    LAN interface Speed and Duplex not correct working
    Scheduled Pinned Locked Moved Plus 24.11 Development Snapshots (Retired)
    4 Posts 2 Posters 923 Views 3 Watching
      Antibiotic
      Hi, i never have this problem before with 24.03. The problem exist, if set to auto select option interface on LAN. Then card speed and duplex going 10 Mb or 100 simply start jumping and losing internet connection. Very interesting, another cards on same box working correctly with auto select option. If set to default Speed and Duplex card start working. All cards are intel i226-v, any ideas?
      pfSense plus 25.11 on Topton mini PC
      CPU: Intel N100
      NIC: Intel i-226v 4 pcs
      RAM : 16 GB DDR5
      Disk: 128 GB NVMe
      Brgds, Archi
        The igc driver does not actually support fix speeds or duplex settings in any version. When you set that what it does is restrict the advertised speeds that it can negotiate in auto-select.
        So it can never link to a NIC that is not auto-negotiating (true fixed speed/duplex).
        Additionally it has a quirk where setting it to auto-select specifically rather than default can cause the link to flap at ~2s intervals in my experience.
        i225/i226 NICs using the igc driver should always be left at default unless you have a very good reason to set anything else. However that isn't a regression. The behaviour was the same in 24.03.
          Antibiotic @stephenw10
          @stephenw10 Oh, so better to keep "default (no preference, typically autoselect)" option with this NIC's and not to set to autoselect?
          CPU: Intel N100
          RAM : 16 GB DDR5
          Disk: 128 GB NVMe
          Brgds, Archi
            Yes. In almost every case when using igc.
