Problem activating wireless interface
I have my wireless card installed and set up in OPT1. When I try to activate it I get this message:
"The DHCP Server is active on this interface and it can be used only with a static IP configuration. Please disable the DHCP Server service on this interface first, then change the interface configuration."
When I go to the DHCP Server settings, there is notheing about OPT1 that I can see. How do I get this interface activated?
Thanks!
Do you have an static IP-adress on the wireless interface?
