    Issue with WAN speed negotiation after upgrading from 2.7 to 2.8 or 2.8.1
    24 Posts 5 Posters 5.3k Views 4 Watching
      C80SGEEK @stephenw10
      @stephenw10 said in Issue with WAN speed negotiation after upgrading from 2.7 to 2.8 or 2.8.1:
      What happens if you set the media to 100M without setting the mediaopt value so it still tries to negotiate that?
      I made the test by not specifying mediaportopt : from GUI and SSH
      ifconfig igb0 media 100baseTX
      ifconfig -vvm igb0
      gb0: flags=1008943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500
      description: WAN
      options=4e100bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWFILTER,RXCSUM_IPV6,TXCSUM_IPV6,HWSTATS,MEXTPG>
      capabilities=4f53fbb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,NETMAP,RXCSUM_IPV6,TXCSUM_IPV6,HWSTATS,MEXTPG>
      ether 00:90:0b:72:d8:83
      inet X.X.X.X netmask X.X.X.X broadcast X.X.X.X
      inet6 X.X.X.X prefixlen 64 scopeid 0x3
      media: Ethernet 100baseTX (100baseTX <half-duplex>)
      status: active
      supported media:
      media autoselect
      media 1000baseT
      media 1000baseT mediaopt full-duplex
      media 100baseTX mediaopt full-duplex
      media 100baseTX
      media 10baseT/UTP mediaopt full-duplex
      media 10baseT/UTP
      drivername: igb0
      No luck here proble still remains the same
        Just trying to see if it can be worked around with the existing code.
        This is an embarrassing situation, considering that this is a stable version of pfSense and that my hardware is in production. I also note that we had to wait a very long time between pfSense 2.7.2 and pfSense 2.8.
        I am not sure I fully understand what the source code indicates and what it represents in the development branch: https://github.com/pfsense/FreeBSD-src/commit/3ff0231c87f360afa4521e635b46f6c711dc4ee3
        The workaround I see is to use a managed switch and set the speeds and media options manually.
        What concerns me here is that in the event of a real issue on an internet line, the ISP systematically suspects customer equipment (for example, a switch), and in this case, I would no longer be able to demonstrate the proper functioning of my firewall directly on the line.
        The other option would be to revert to pfSense version 2.7.2, which is older and suffers from certain vulnerabilities.
        Do you think that paid support could be a solution?
        Kind regards,
          Well in Plus 25.11 dev snapshots are now available and they contain the commit that revered that change. So you could test it now.
          I'm looking at what we can do before that....
            Opened a bug to track: https://redmine.pfsense.org/issues/16449
            • stephenw10S stephenw10 moved this topic from Problems Installing or Upgrading pfSense Software on
              mer
              From a long time ago, PHYs always had issues with "negotiation" if one side was set to fixed configurations and the other set to autonegotiate.
              The way the hardware works (worked?) is speed can be figured out, duplex can't.
              A way around this is leave both sides at autoneg, but you only present the options you want.
              Example:
              HW can do 10,100,1000 speeds, half, full. You want to only do 100, full so the autoneg options presented are "100, full" and the autoneg process does it's thing.
              Presenting autoneg options is different than setting an interface to fixed. Setting to fixed means "i'm not even trying autoneg".
              I think (believe/hope) most manufacturers leave autoneg on and interfaces restrict what is presented.
              All that at least for copper.
              Fiber I think really wants both sides saying "fixed".
                Yup. It appears this patch attempted to allow linking to ports where speed is fixed but duplex is still negotiated. Which seems like an extreme edge case, I don't think I've ever seen it.
                It has wound up introducing this but where igb is trying to negotiate the duplex and the other side is set fixed. Hence it falls back to half-duplex. Obviously it should be possible to just set it fixed because, yes, both sides must be set the same.
                  C80SGEEK @mer
                  @mer
                  As mentioned, our ISP router is a fiber optic router and has a fixed configuration.
                  We have always configured our firewall to match the router, namely 100BaseTX full-duplex. This had been working perfectly for more than ten years, up until pfSense version 2.8.0.
                  Kind regards
                    What I understand is that, as of today, pfSense 2.8 no longer allows fixing the mediaopt configuration.
                    Do you think this will be corrected? Does the pfSense Plus version fix this bug?
                      The commit that reverted that patch is in 25.11-dev snapshots in Plus. But 25.07.1 is the same base as 2.8.1. I'm still looking at what we can do here. I'm sure it affects more users than just you.
                        Thank you for your help so far. I will wait for your feedback to see if there is a solution.
                        Perhaps I will simply downgrade to version 2.7.2 for the time being in order to keep my installations operational.
