pfSense VM on Proxmox: PPPoE only works when parent NIC is PCI passthrough — virtual NIC breaks LAN→WAN traffic
@w0w
All vlan configuration is handled at the hypervisor level.
pf sees only virtual interfaces.Here is the output
sysctl hw.vtnet hw.vtnet.altq_disable: 1 hw.vtnet.lro_mbufq_depth: 0 hw.vtnet.lro_entry_count: 128 hw.vtnet.rx_process_limit: 1024 hw.vtnet.tso_maxlen: 65535 hw.vtnet.mq_max_pairs: 32 hw.vtnet.mq_disable: 0 hw.vtnet.lro_disable: 1 hw.vtnet.tso_disable: 1 hw.vtnet.fixup_needs_csum: 0 hw.vtnet.csum_disable: 1ifconfig vtnet0 vtnet0: flags=1008943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500 options=880028<VLAN_MTU,JUMBO_MTU,LINKSTATE,HWSTATS> ether 52:54:00:05:01:fb inet 192.168.31.3 netmask 0xffffff00 broadcast 192.168.31.255 inet6 fe80::5054:ff:fe05:1fb%vtnet0 prefixlen 64 scopeid 0x1 media: Ethernet autoselect (10Gbase-T <full-duplex>) status: active nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> -
@netblues
I kinda screwed up… I forgot to mention that this ix0 is part of a LAGG interface, and the LAN itself is using that LAGG. This shouldn’t really affect anything, but I’ll check if that’s the issue. Also, I don’t remember changing any settings for this NIC on the host, I think I left it as is. -
Configured LAN to use ix0 directly — nothing changed.
@netblues said in pfSense VM on Proxmox: PPPoE only works when parent NIC is PCI passthrough — virtual NIC breaks LAN→WAN traffic:
JUMBO_MTU
Hmm… I don't see any jumbo settings on my vtnet interfaces, did you change something? VM setiings? Nonstandard MTU?
Now I have configured it directly for both pppoe and LAN
vtnet0: flags=1008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500 options=880008<VLAN_MTU,LINKSTATE,HWSTATS> ether a- inet6 fe80::aab8:e0ff:fe02:655a%vtnet0 prefixlen 64 scopeid 0x5 media: Ethernet autoselect (10Gbase-T <full-duplex>) status: active nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> vtnet1: flags=1008943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500 description: LAN options=880008<VLAN_MTU,LINKSTATE,HWSTATS> ether a- inet 10.0.67.2 netmask 0xffffff00 broadcast 10.0.67.255 inet 10.0.67.5 netmask 0xffffff00 broadcast 10.0.67.255 vhid 5 inet 10.0.70.5 netmask 0xffffff00 broadcast 10.0.70.255 vhid 10 inet 10.0.70.11 netmask 0xffffff00 broadcast 10.0.70.255 inet6 fe80::a236:9fff:fef8:f225%vtnet1 prefixlen 64 scopeid 0x6 inet6 fd00:1234:abcd:1::2 prefixlen 64 inet6 fd00:1234:abcd:1::5 prefixlen 64 vhid 12 carp: MASTER vhid 5 advbase 5 advskew 100 peer 224.0.0.18 peer6 ff02::12 carp: MASTER vhid 10 advbase 5 advskew 100 peer 224.0.0.18 peer6 ff02::12 carp: MASTER vhid 12 advbase 5 advskew 100 peer 224.0.0.18 peer6 ff02::12 media: Ethernet autoselect (10Gbase-T <full-duplex>) status: active nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>Ok, I've changed MTU to 9000 in proxmox for the LAN card/bridge/vtnet
vtnet1: flags=1008943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500 description: LAN options=880028<VLAN_MTU,JUMBO_MTU,LINKSTATE,HWSTATS>Still working for me… no problem.
Proxmox settings for WAN parent
:~# ethtool -k enp6s0f0 Features for enp6s0f0: rx-checksumming: on tx-checksumming: on tx-checksum-ipv4: off [fixed] tx-checksum-ip-generic: on tx-checksum-ipv6: off [fixed] tx-checksum-fcoe-crc: on [fixed] tx-checksum-sctp: on scatter-gather: on tx-scatter-gather: on tx-scatter-gather-fraglist: off [fixed] tcp-segmentation-offload: on tx-tcp-segmentation: on tx-tcp-ecn-segmentation: off [fixed] tx-tcp-mangleid-segmentation: off tx-tcp6-segmentation: on tx-tcp-accecn-segmentation: off [fixed] generic-segmentation-offload: on generic-receive-offload: on large-receive-offload: off rx-vlan-offload: on tx-vlan-offload: on ntuple-filters: off receive-hashing: on highdma: on [fixed] rx-vlan-filter: on vlan-challenged: off [fixed] tx-gso-robust: off [fixed] tx-fcoe-segmentation: on [fixed] tx-gre-segmentation: on tx-gre-csum-segmentation: on tx-ipxip4-segmentation: on tx-ipxip6-segmentation: on tx-udp_tnl-segmentation: on tx-udp_tnl-csum-segmentation: on tx-gso-partial: on tx-tunnel-remcsum-segmentation: off [fixed] tx-sctp-segmentation: off [fixed] tx-esp-segmentation: on tx-udp-segmentation: on tx-gso-list: off [fixed] tx-nocache-copy: off loopback: off [fixed] rx-fcs: off [fixed] rx-all: off tx-vlan-stag-hw-insert: off [fixed] rx-vlan-stag-hw-parse: off [fixed] rx-vlan-stag-filter: off [fixed] l2-fwd-offload: off hw-tc-offload: off esp-hw-offload: on esp-tx-csum-hw-offload: on rx-udp_tunnel-port-offload: on tls-hw-tx-offload: off [fixed] tls-hw-rx-offload: off [fixed] rx-gro-hw: off [fixed] tls-hw-record: off [fixed] rx-gro-list: off macsec-hw-offload: off [fixed] rx-udp-gro-forwarding: off hsr-tag-ins-offload: off [fixed] hsr-tag-rm-offload: off [fixed] hsr-fwd-offload: off [fixed] hsr-dup-offload: off [fixed]LAN
ethtool -k enp6s0f1 Features for enp6s0f1: rx-checksumming: on tx-checksumming: on tx-checksum-ipv4: off [fixed] tx-checksum-ip-generic: on tx-checksum-ipv6: off [fixed] tx-checksum-fcoe-crc: on [fixed] tx-checksum-sctp: on scatter-gather: on tx-scatter-gather: on tx-scatter-gather-fraglist: off [fixed] tcp-segmentation-offload: on tx-tcp-segmentation: on tx-tcp-ecn-segmentation: off [fixed] tx-tcp-mangleid-segmentation: off tx-tcp6-segmentation: on tx-tcp-accecn-segmentation: off [fixed] generic-segmentation-offload: on generic-receive-offload: on large-receive-offload: off rx-vlan-offload: on tx-vlan-offload: on ntuple-filters: off receive-hashing: on highdma: on [fixed] rx-vlan-filter: on vlan-challenged: off [fixed] tx-gso-robust: off [fixed] tx-fcoe-segmentation: on [fixed] tx-gre-segmentation: on tx-gre-csum-segmentation: on tx-ipxip4-segmentation: on tx-ipxip6-segmentation: on tx-udp_tnl-segmentation: on tx-udp_tnl-csum-segmentation: on tx-gso-partial: on tx-tunnel-remcsum-segmentation: off [fixed] tx-sctp-segmentation: off [fixed] tx-esp-segmentation: on tx-udp-segmentation: on tx-gso-list: off [fixed] tx-nocache-copy: off loopback: off [fixed] rx-fcs: off [fixed] rx-all: off tx-vlan-stag-hw-insert: off [fixed] rx-vlan-stag-hw-parse: off [fixed] rx-vlan-stag-filter: off [fixed] l2-fwd-offload: off hw-tc-offload: off esp-hw-offload: on esp-tx-csum-hw-offload: on rx-udp_tunnel-port-offload: on tls-hw-tx-offload: off [fixed] tls-hw-rx-offload: off [fixed] rx-gro-hw: off [fixed] tls-hw-record: off [fixed] rx-gro-list: off macsec-hw-offload: off [fixed] rx-udp-gro-forwarding: off hsr-tag-ins-offload: off [fixed] hsr-tag-rm-offload: off [fixed] hsr-fwd-offload: off [fixed] hsr-dup-offload: off [fixed] -
@w0w I see minor differences on the physical kvm interface, but I haven't done anything special, its at defaults.
The mtu has been adjusted to 1508, but that can't be the issue. In any case, the brigded interfaces all use 1500 as mtu.
As is, the same bridges are used at the same time by pfpls @25.07 pfplus @25.11rc and pfCE 2.8.1 with multiple pppoe connections over the same parent vlam.
Only new rc fails to work as described above.
ethtool -k enp1s0.31 Features for enp1s0.31: rx-checksumming: off [fixed] tx-checksumming: on tx-checksum-ipv4: off [fixed] tx-checksum-ip-generic: on tx-checksum-ipv6: off [fixed] tx-checksum-fcoe-crc: off [requested on] tx-checksum-sctp: off [requested on] scatter-gather: on tx-scatter-gather: on tx-scatter-gather-fraglist: off [requested on] tcp-segmentation-offload: on tx-tcp-segmentation: on tx-tcp-ecn-segmentation: on tx-tcp-mangleid-segmentation: on tx-tcp6-segmentation: on generic-segmentation-offload: on generic-receive-offload: on large-receive-offload: off [fixed] rx-vlan-offload: off [fixed] tx-vlan-offload: off [fixed] ntuple-filters: off [fixed] receive-hashing: off [fixed] highdma: on rx-vlan-filter: off [fixed] vlan-challenged: off [fixed] tx-gso-robust: off [fixed] tx-fcoe-segmentation: off [requested on] tx-gre-segmentation: off [requested on] tx-gre-csum-segmentation: off [requested on] tx-ipxip4-segmentation: off [requested on] tx-ipxip6-segmentation: off [requested on] tx-udp_tnl-segmentation: off [requested on] tx-udp_tnl-csum-segmentation: off [requested on] tx-gso-partial: off [fixed] tx-tunnel-remcsum-segmentation: off [fixed] tx-sctp-segmentation: on tx-esp-segmentation: off [fixed] tx-udp-segmentation: on tx-gso-list: on tx-nocache-copy: off loopback: off [fixed] rx-fcs: off [fixed] rx-all: off [fixed] tx-vlan-stag-hw-insert: off [fixed] rx-vlan-stag-hw-parse: off [fixed] rx-vlan-stag-filter: off [fixed] l2-fwd-offload: off [fixed] hw-tc-offload: off [fixed] esp-hw-offload: off [fixed] esp-tx-csum-hw-offload: off [fixed] rx-udp_tunnel-port-offload: off [fixed] tls-hw-tx-offload: off [fixed] tls-hw-rx-offload: off [fixed] rx-gro-hw: off [fixed] tls-hw-record: off [fixed] rx-gro-list: off macsec-hw-offload: off [fixed] rx-udp-gro-forwarding: off hsr-tag-ins-offload: off [fixed] hsr-tag-rm-offload: off [fixed] hsr-fwd-offload: off [fixed] hsr-dup-offload: off [fixed]ethtool -k enp1s0.835 Features for enp1s0.835: rx-checksumming: off [fixed] tx-checksumming: on tx-checksum-ipv4: off [fixed] tx-checksum-ip-generic: on tx-checksum-ipv6: off [fixed] tx-checksum-fcoe-crc: off [requested on] tx-checksum-sctp: off [requested on] scatter-gather: on tx-scatter-gather: on tx-scatter-gather-fraglist: off [requested on] tcp-segmentation-offload: on tx-tcp-segmentation: on tx-tcp-ecn-segmentation: on tx-tcp-mangleid-segmentation: on tx-tcp6-segmentation: on generic-segmentation-offload: on generic-receive-offload: on large-receive-offload: off [fixed] rx-vlan-offload: off [fixed] tx-vlan-offload: off [fixed] ntuple-filters: off [fixed] receive-hashing: off [fixed] highdma: on rx-vlan-filter: off [fixed] vlan-challenged: off [fixed] tx-gso-robust: off [fixed] tx-fcoe-segmentation: off [requested on] tx-gre-segmentation: off [requested on] tx-gre-csum-segmentation: off [requested on] tx-ipxip4-segmentation: off [requested on] tx-ipxip6-segmentation: off [requested on] tx-udp_tnl-segmentation: off [requested on] tx-udp_tnl-csum-segmentation: off [requested on] tx-gso-partial: off [fixed] tx-tunnel-remcsum-segmentation: off [fixed] tx-sctp-segmentation: on tx-esp-segmentation: off [fixed] tx-udp-segmentation: on tx-gso-list: on tx-nocache-copy: off loopback: off [fixed] rx-fcs: off [fixed] rx-all: off [fixed] tx-vlan-stag-hw-insert: off [fixed] rx-vlan-stag-hw-parse: off [fixed] rx-vlan-stag-filter: off [fixed] l2-fwd-offload: off [fixed] hw-tc-offload: off [fixed] esp-hw-offload: off [fixed] esp-tx-csum-hw-offload: off [fixed] rx-udp_tunnel-port-offload: off [fixed] tls-hw-tx-offload: off [fixed] tls-hw-rx-offload: off [fixed] rx-gro-hw: off [fixed] tls-hw-record: off [fixed] rx-gro-list: off macsec-hw-offload: off [fixed] rx-udp-gro-forwarding: off hsr-tag-ins-offload: off [fixed] hsr-tag-rm-offload: off [fixed] hsr-fwd-offload: off [fixed] hsr-dup-offload: off [fixed]ethtool -k enp1s0 Features for enp1s0: rx-checksumming: on tx-checksumming: on tx-checksum-ipv4: on tx-checksum-ip-generic: off [fixed] tx-checksum-ipv6: on tx-checksum-fcoe-crc: off [fixed] tx-checksum-sctp: off [fixed] scatter-gather: on tx-scatter-gather: on tx-scatter-gather-fraglist: off [fixed] tcp-segmentation-offload: on tx-tcp-segmentation: on tx-tcp-ecn-segmentation: off [fixed] tx-tcp-mangleid-segmentation: off tx-tcp6-segmentation: on generic-segmentation-offload: on generic-receive-offload: on large-receive-offload: off [fixed] rx-vlan-offload: on tx-vlan-offload: on ntuple-filters: off [fixed] receive-hashing: on highdma: on [fixed] rx-vlan-filter: on [fixed] vlan-challenged: off [fixed] tx-gso-robust: off [fixed] tx-fcoe-segmentation: off [fixed] tx-gre-segmentation: off [fixed] tx-gre-csum-segmentation: off [fixed] tx-ipxip4-segmentation: off [fixed] tx-ipxip6-segmentation: off [fixed] tx-udp_tnl-segmentation: off [fixed] tx-udp_tnl-csum-segmentation: off [fixed] tx-gso-partial: off [fixed] tx-tunnel-remcsum-segmentation: off [fixed] tx-sctp-segmentation: off [fixed] tx-esp-segmentation: off [fixed] tx-udp-segmentation: off [fixed] tx-gso-list: off [fixed] tx-nocache-copy: off loopback: off rx-fcs: off rx-all: off tx-vlan-stag-hw-insert: off rx-vlan-stag-hw-parse: on rx-vlan-stag-filter: on [fixed] l2-fwd-offload: off [fixed] hw-tc-offload: off [fixed] esp-hw-offload: off [fixed] esp-tx-csum-hw-offload: off [fixed] rx-udp_tunnel-port-offload: off [fixed] tls-hw-tx-offload: off [fixed] tls-hw-rx-offload: off [fixed] rx-gro-hw: off [fixed] tls-hw-record: off [fixed] rx-gro-list: off macsec-hw-offload: off [fixed] rx-udp-gro-forwarding: off hsr-tag-ins-offload: off [fixed] hsr-tag-rm-offload: off [fixed] hsr-fwd-offload: off [fixed] hsr-dup-offload: off [fixed] -
Can you ping across it with large packets?
When ICMP passes and nothing else does it's usually either an MTU issue or some sort of asymmetric routing problem. But neither should have changed in 25.11.
The packages widget issue is known: https://forum.netgate.com/topic/199375/zero-packages-install/
@stephenw10 Obviously yes
ping 8.8.4.4 -l 1472 -f
Pinging 8.8.4.4 with 1472 bytes of data:
Reply from 8.8.4.4: bytes=1472 time=14ms TTL=112
Reply from 8.8.4.4: bytes=1472 time=14ms TTL=112Ping statistics for 8.8.4.4:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 14ms, Average = 14msAnd same config couldn't cause mtu issues imho too.
And this is a plain vanila config, only one wan one lan interface, no policy routing, nothing fancy
Yup I agree it shouldn't. But PPPoE has always had MTU/MSS requirements and if_pppoe specifically had an MSS issue previously.
