Issue with communication between 2 nics on same pfsense box
  • Greetings,
    I have a pfsense with two lans, lan and opt1. Lan is configured with 192.168.1/24 and opt1 is 192.168.2/24. The devices on either interface cant reach the devices on the other network, specifically using samba. I would assume this is a routing issue but the routing tab has a warning about setting routes for networks physically attached to the machine.
    I don't see the packets getting flagged in the firewall log, what would cause this?
    Thanks!
  • Do you have a firewall pass rule on both interfaces that will allow traffic to the other network? Is this pass rule above any rule that would block the traffic?
