    WiFi device not being loaded, not sure how to track down the issue
    4 Posts 3 Posters 1.3k Views 3 Watching
    • SolaAesirS Offline
      SolaAesir
      I got a little Beelink EQ12 to turn into a pfSense (2.7.2-RELEASE (amd64), FreeBSD 14.0-CURRENT) router, it will eventually use a wired WAN but for now I need to use a wireless WAN so infrastructure mode is fine. It came with an Intel AX101NGW m.2 Wifi module. If I'm reading the documentation correctly, it should be supported by iwlwifi. However, it doesn't show up in my list of interfaces and if I try to create a wireless interface, Parent Interface says None available.
      dmesg shows nothing related to iwlwifi and only a warning about needing to accept the EULA around anything wireless. I created loader.conf.local and added legal.intel_iwi.license_ack=1 to both it and loader.conf itself without those lines going away.
      ---<<BOOT>>---
      Copyright (c) 1992-2023 The FreeBSD Project.
      Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
      The Regents of the University of California. All rights reserved.
      FreeBSD is a registered trademark of The FreeBSD Foundation.
      FreeBSD 14.0-CURRENT amd64 1400094 #1 RELENG_2_7_2-n255948-8d2b56da39c: Wed Dec 6 20:45:47 UTC 2023
      root@freebsd:/var/jenkins/workspace/pfSense-CE-snapshots-2_7_2-main/obj/amd64/StdASW5b/var/jenkins/workspace/pfSense-CE-snapshots-2_7_2-main/sources/FreeBSD-src-RELENG_2_7_2/amd64.amd64/sys/pfSense amd64
      FreeBSD clang version 16.0.6 (https://github.com/llvm/llvm-project.git llvmorg-16.0.6-0-g7cbf1a259152)
      VT(efifb): resolution 1920x1080
      CPU: Intel(R) N100 (806.40-MHz K8-class CPU)
      Origin="GenuineIntel" Id=0xb06e0 Family=0x6 Model=0xbe Stepping=0
      Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
      Features2=0x7ffafbbf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,SDBG,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
      AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
      AMD Features2=0x121<LAHF,ABM,Prefetch>
      Structured Extended Features=0x239ca7eb<FSGSBASE,TSCADJ,BMI1,AVX2,FDPEXC,SMEP,BMI2,ERMS,INVPCID,NFPUSG,PQE,RDSEED,ADX,SMAP,CLFLUSHOPT,CLWB,PROCTRACE,SHA>
      Structured Extended Features2=0x98c007bc<UMIP,PKU,OSPKE,WAITPKG,GFNI,VAES,VPCLMULQDQ,RDPID,MOVDIRI,MOVDIR64B>
      Structured Extended Features3=0xfc184410<FSRM,MD_CLEAR,IBT,IBPB,STIBP,L1DFL,ARCH_CAP,CORE_CAP,SSBD>
      XSAVE Features=0xf<XSAVEOPT,XSAVEC,XINUSE,XSAVES>
      IA32_ARCH_CAPS=0x180fd6b<RDCL_NO,IBRS_ALL,SKIP_L1DFL_VME,MDS_NO,TAA_NO>
      VT-x: (disabled in BIOS) PAT,HLT,MTF,PAUSE,EPT,UG,VPID,VID,PostIntr
      TSC: P-state invariant, performance statistics
      real memory = 17179869184 (16384 MB)
      avail memory = 16329113600 (15572 MB)
      Event timer "LAPIC" quality 600
      ACPI APIC Table: <ALASKA A M I >
      WARNING: L3 data cache covers more APIC IDs than a package (7 > 3)
      FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
      FreeBSD/SMP: 1 package(s) x 4 core(s)
      random: registering fast source Intel Secure Key RNG
      random: fast provider: "Intel Secure Key RNG"
      random: unblocking device.
      ioapic0 <Version 2.0> irqs 0-119
      Launching APs: 3 1 2
      TCP_ratelimit: Is now initialized
      wlan: mac acl policy registered
      iwi_bss: You need to read the LICENSE file in /usr/share/doc/legal/intel_iwi.LICENSE.
      iwi_bss: If you agree with the license, set legal.intel_iwi.license_ack=1 in /boot/loader.conf.
      module_register_init: MOD_LOAD (iwi_bss_fw, 0xffffffff80765180, 0) error 1
      iwi_ibss: You need to read the LICENSE file in /usr/share/doc/legal/intel_iwi.LICENSE.
      iwi_ibss: If you agree with the license, set legal.intel_iwi.license_ack=1 in /boot/loader.conf.
      module_register_init: MOD_LOAD (iwi_ibss_fw, 0xffffffff80765230, 0) error 1
      iwi_monitor: You need to read the LICENSE file in /usr/share/doc/legal/intel_iwi.LICENSE.
      iwi_monitor: If you agree with the license, set legal.intel_iwi.license_ack=1 in /boot/loader.conf.
      module_register_init: MOD_LOAD (iwi_monitor_fw, 0xffffffff807652e0, 0) error 1
      random: entropy device external interface
      kbd0 at kbdmux0
      WARNING: Device "spkr" is Giant locked and may be deleted before FreeBSD 14.0.
      netgate0: <unknown hardware>
      efirtc0: <EFI Realtime Clock>
      efirtc0: registered as a time-of-day clock, resolution 1.000000s
      smbios0: <System Management BIOS> at iomem 0x75da3000-0x75da301e
      smbios0: Version: 3.5, BCD Revision: 3.5
      acpi0: <ALASKA A M I >
      Firmware Error (ACPI): Could not resolve symbol [\134_SB.PC00.TXHC.RHUB.SS01], AE_NOT_FOUND (20221020/dswload2-315)
      ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20221020/psobject-372)
      Firmware Error (ACPI): Could not resolve symbol [\134_SB.PC00.TXHC.RHUB.SS02], AE_NOT_FOUND (20221020/dswload2-315)
      acpi0: Power Button (fixed)
      hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
      Timecounter "HPET" frequency 19200000 Hz quality 950
      Event timer "HPET" frequency 19200000 Hz quality 550
      Event timer "HPET1" frequency 19200000 Hz quality 440
      Event timer "HPET2" frequency 19200000 Hz quality 440
      Event timer "HPET3" frequency 19200000 Hz quality 440
      Event timer "HPET4" frequency 19200000 Hz quality 440
      atrtc1: <AT realtime clock> on acpi0
      atrtc1: Warning: Couldn't map I/O.
      atrtc1: registered as a time-of-day clock, resolution 1.000000s
      Event timer "RTC" frequency 32768 Hz quality 0
      attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
      Timecounter "i8254" frequency 1193182 Hz quality 0
      Event timer "i8254" frequency 1193182 Hz quality 100
      Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
      acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
      pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
      pci0: <ACPI PCI bus> on pcib0
      vgapci0: <VGA-compatible display> port 0x3000-0x303f mem 0x6000000000-0x6000ffffff,0x4000000000-0x400fffffff irq 16 at device 2.0 on pci0
      vgapci0: Boot video device
      xhci0: <XHCI (generic) USB 3.0 controller> mem 0x6001100000-0x600110ffff irq 16 at device 20.0 on pci0
      xhci0: 32 bytes context size, 64-bit DMA
      usbus0 on xhci0
      usbus0: 5.0Gbps Super Speed USB v3.0
      pci0: <memory, RAM> at device 20.2 (no driver attached)
      pci0: <network> at device 20.3 (no driver attached)
      pci0: <serial bus> at device 21.0 (no driver attached)
      pci0: <serial bus> at device 21.1 (no driver attached)
      pci0: <simple comms> at device 22.0 (no driver attached)
      ahci0: <AHCI SATA controller> port 0x3090-0x3097,0x3080-0x3083,0x3060-0x307f mem 0x80b00000-0x80b01fff,0x80b03000-0x80b030ff,0x80b02000-0x80b027ff irq 16 at device 23.0 on pci0
      ahci0: AHCI v1.31 with 1 6Gbps ports, Port Multiplier not supported
      ahcich1: <AHCI channel> at channel 1 on ahci0
      pcib1: <ACPI PCI-PCI bridge> irq 18 at device 28.0 on pci0
      pci1: <ACPI PCI bus> on pcib1
      igc0: <Intel(R) Ethernet Controller I225-V> mem 0x80800000-0x808fffff,0x80900000-0x80903fff irq 18 at device 0.0 on pci1
      igc0: Using 1024 TX descriptors and 1024 RX descriptors
      igc0: Using 4 RX queues 4 TX queues
      igc0: Using MSI-X interrupts with 5 vectors
      igc0: Ethernet address: e8:ff:1e:d1:e2:ed
      igc0: netmap queues/slots: TX 4/1024, RX 4/1024
      pcib2: <ACPI PCI-PCI bridge> irq 16 at device 29.0 on pci0
      pci2: <ACPI PCI bus> on pcib2
      igc1: <Intel(R) Ethernet Controller I225-V> mem 0x80500000-0x805fffff,0x80600000-0x80603fff irq 16 at device 0.0 on pci2
      igc1: Using 1024 TX descriptors and 1024 RX descriptors
      igc1: Using 4 RX queues 4 TX queues
      igc1: Using MSI-X interrupts with 5 vectors
      igc1: Ethernet address: e8:ff:1e:d1:e2:ee
      igc1: netmap queues/slots: TX 4/1024, RX 4/1024
      pcib3: <ACPI PCI-PCI bridge> irq 18 at device 29.2 on pci0
      pci3: <ACPI PCI bus> on pcib3
      nvme0: <Generic NVMe Device> mem 0x80a00000-0x80a03fff irq 18 at device 0.0 on pci3
      pci0: <simple comms> at device 30.0 (no driver attached)
      pci0: <serial bus> at device 30.3 (no driver attached)
      isab0: <PCI-ISA bridge> at device 31.0 on pci0
      isa0: <ISA bus> on isab0
      hdac0: <Intel Alder Lake-N HDA Controller> mem 0x6001110000-0x6001113fff,0x6001000000-0x60010fffff irq 19 at device 31.3 on pci0
      pci0: <serial bus> at device 31.5 (no driver attached)
      acpi_button0: <Sleep Button> on acpi0
      cpu0: <ACPI CPU> on acpi0
      acpi_button1: <Power Button> on acpi0
      acpi_tz0: <Thermal Zone> on acpi0
      ns8250: UART FCR is broken
      uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
      acpi_syscontainer0: <System Container> on acpi0
      acpi_syscontainer1: <System Container> on acpi0
      atrtc0: <AT realtime clock> at port 0x70 irq 8 on isa0
      atrtc0: Warning: Couldn't map I/O.
      atrtc0: registered as a time-of-day clock, resolution 1.000000s
      atrtc0: Can't map interrupt.
      hwpstate_intel0: <Intel Speed Shift> on cpu0
      hwpstate_intel1: <Intel Speed Shift> on cpu1
      hwpstate_intel2: <Intel Speed Shift> on cpu2
      hwpstate_intel3: <Intel Speed Shift> on cpu3
      Timecounter "TSC" frequency 806399617 Hz quality 1000
      Timecounters tick every 1.000 msec
      ZFS filesystem version: 5
      ZFS storage pool version: features support (5000)
      ugen0.1: <Intel XHCI root HUB> at usbus0
      uhub0 on usbus0
      uhub0: <Intel XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
      nvme0: Allocated 64MB host memory buffer
      hdacc0: <Realtek ALC897 HDA CODEC> at cad 0 on hdac0
      hdaa0: <Realtek ALC897 Audio Function Group> at nid 1 on hdacc0
      pcm0: <Realtek ALC897 (Rear Analog)> at nid 20 and 24,26 on hdaa0
      pcm1: <Realtek ALC897 (Front Analog)> at nid 27 and 25 on hdaa0
      nda0 at nvme0 bus 0 scbus1 target 0 lun 1
      nda0: <512GB SSD V0808A0 NKG393R005086P70GX>
      nda0: Serial Number NKG393R005086P70GX
      nda0: nvme version 1.3
      nda0: 488386MB (1000215216 512 byte sectors)
      Trying to mount root from zfs:pfSense/ROOT/default []...
      uhub0: 16 ports with 16 removable, self powered
      Root mount waiting for: usbus0
      ugen0.2: <SONiX USB DEVICE> at usbus0
      ukbd0 on uhub0
      ukbd0: <SONiX USB DEVICE, class 0/0, rev 2.00/1.03, addr 1> on usbus0
      kbd1 at ukbd0
      ukbd1 on uhub0
      ukbd1: <SONiX USB DEVICE, class 0/0, rev 2.00/1.03, addr 1> on usbus0
      kbd2 at ukbd1
      ugen0.3: <vendor 0x8087 product 0x0026> at usbus0
      ig4iic0: <Intel Alder Lake-M I2C Controller-0> at device 21.0 on pci0
      ig4iic0: Using MSI
      iicbus0: <Philips I2C bus (ACPI-hinted)> on ig4iic0
      iicbus0: <unknown card> at addr 0x2c
      ig4iic1: <Intel Alder Lake-M I2C Controller-1> at device 21.1 on pci0
      ig4iic1: Using MSI
      iicbus1: <Philips I2C bus (ACPI-hinted)> on ig4iic1
      ichsmb0: <Intel Alder Lake SMBus controller> port 0xefa0-0xefbf mem 0x600111c000-0x600111c0ff irq 16 at device 31.4 on pci0
      smbus0: <System Management Bus> on ichsmb0
      aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS,SHA1,SHA256>
      coretemp0: <CPU On-Die Thermal Sensors> on cpu0
      lo0: link state changed to UP
      pflog0: promiscuous mode enabled
      igc0: link state changed to UP
      Running pciconf -lv gives me
      hostb0@pci0:0:0:0: class=0x060000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x461c subvendor=0x8086 subdevice=0x7270
      vendor = 'Intel Corporation'
      class = bridge
      subclass = HOST-PCI
      vgapci0@pci0:0:2:0: class=0x030000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x46d1 subvendor=0x8086 subdevice=0x7270
      device = 'Alder Lake-N [UHD Graphics]'
      class = display
      subclass = VGA
      xhci0@pci0:0:20:0: class=0x0c0330 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54ed subvendor=0x8086 subdevice=0x7270
      class = serial bus
      subclass = USB
      none0@pci0:0:20:2: class=0x050000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54ef subvendor=0x8086 subdevice=0x7270
      class = memory
      subclass = RAM
      none1@pci0:0:20:3: class=0x028000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54f0 subvendor=0x8086 subdevice=0x0244
      class = network
      ig4iic0@pci0:0:21:0: class=0x0c8000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54e8 subvendor=0x8086 subdevice=0x7270
      class = serial bus
      ig4iic1@pci0:0:21:1: class=0x0c8000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54e9 subvendor=0x8086 subdevice=0x7270
      class = serial bus
      none2@pci0:0:22:0: class=0x078000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54e0 subvendor=0x8086 subdevice=0x7270
      class = simple comms
      ahci0@pci0:0:23:0: class=0x010601 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54d3 subvendor=0x8086 subdevice=0x7270
      class = mass storage
      subclass = SATA
      pcib1@pci0:0:28:0: class=0x060400 rev=0x00 hdr=0x01 vendor=0x8086 device=0x54be subvendor=0x8086 subdevice=0x7270
      class = bridge
      subclass = PCI-PCI
      pcib2@pci0:0:29:0: class=0x060400 rev=0x00 hdr=0x01 vendor=0x8086 device=0x54b0 subvendor=0x8086 subdevice=0x7270
      class = bridge
      subclass = PCI-PCI
      pcib3@pci0:0:29:2: class=0x060400 rev=0x00 hdr=0x01 vendor=0x8086 device=0x54b2 subvendor=0x8086 subdevice=0x7270
      class = bridge
      subclass = PCI-PCI
      none3@pci0:0:30:0: class=0x078000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54a8 subvendor=0x8086 subdevice=0x7270
      none4@pci0:0:30:3: class=0x0c8000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54ab subvendor=0x8086 subdevice=0x7270
      class = serial bus
      isab0@pci0:0:31:0: class=0x060100 rev=0x00 hdr=0x00 vendor=0x8086 device=0x5481 subvendor=0x8086 subdevice=0x7270
      class = bridge
      subclass = PCI-ISA
      hdac0@pci0:0:31:3: class=0x040300 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54c8 subvendor=0x8086 subdevice=0x7270
      class = multimedia
      subclass = HDA
      ichsmb0@pci0:0:31:4: class=0x0c0500 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54a3 subvendor=0x8086 subdevice=0x7270
      class = serial bus
      subclass = SMBus
      none5@pci0:0:31:5: class=0x0c8000 rev=0x00 hdr=0x00 vendor=0x8086 device=0x54a4 subvendor=0x8086 subdevice=0x7270
      class = serial bus
      igc0@pci0:1:0:0: class=0x020000 rev=0x03 hdr=0x00 vendor=0x8086 device=0x15f3 subvendor=0x8086 subdevice=0x0000
      device = 'Ethernet Controller I225-V'
      class = network
      subclass = ethernet
      igc1@pci0:2:0:0: class=0x020000 rev=0x03 hdr=0x00 vendor=0x8086 device=0x15f3 subvendor=0x8086 subdevice=0x0000
      class = network
      subclass = ethernet
      nvme0@pci0:3:0:0: class=0x010802 rev=0x03 hdr=0x00 vendor=0x126f device=0x2263 subvendor=0x126f subdevice=0x2263
      vendor = 'Silicon Motion, Inc.'
      device = 'SM2263EN/SM2263XT SSD Controller'
      subclass = NVM
      So it is seeing the device and just not assigning a driver to it.
      As far as I can tell, iwlwifi isn't being loaded as a module at all, though Feature #14050 says it should have been added in 2.7.0. sysctl -a -x doesn't mention it anywhere. sysctl net.wlan.devices just gives an empty list net.wlan.devices:
      I'm not at all skilled with BSD and so I have no idea what next steps to take. Can anyone help?
        Gertjan @SolaAesir
        @SolaAesir said in WiFi device not being loaded, not sure how to track down the issue:
        kldstat -v
        to see all the drivers build into the kernel, and avaible as files in /boot/kernel/.
        kldstat -v | grep 'iwl'
        shows everything that has 'iwl' in its name.
        On my pfSense 24.03 : nothing.
        If you can get your hands on a complied and build driver file, the one with the 'ko' extension, and it was build for 'FreeBSD 15.0' you could place it on your system an see if the found hardware activated the driver you've included.
        You probably also have to include a line in the file /boot/loader.conf.local :
        iwlwifi _load=YES"
        If iwlwifi.ko is the file name of the driver.
        If the file /boot/loader.conf.local doesn't exist, create it.
        Btw : use SSH or the console, not the crappy Diagnostics > Command Prompt.
        Feature #14050
        I could check if this
        Description
        The iwlwifi(4) driver is supported in pfSense 23.01/2.7 but needs to be added to the 'wireless_regex' list in order for the webgui to display wireless options for it.
        is actually present in the current pfSense.
        One general remark : Wifi and FreeBSD are not friends.
        Wifi on a LAN is already 'bad'. Wifi as a WAN ... imho : don't do that. Live is already to sshort, don't make that pain-full. Get a cable, and enjoy the simplicity.
          The driver is no longer included by default. The kernel module is in the 2.7.2 ISO image though so you can copy it across if you want to try it.
          However it's not particularly useful. It cannot run as an access point AFAIK.
            SolaAesir
            Thank you two. I wasn't able to dig into the iso to try and add the kernel module since neither my Linux or Windows computer wanted to mount it but I had a spare AP I could steal until I can get wiring installed that seems happy to mesh up and act as my WAN port (Unifi U6). They wouldn't do it when I tried to do the same thing a year ago with another computer, but they've either had a firmware update in the meantime or pfsense is smarter than a more normal OS and could work it out. This should be much better than a little m.2 wifi card anyway.
            • R raymond.jimenez referenced this topic on
