    Flow control System tunables ignored on sg-1537
    4 Posts 2 Posters 501 Views 1 Watching
    • keyserK Offline
      keyser Rebel Alliance
      Hi
      I seem to have discovered an issue with SG-1537 boxes and flow control on the 10Gbe interfaces.
      By default pfsense has flow control enabled on the ix0 and ix1 built in interfaces. I have tried disabling them with a "system tunables" set in the UI pr. following the documentation: hw.ix.flow_control=0
      Setting that has no effect on the actual NIC after restart.
      Doing a "sysctl -a | grep fc" clearly shows dev.ix.0.fc is still in mode 3 (auto).
      Doing a "sysctl -a | grep flow_control" also shows the settings as still being in mode 3
      The only way I can disable it is by running a "sysctl dev.ix.0.fc=0" runtime
      That works, and the interface no longer shows nor tries txpause,rxpause frames.
      But setting dev.ix.0.fc=0 in system tuntables also has no effect after a boot.
      This is 24.11, and I tried on 24.03 also - both show the same behaviour.
      • E Online
        elvisimprsntr @keyser
        @keyser
        did you try putting it in a /boot/loader.conf.local file?
        https://docs.netgate.com/pfsense/en/latest/config/advanced-tunables.html#managing-loader-tunables
        • keyserK Offline
          keyser Rebel Alliance @elvisimprsntr
          @elvisimprsntr said in Flow control System tunables ignored on sg-1537:
          No, I thought it would be enough to put them in SYSTEM -> ADVANCED -> SYSTEM TUNABLES.
          Am I to understand that menu is only for runtime edits. For boottime tunables I have to put them in the loader.conf manually?
          edit: read you documentation link all the way, and yes, that is the conclusion.
          • E Online
            @keyser
            Put it in a new file
            That way it will survive pfSense upgrades.
            I personally install nano to make small file edits via SSH CLI
            pkg install nano
