    GUI problem using several (more than 60) vlans
    7 Posts 4 Posters 3.0k Views
      davidemiccone
      I'm using pfsense to manage a network that contains several VLANs (more than 60).
      GUI tabs go over the screen and working with the rules is very difficult.
      My versione is 1.2-BETA-1-PRERELEASE-SNAPSHOT-04-23-07
      Any conseil will be appreciated
        sullrich
        Known issue.
          hoba
          Use the theme "pfsense". It won't fix the tab problem but will fix the interfaces menu. We have a solution for this but it needs to be implemented (not ultra high priority though currently).
            davidemiccone
            Thank you for the replies. I hope a solution on the tab came very quickly. It is true that it is not very important but it is very very uncomfortable working with rules with many vlans.
            Best Regards
              sullrich
              Quickly?  I doubt.  If you want to speed up the process consider starting a bounty.
                davidemiccone
                @hoba:
                Please,
                can you put me on the right path? Which is your solution? I'll try to temporary patch the interface myself. (working on rules with so many vlans is very very very unconfortable)
                • Y Offline
                  yoda715
                  Our thoughts were to create one tab for VLANs. Once you click that tab there will be a dropdown box to select which VLAN you want to work with.
