    Help with tap. Not sure what I'm doing wrong.
    2 Posts 1 Posters 1.6k Views
      jaredadams
      In the first screen you can see the setup of my OpenVPN server.
      I then read I was supposed to create an interface for the OpenVPN instance.  Then bridge it to the LAN.  This can be seen in the 2nd screenshot.
      I use the client export, copy everthing over to the client's config folder and i get:
      Wed Jan 04 19:42:01 2012 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
      Wed Jan 04 19:42:01 2012 TLS Error: TLS handshake failed
      Wed Jan 04 19:42:01 2012 SIGUSR1[soft,tls-error] received, process restarting
      It doesnt even get to try to connect.  I've tried firewall rules.  Would you like me to post those screenshots.
      Thanks so much!
      ovpn.png_thumb
      bridges.png_thumb
        jaredadams
        actually, got it.  had the wrong port specificed in my firewall rules.  this post can be used for people having trouble setting up i guess.
