously, switches, other routers, virtual machines, etc... go as usual, but proxmox NO.Everything ok, I update and a part of the system stops working. If I activate again “Floating States” everything goes back to normal.
In firewall rules in Wireguard I have allowed all traffic and should be able to reach any machine.
Any idea what is going on?
Thanks!
Here is UptimeKuma..
Green are switches, MVs, etc..
Red Proxmox nodes.
Switch on "Interface Bound States" red.. switch off, green...What is going on here?
@wisepds said in Problem with 24.03 and Interface Bound States. Proxmox OUT!:
Looks like you have asymmetric routing going on without knowing it, now you do.
@Bob-Dig But the configuration is the same for all devices.. why proxmox fail?
@Bob-Dig Ok, but you don't give me a solution... can you help me?
@wisepds Any help @stephenw10
J jimp moved this topic from Problems Installing or Upgrading pfSense Software on
@wisepds Fixed done. I was doing a asymetric routering. Check gateways if you have more than one... now working well.
Thanks.
